I’m adding a camera to the frontend using the Lovelace Picture Entity Card but the documentation relating to aspect ratio seems to be incorrect.
The docs say that the aspect ratio should be a string, with examples being 16x9, 16:9 and 1.78, but the input type is set to number, and thus of the example values only 1.78 can be accepted, as you can’t type an x or : in the box.
If I enter 1.78, the image becomes really stretched horizontally:
You’re welcome to write up an issue or create a PR. Not sure what will come of it. Most of the documentation glosses over UI functionality. Mainly because the UI changes so much.
Hello, im having a similar issue…
The rtsp camera stream appears to be 4:3.
I place aspect_ratio: 16x9 by clicking the relevant {} button but that affects only the entity card and not the actual steam which remains 4:3 when i click on the card.
How can i force aspect ratio 16:9 to the stream hassio shows and not only the card?
