Lovelace: PostNL
This is great @ptnijssen . For step 1, is the pull request good enough?
For step 2: Who can do this? I unfortunately have not enough experience in coding.
Great progress!
Mart
I am not sure, depends if PostNL changed their API a lot. Someone has to check. Perhaps the original author of the library is interested in updating his library and creating a component for HA. My time is unfortunately limited to pick this up.
Just to let you know that we can probably expect a component back at one point. Just giving the original author of the library time to get everything up and running. Keep track of progress here;
So please be patient :slight_smile:
Nice work. Hope it’ll be merged soon. I will give it another shot
Sorry, but I have tried that PR last week and does not work (anymore)
Let’s hope this will be picked up by @ptnijssen or Mick :slight_smile:
I see that the toon has now implemented a fix for the login issue @ptnijssen
Can we re-use this?
Looking in to it
That actually does not fix it. At least not when I run the script.
With a couple of adjustments it sticks at step 5:
Alright, thanks for checking!
At toon it does work. Let’s see what the devs think.
Dev discussion can be tracked here: Fix for issue: #20 by 0x00-0xFF ¡ Pull Request #22 ¡ iMicknl/python-postnl-api ¡ GitHub
Is er toevallig nog nieuws te melden?
Hi all, I reached out to PostNL (again) and they informed me they are actively working on a public api. They gave me this URL, but it is behind a (okta) login (so much for “public”):
https://jouw.postnl.nl/online-versturen/swagger
I noticed that the following URL is also behind the same URL, so I expect we should be able to use this endpoint to track parcels instead of using the API to send parcels:
https://jouw.postnl.nl/track-and-trace/swagger
I already tried the “forgot password” option, but it seems my “jouw postnl” account is not valid. I’m reaching out to them again to check whether a special account or specific permissions are required.
Anyone else any luck?
No luck, but this could be promising!
Now just do what we have been doing for a while now:
I’m not a developer, but are we looking for something like this?
You have to pay for this. This is for company’s.
Is er al iets mogelijk om PostNL te gebruiken :face_with_raised_eyebrow: :grimacing:
Hi
Ant news on this?
Found noderedflow for notifications PostNL notification (for Home Assistant) ¡ GitHub
Does this help in reviving this card?
Even a Nodered flow requires acces to the PostNL api and that’s exacly what Postnl doesn’t provide…
Still sad that PostNL doesn’t provide a public API to use. Hopefully something will change in the future.
