๐Ÿ’ก Lovelace: RGB light card
Hi everyone !
I'd like to show you my new Lovelace custom card dedicated to RGB lights :purple_circle::orange_circle::green_circle:
The goal is to quickly switch between different presets of color / brightness with a minimalist UI
:memo: Don't hesitate do give me your feedback and suggestions to improve it !
Preview
Installation & Configuration
Please visit the GitHub repository for a detailed documentation and examples
( and add a :star2: if you like it ! )
Beautiful, is this customizable (as in colors?).
If yes I will incorporate this into my setup!
It is very customizable yes !
Check out the documentation to see the examples
The github link is wrong. It points to the screenshot :wink:
Oooops ! Thank you, itโ€™s fixed
Great idea and good work!! :+1: I will integrate this in my :bulb: setup today.
That itโ€™s very nice!
Would be possible to have it integrated with HACS?
Thanks!
Andrea
Yes ! The request is being reviewed
Great, will be waiting till its added tot HACS but it looks great and is a very cool addition.
Is this also possible for (light) groups?.
Each icon simply call the service light.turn_on with your own parameters
The light.turn_on service works for lights groups, so the answer is yes !
Itโ€™s done ! Click the โ€œRELOAD DATAโ€ button in your HACS settings, and the plugin should appear after a few minutes !
@VGE @SeLLeRoNe
Looks freaking awesome:
afbeelding
Is there anyway to get ride of the light entity and just show the colour options?
Sure !
The light entity isnโ€™t part of the lovelace card and is on the screenshots only as an example.
However, the custom card must be included in a โ€œentitiesโ€ card
type: entities
entities:
    - type: 'custom:rgb-light-card'
      entity: light.example_light
      colors: [...]
Thanks, looks great by the way - I was definitely missing this from the front end.
Would you mind sharing the code to also have the brightness control as you have?
Thanks .)
I guess @VGE uses this custom component
So it would be something like
type: entities
entities:
  - type: 'custom:slider-entity-row'
    toggle: true
    colors: [...]
Well yes and no (I did know about that card, but thatโ€™s something slighly different), because that way it show two lights entities while he is somehow mixing the two
Nevermind, I found what was my issue :slight_smile:
