I also tried picture-elements card, but no luck…
are you using docker ? I strongly feel it has to do something with docker and permissions associated to it… It looks like, HA is not able to find image…
I think sota is right. The image should be in a www directory in your config folder. If you need to create www you will have to restart home assistant. The www folder is referenced as /local you can create any structure under that you like.
Yes… That’s it !!! It works by adding “www” folder, which is getting referenced as “local”. Thanks all. Shouldn’t the documentation be updated accordingly…
To make it clear for people just coming from Google:
Files need to be mounted into the container’s /config/www so they can be served on /local
Example:
That statement is not entirely truthful. I have migrated my HA installation from a MacMini running HA core to a Docker Container installation on a QNAP NAS. My Audi Connect integration works on both, but the picture image referenced to in the picture element is ONLY visible on the HA running as vore on the Mac. On Docker it is simply just a grey background.
The path I use is /local/pictures/AudiA4Allroad.jpg, and the jpg-file is located in config/www/pictures/. Re-starting HA, changing language as described above makes no difference.
