Maybe we talk past each other.
Default config path for Ubuntu 18 is /home/homeassistant/.homeassistant/{$configfiles}
Once I create the www folder, I still can’t access the files. Permissions are set and owner is homeassistant Is there a documentation for that?
After much mucking around, putting files into the config www folder, and them not showing up when called, I found an answer. Check the capitalisation on your file extension. If the file extension is saved in caps, then you have to call it in caps!
I have a fplan1.png file in the directory /home/pi/homeassistant/config/www/fplan1.png
but it wont display in homeassistant
in a browser i enter http://ipadd:8123/local/fplan1.png but it comes back with 404 file not found. ( ha rasbian image running in docker)
short and beautifull … should be added somewhere in all those tiles cause I had suffered a lot from that and I was going crazy why the script were not working.
