Lovelace only add new entities
My Raspberry PI has died so I reinstalled Home assistant on a virtual machine with Ubuntu server and docker as a test. Later I will install everything on a NUC.
That process went very smooth after resolving an issue with Docker on Ubuntu.
Now I’m trying to add my Foscam cameras again but I can’t find the entities.
They are not listed in the unused entities.
So I think I need to create/add them in some way but I can’t find how.
So… how do I add a IP camera entity which I then can add to lovelace?
Best regards,
Eddy
Ah I see, so I still need to add the devices through yaml.
Ok, not sure how to do that in the lastest LoveLace since I can’t add samba anymore.
Never mind, I found the way to access the files.
