PostNL Integration
+1 for DHL.
I did find one but not sure it will work GitHub - glance-/dhl: A custom_component for home-assistant to track DHL packages via their api.
/edit
I was unable to create a API key for the Dutch Parcel EU API, submitted a ticket to support.
Really awesome that you guys got it working! :slight_smile:
Does anyone know how to get rid of specific text + icons in the lovelace card ?
( I marked it red in the screenshot below ) TY!
EDIT : Found it already in the CSS. :slight_smile:
dashn
Can you share code?
Yes ofcourse.
In the postnl-card.yaml:
Find the CSS for the Header ( Removes the Header & title ) and or Info ( removes the icons/counter )
And change/add the code: display: none;
In my case, it looks like this:
          header {
            display: none;
            flex-direction: row;
            align-items: center;
            font-family: var(--paper-font-headline_-_font-family);
            -webkit-font-smoothing: var(
              --paper-font-headline_-_-webkit-font-smoothing
Looking at the DHL app, this should be easy. They use a simple POST call to my.dhlparcel.nl/api/user/login with the username and password. The response headers include two cookies (access_token and refresh_token) which are JWT tokens.
https://my.dhlparcel.nl/receiver-parcel-api/parcels returns all parcels.
https://my.dhlparcel.nl/receiver-parcel-api/track-trace?key={TT_CODE}%2B{ZIPCODE}&role=receiver will return the details.
I try to avoid DHL as much as possible, so I am not really able to properly build and test a new version of the integration.
I created a beta release (11.2.0 beta 1). In this release I try to solve an issue which I encountered a couple of times. Sometimes the PostNL API doesn’t return any data (5xx error) or is unreachable. This will break the sensor and therefor the lovelace. I try to solve this by adding a retry strategy. I also changed the behaviour in retrieving data (using async now). This will improve the start time of the integration.
Please test the beta release and let me know if there are (no) issues :smile: .
Does this addon includes the ‘specific time block’ wherein the delivery will take place?
Would be great to get a notification every 20 minutes or so when the timerange updates.
If there is an expected delivery date and time, then this data is added to the delivery data. However, the original lovelace does not show this data. I forked the lovelace and changed the code. In my HA env I can see the data.
You need to do some template magic if you want to create an automation.
Is it true you cant find it in HACS anymore?
Couldnt find it in integration and frontend.
First off all great work, but…cant get the lovelace to work.
My resource.yaml:
- url: local/community/lovelace-postnl-card/postnl-card.js
  type: module
Full file path:
…/homeassistant/config/www/community/lovelace-postnl-card/postnl-card.js.
I have got a lot off lovelace resources that working well.
What am I overlooking?
Dit mag best wel pupbliekelijk gedeeld worden hoe ik het voor elkaar heb gekregen:
\custom_components\postnl: GitHub - iMicknl/python-postnl-api: Python wrapper for the PostNL API, a way to track packages using their online portal.
Browser Extention: GitHub - arjenbos/ha-postnl: Custom PostNL Home Assistant integration
Card \www\postnl-card.js: GitHub - peternijssen/lovelace-postnl-card at 0.12.2
Resource path: /local/postnl-card.js as Javacscript Module
Please respond in English, this is an English-speaking forum. If it’s easier for you, use google translate or something similar.
Can you describe it more detailed please how you did this? Because I got the postnl integration from arjenbos working but the letters entity is not in there. So how did you solve this with the python api wrapper? Please a short step-by-step procedure would be awesome!
On Gihub you closed my ticket with the message its should not working in HA anymore but, my entties does get information which seems to be accurate
This is not PostNL related, but since we discussed DHL earlier I thought I should share some findings here.
Long story short, I got my DHL packages which are on the way available within Home Assistant through the multiscrape component.
So far it has been running for almost 24 hours and I haven’t seen any issues yet. As my package meanwhile got delivered, I can’t garantuee that it works flawlessly though.
The only issue that is present is whenever you (re)start home assistant, the sensor might be unavailable, but becomes available after reloading the multiscrape configuration.
