Is it possible to make the font scalable for a state label? I am trying to make a thermostat control and I used an svg file as the picture so it scales nicely when the browser becomes bigger and smaller. But the text of the state-label does not change so the text is either too big or too small depending on how the svg file scales.
I tried changing the text size by defining it as a percentage but that is just done off the base font size so if I make the font 400% so it is the right size it stays at 400% when I scale the image and it does not scale up or down with the image.
I don’t think this is possible with the current card. Also, you must be using this with the attribute panel: True under your view? Because typically these cards are not resized.
Yes I am using it with panel: true. I did that because I couldn’t get the card big enough to show the whole background image. Is there a way to specify the background image size so the whole thing will display? If I can make it the correct size for the primary display it will be used on and then I don’t need to worry about scaling. Although it would be pretty cool if I could get it to scale in the future.
Yeah, my comment is referring to the size of the card… not the size of the font. I think I overlooked the word ‘font’ when originally reading this post.
