Ian are you going to fix the āerror inside the event loopā error?
itās not a high priority for me at the moment
Does it need gpodder? Anyone using it without gpodder (no cloud), e.g. 100% local podcast subscription?
More errors with 0.110.2
2020-05-27 10:10:58 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for gpodder doing I/O at custom_components/gpodder/__init__.py, line 107: urls = hass.data[DOMAIN]["client"].get_subscriptions(device)
2020-05-27 10:10:59 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for gpodder doing I/O at custom_components/gpodder/__init__.py, line 107: urls = hass.data[DOMAIN]["client"].get_subscriptions(device)
2020-05-27 10:10:59 ERROR (MainThread) [custom_components.gpodder] Could not update data - 500
2020-05-27 10:10:59 ERROR (MainThread) [homeassistant.components.sensor] gpodder: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 322, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 470, in async_device_update
await self.async_update()
File "/config/custom_components/gpodder/sensor.py", line 27, in async_update
await update_data(self.hass, self._device)
File "/config/custom_components/gpodder/__init__.py", line 110, in update_data
hass.data[DOMAIN_DATA] = update_using_feedservice(urls)
UnboundLocalError: local variable 'urls' referenced before assignment
2020-05-27 10:11:01 WARNING (MainThread) [homeassistant.helpers.entity_component] Forced update failed. Entity sensor.alarm_triggers not found.
GitHub is the place to report bugs. That being said, I donāt anticipate working on this anytime soon. Iāve got a lot on my plate at the moment. Hopefully someone in the community can submit a PR.
I have reported it there.
Understood. Iāll just delete it for now.
Still fairly new to HA and I really like this plugin. Is there a way to configure the plugin so I can choose which source I would like the podcast to play on within the card? I currently have a card for each speaker, but this isnāt ideal.
Click on the speaker icon
Nice! Thanksā¦ the problem was/is the speaker icon isnāt displaying, but clicking on the area where the icon should be shows my speaker options.
ah, yeah core changed that icon type to dynamically load. Iāll see if I can do a quick patch tonight.
Fixed in 1.1.0
Version 2.0.0: Breaking Change: Move to UI
With this update, YAML configurations are no longer supported and the integration has moved to being configured via the UI
Hi
What does this mean ? I cant see anything in HA and have upgraded to version 2 in HACS
What do I need to do please ?
Thanks Martyn
As I noted right above, it is a breaking change. Remove the YAML configuration and add it via the UI
Hi
Just guessed afterwards it maybe in Integrations.
Just installed and removed the old yaml and rebooted and still nothing in sensors or names gpodder in developer tools. No entities.
You have to make sure the name is in the same format as the one registered on gpodder.
All working now.
Martyn
I also had an issue with getting the entity of sensor.gpodder to work and just wanted to report back what my problem was as it cost me some hours to figure it out. It might help someone else!
you need to use your username, NOT the email address for the credentials in gpodder. Seems obvious, but still!!
My intention is to create an automation that will play a different podcast each morning and hope that your plugin will be helpful with this!!! Thank you!
Where i add the usernameās gpodder?
I just istall gpodder with hacs, then i add the following, with manual card:
type: ācustom:podcast-cardā
entity: sensor.gpodder
default_target: media_player.office_home
show_player: True
custom_player: True
I have āEntity not available: sensor.gpodderā
I do not know what to do more, reinstall the gpodder on hacs?
Hi
How did you get the source to be 2 echos or dots ?
Cant fathom how.
Martyn
Hi
I have everything set up. I have the gpodder account and can see all my subscribed podcasts but how do I play them on any of the echoās or dots I have around the house.
I have alexa media and Mini Media player installed from HACS but something is not quite right ?
I also cant TTS anything either.
Any help would be appreciated
Martyn
I am running into the same issue. Did you find a resolution?
