Is there an example of the values that are needed in config.ini anywhere? Struggling to understand where I would find the correct values to enter into my file eg:
- base_topic - where do I find this?
- hostname - is this the url for my homeassistant? which port do I also specify? mosquito has several (normal mqtt, mqtt over websocket, normal mqtt with ssl, mqtt over websocket with ssl)
also, can I add these anywhere in the config, or do they need to be under a specific heading (daemon,mqtt, commands)
