šŸ’” Lovelace: RGB light card
I still believe it’s better if you paste the code with your indentation :slight_smile:
It’s quite odd, because as far as I know you can use the same condition multiple time, that’s why I think you have the second condition inside the first (due to indentation), or something like that :slight_smile:
          - type: conditional
            conditions:
              - entity: light.studio_andrea_light
                state: "off"
            card:
              type: entities
              show_header_toggle: false
              entities:
                - type: 'custom:slider-entity-row'
                  toggle: true
          - type: conditional
            conditions:
                state: "on"
            card:
              type: entities
              toggle: false
              entities:
                  toggle: true
                - type: 'custom:rgb-light-card'
                  colors:
                    - rgb_color:
                      - 255
                      - 255
                      - 255
#                      brightness: 255
                      icon_color: '#FFFFFF'
                    - rgb_color:
                      - 51
                      - 102
                      - 204
#                      brightness: 255
                      icon_color: '#3366CC'
                    - rgb_color:
                      - 51
                      - 204
                      - 51
#                      brightness: 255
                      icon_color: '#33CC33'
                    - rgb_color:
                      - 255
                      - 0
                      - 255
#                      brightness: 255
                      icon_color: '#FF00FF'
What happens is that since there are 10 spaces before the first - on the first line is says Cannot read property ā€˜setConfig’ of undefined as seen here:
Ok so I tried to go through it again just for a screenshot and it didn’t give me the duplicate error. Maybe I deleted the - in front of conditional last time.
Either way now it just keeps the error in the above screenshot.
It might be that you don’t have the same light as I do, I can still see in your code light.studio_andrea_light
That needs to be your entity name for the light, if the entity doesn’t exists might be the reason why it returns you an error.
I very seriously doubt that’s it.
Usually it will just show an entity not available like the following when I copied VGE’s code in the same way:
Do you use the editor for lovelace or are you all yaml?
I’m not a programmer and I’m terrible at the spacing requirements.
That’s why I get stuck in situations like these.
Thanks for trying to help!
I use YAML.
But keep in mind, that if you put a condition on an entity that doesn’t exists the whole conditon might return an error, so I would put instead of my entity one of yours, just to give it a try :slight_smile:
Well I tried. I did a find and replace with the entity I’m trying to use and same thing.
I didn’t capture it in the screenshot above, but it actually says ā€œno card type foundā€ in the red section on the right. Strange.
I’m sure it is something simple, but I just can’t find it for now.
Thanks again for trying.
Have you installed the slider-entity-row and the rgb-light cards?
Did you forget the type parameter?
Yes and yes.
In fact I can get both to work in the same card. I can even get one conditional to work, but when I get to the second one it just complains about the duplicate.
Do you mean for the card?
Like: - type: 'custom:rgb-light-card'
it is in there.
Here is the last one I did with my own entity and trying to conform to the editor:
- type: conditional
  conditions:
    - entity: light.hue_color_light_1
      state: "off"
  card:
    type: entities
    entities:
        toggle: true
- type: conditional
  conditions:
      state: "on"
  card:
    type: entities
    toggle: false
    entities:
        toggle: true
        colors:
          - rgb_color:
            - 255
            - 255
            - 255
            brightness: 255
          - rgb_color:
            - 51
            - 102
            - 204
            brightness: 255
          - rgb_color:
            - 51
            - 204
            - 51
            brightness: 255
          - rgb_color:
            - 255
            - 0
            - 255
            brightness: 255
It is just a copy of the above with my entity replaced and slid to the left about 10 characters.
Did you use the ā€œtabā€ key to create the space?
Does it work if you add these 2 lines to the top:
type: vertical-stack
cards:
  - type: conditional
  conditions:
      state: "off"
  card:
      type: entities
      entities:
          toggle: true
  - type: conditional
  conditions:
      state: "on"
  card:
      type: entities
      toggle: false
      entities:
          toggle: true
          colors:
          - rgb_color:
              - 255
              - 255
              - 255
              brightness: 255
          - rgb_color:
              - 51
              - 102
              - 204
              brightness: 255
          - rgb_color:
              - 51
              - 204
              - 51
              brightness: 255
          - rgb_color:
              - 255
              - 0
              - 255
              brightness: 255
Just make sure to mantain your code as you have because the one above look not correctly ā€œallignedā€ :slight_smile:
More like this:
cards:
  - type: conditional
    conditions:
        state: "off"
    card:
      type: entities
      entities:
          toggle: true
  - type: conditional
    conditions:
        state: "on"
    card:
      type: entities
      toggle: false
      entities:
          toggle: true
          colors:
            - rgb_color:
              - 255
              - 255
              - 255
              brightness: 255
            - rgb_color:
              - 51
              - 102
              - 204
              brightness: 255
            - rgb_color:
              - 51
              - 204
              - 51
              brightness: 255
            - rgb_color:
              - 255
              - 0
              - 255
              brightness: 255
Yes, copy pasting messed that up
Okay I copied it before the last couple of posts and did mess with it to get spacing better and now it works!
Thanks to all who helped!
This is what I ended up with working in case anyone else ever has this issue:
cards:
  - type: conditional
    conditions:
        state: 'off'
    card:
      type: entities
      entities:
          toggle: true
  - type: conditional
    conditions:
        state: 'on'
    card:
      type: entities
      toggle: false
      entities:
          toggle: true
          colors:
            - rgb_color:
                - 255
                - 255
                - 255
              brightness: 255
            - rgb_color:
                - 51
                - 102
                - 204
              brightness: 255
            - rgb_color:
                - 51
                - 204
                - 51
              brightness: 255
            - rgb_color:
                - 255
                - 0
                - 255
              brightness: 255
@bokub Size works like a charm. I find 30 to be perfect for mobile use.
Is it possible to add ā€œwhite_valueā€ to a preset color? I have an RGBW light, so RGB + white_value (0-255).
As said in the documentation, this card supports all the options of the light.turn_on service, because the card actually calls the light.turn_on service.
Therefore, white_value is supported
How would look configuration for only ā€œwhiteā€ LED stripe.
For RGB all is working fine, but my goal is also to make some ā€œdimmingā€ preset, so that you would only set brightness value, and night mode.
