Lovelace randomly unresponsive after installing MQTT
Yesterday I flashed a Tuya plug with Tasmota for the first time and installed the mosquito MQTT broker in Home Assistant. Everything seemed to work fine but I’ve noticed that now and then Lovelace becomes unresponsive (for example, if I turn a light on, the light turns on but Home Assistant shows the light off and Lovelace becomes unresponsive). Closing and reopening the app usually fixes the problem. At home we use the iOS and Android apps and it has happened in both. It seems to be a random problem and the logs don’t show any errors. I wonder if it is a configuration problem (I’m quite newbie at this) or a power problem, as I’m using a raspberry pi 2 for HA. Does Mosquito use a lot of resources? I would appreciate any help or guidance on how to find/debug the problem.