This is my multiscrape setup. Replace YOUR EMAIL and YOUR PASSWORD with your credentials.
It might also work with the default rest integration. Haven’t tried that.
multiscrape:
  - resource: "https://my.dhlecommerce.nl/api/user/login"
    scan_interval: 3600
    method: "post"
    headers:
      Content-Type: "application/json"
    payload: '{"email":"YOUR EMAIL","password":"YOUR PASSWORD"}'
  - resource: "https://my.dhlecommerce.nl/receiver-parcel-api/parcels"
    scan_interval: 3600
    method: "get"
    headers:
      - unique_id: dhl_packages
        name: DHL Pakketten
        value_template: "{{ value_json.parcels | selectattr('category', 'search', '(PROBLEM|CUSTOMS|DATA_RECEIVED|EXCEPTION|INTERVENTION|IN_DELIVERY|LEG|UNDERWAY|UNKNOWN)') | list | count }}"
        attributes:
          - name: parcels
            value_template: "{{ value_json.parcels | selectattr('category', 'search', '(PROBLEM|CUSTOMS|DATA_RECEIVED|EXCEPTION|INTERVENTION|IN_DELIVERY|LEG|UNDERWAY|UNKNOWN)') | list }}"
And this is my lovelace configuration for displaying a table of all packages on the way from either PostNL or DHL:
      - type: conditional
        conditions:
          - condition: or
            conditions:
              - condition: "numeric_state"
                entity: sensor.postnl_delivery
                above: 0
                entity: sensor.dhl_packages
                above: 0
        card:
          type: markdown
          card_mod:
            style:
              ha-markdown$: |
                table {
                  width: 100%;
                thead {
                  font-weight: bold;
          content: |
              <table>
              <thead>
                <tr>
                  <td>Bezorger</td>
                  <td>Pakket</td>
                  <td>Datum</td>
                  <td>Tijd</td>
                </tr>
              </thead>
              <tbody>
              {% for package in state_attr('sensor.postnl_delivery', 'enroute') %}
                {% if package.planned_date is not none %}
                <tr>
                  <td>PostNL</td>
                  <td>{{ package.name }}</td>
                  <td>{{ as_timestamp(package.planned_date) | timestamp_custom('%-d %b') }}</td>
                  <td>{{ as_timestamp(package.planned_from) | timestamp_custom('%H:%M') }} - {{ as_timestamp(package.planned_to) | timestamp_custom('%H:%M') }}</td>
                </tr>
              {%- endfor %}
              {% for package in state_attr('sensor.dhl_packages', 'parcels') %}
                {% if package.receivingTimeIndication is not none %}
                <tr>
                  <td>DHL</td>
                  <td>{{ package.sender.name }}</td>
                  <td>{{ as_timestamp(package.receivingTimeIndication.start) | timestamp_custom('%-d %b') }}</td>
                  <td>{{ as_timestamp(package.receivingTimeIndication.start) | timestamp_custom('%H:%M') }} - {{ as_timestamp(package.receivingTimeIndication.end) | timestamp_custom('%H:%M') }}</td>
                </tr>
              {%- endfor %}
              </tbody>
              </table>
Tried it here, but it’s one of those days there are no packages for me. So I have to make the wife order something :smiley:
Be carefull, what you wish for… :stuck_out_tongue:
LoL, it’s not a wish, I know it will happen! :smiley:
So you dont make her to order, she will do it anyway :joy:
Of course risking to deviate too much from the PostNL integration (thanks!), I am struggling in getting the DHL code you posted to work.
I get the following errors:
Scraper_noname_1 # Updating failed with exception: Client error '403 Forbidden' for url 'https://my.dhlparcel.nl/receiver-parcel-api/parcels' For more information check: https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/403
Scraper_noname_0 # Updating failed with exception: Client error '401 Unauthorized' for url 'https://my.dhlparcel.nl/api/user/login' For more information check: https://developer.mozilla.org/en-US/docs/Web/HTTP/Status/401
Did DHL change something on their end? Or should I have a business account?
