šŸŽ§ Lovelace Podcast Card/Plugin for gPodder
The component seems broken in 0.91.3. I got a custom_updater for a new version and when I restarted HA it wonā€™t load gpodder and I canā€™t restart again as it comes up with a config error. Comment out gpodder and all is well validation wise.
Does this work with the older ā€˜statesā€™ UI also or do you need to use the card for this to be functional?
Itā€™s a lovelace card so it wonā€™t work with states.
@Codec303 the component is what it is. You COULD access the data in a template sensor or use it an automation/script, but seems overly complicated. It was made with the custom LL card in mind.
Ok, thanks. Iā€™ll have to try it with Lovelace first before doing anything else. I mainly use Tileboard as my UI now but this looks like a really handy component. :slight_smile:
Hey Ianā€¦ any way to see older podcasts? Seems to only show last 5.
I have it hardcoded to 5 for now. It was a rush job getting this one out. Will eventually circle back and add more options and features. Just need to find the time :stuck_out_tongue_winking_eye:
Iā€™ve installed all like the docs tell, all works fine but I donā€™t see my podcast entries.
Thereā€™s also no error about gpodder that shows up in the logs.
Any idea how I could debug?
This is the config for it in ui-lovelace.yaml :
resources:
  - url: /local/podcast-card.js?v=0
    type: module
  - url: /local/mini-media-player-bundle.js?v=1.1.3
    type: module
  # View tab title.
  - title: Home
    icon: mdi:home-assistant
    cards:
      # The markdown card will render markdown text.
      - type: markdown
        title: Lovelace
        content: >
          Welcome!
      - type: custom:podcast-card
        entity: sensor.gpodder
        default_target: media_player.kodi
        show_player: True
        custom_player: True
and this in configurations.yaml :
gpodder:
  username: !secret gpodder_username
  password: !secret gpodder_password
    - enabled: true
      device: homeassistant
under the states icon thereā€™s
[sensor.gpodder] (state) 0
podcasts:
friendly_name: gPodder
icon: mdi:headphones
the used password has special chars in it and is in secrets.yaml with double quotes.
on gpodder.net I can see my podcasts under ā€œPodcast Subscriptionsā€ā€¦
hi;
at gpodder site while you sub a podcast there are devices. i created a hassio device and i sub with that device. it should be the same at your config.
    - enabled: true
      device: hassio
I can not trigger my clementine player to play as i click the podcastā€™s link.
:frowning:
When you go to Subscriptions -> Devices -> Your defined device used in HA do you see your subscriptions
e.g.
Itā€™s just a standard media player service call. Any errors in the browser console or your HA logs?
http://hassio.local:8123/lovelace/0:0:0 Uncaught all i see at the log
Just curious as to why I am getting this error via gPodder? ā€œERROR (MainThread) [custom_components.gpodder] Could not update data - HTTP Error 403: Forbiddenā€
I have two subscriptions added currently and it works fine (HA and one other), but when I try to more subscriptions it will create the above error and subsequently I lose the podcast-card from the front end.
Is this a known error?
The subscriptions I add can be played elsewhere.
Thanks for great addon. It would be awesome to get more than 5 podcasts available, as in gPoderr there are +100 new podcasts in lists. :slight_smile:
Is there an option to add more than one media_player to choose from?
Click on the speaker group icon to see a list of more media players to set as a target. Iā€™ll have to look back at the code for the 5 limit. Donā€™t remember if it was the card or component
Update this line
With the number of episodes you wish to show
Anyone having issues with podcasts with special characters, give this version a try: https://gist.github.com/iantrich/d243d08d48c37d6ed05207ef16cb0bac
Anyone getting this error trying to play their podcasts through a Sonos
"2019-08-23 11:11:26 ERROR (SyncWorker_8) [homeassistant.components.sonos.media_player] Sonos does not support a media type of ā€œaudio/mpegā€
I am running 0.98beta
