Just thought I would share my rocket view using https://github.com/djtimca/harocketlaunchlive and the custom lovelace https://github.com/thomasloven/lovelace-template-entity-row
This streamline the info into a simple view.
Come-on, it is for rocket launches…where is the countdown timer??
Seriously, this is nice.
Does the ‘month-year’ indicate that the launch date has not been set and only a launch window is available?
Correct . It also use the flags within HA Rocket launch live to state if the lauch is now ( within the hour) or Today
state: >
{% if states.sensor.rocket_launch_1.attributes.launch_20m_warning == ‘true’ %}
Now
{% elif states.sensor.rocket_launch_1.attributes.launch_24h_warning == ‘true’ %}
Today
{% else %}
{{states.sensor.rocket_launch_1.attributes.launch_date_target}}
{% endif %}
Great! Thanks for your time. Works like a charm!
That does look nice.
Does the countdown start at 24 hrs?
Obviously my comment about the timer was not challenging enough. Now for a challenge, change the icon to the respective live camera feed upon start of countdown timer. Unfortunately I have no idea where you can get this data from one place.
It would be nice if this was in HACS so the updates (for the card and integration) were polled automagically.
Thanks for your comments.
None of this is my work. Im just manipulating the data from rocket live launch that is in HACS . There are a couple attributes
sensor.rocket_launch_1.attributes.launch_24h_warning this give the 24 hour warning. I test for this and then use the sensor.rocket_launch_1.attributes.launch_target_timestamp this is the lauch time and date, I just subtract this from the current time.
I then use another HACS addon to display it nicely.
There is a attribute Launch media link which could do what you want, but it does not apper to be populated, Install the rocket live addon and have a play
Made a minor update to highlight next launch
title: Rocket
path: rocket
icon: 'mdi:rocket-launch'
badges: []
cards:
- type: grid
title: Rockets
columns: 1
square: false
cards:
- type: entities
entities:
- type: custom:template-entity-row
entity: sensor.rocket_launch_1
icon: mdi:rocket-launch
state: >
{% if states.sensor.rocket_launch_1.attributes.launch_24h_warning == 'true' or
states.sensor.rocket_launch_1.attributes.launch_20m_warning == 'true' %}
{% set time = states.sensor.rocket_launch_1.attributes.launch_target_timestamp|float - as_timestamp(utcnow()) %}
{% set hours = ((time % 86400) // 3600) %}
{% set minutes = ((time % 3600) // 60) %}
{% if states.sensor.rocket_launch_1.attributes.launch_24h_warning == 'true' %}
{{hours|int}} hrs {{minutes|int}} mins
{% endif %}
{% if states.sensor.rocket_launch_1.attributes.launch_20m_warning == 'true' %}
{% endif %}
{% else %}
{% endif %}
secondary: >
{{states.sensor.rocket_launch_1.attributes.provider}}
{{states.sensor.rocket_launch_1.attributes.vehicle}}
entity: sensor.rocket_launch_2
state: >
{% if states.sensor.rocket_launch_2.attributes.launch_24h_warning == 'true' or
states.sensor.rocket_launch_2.attributes.launch_20m_warning == 'true' %}
{% set time = states.sensor.rocket_launch_2.attributes.launch_target_timestamp|float - as_timestamp(utcnow()) %}
{% if states.sensor.rocket_launch_2.attributes.launch_24h_warning == 'true' %}
{% endif %}
{% if states.sensor.rocket_launch_2.attributes.launch_20m_warning == 'true' %}
{% endif %}
{% else %}
{{states.sensor.rocket_launch_2.attributes.launch_date_target}}
{% endif %}
secondary: >
{{states.sensor.rocket_launch_2.attributes.provider}}
{{states.sensor.rocket_launch_2.attributes.vehicle}}
entity: sensor.rocket_launch_3
state: >
{% if states.sensor.rocket_launch_3.attributes.launch_24h_warning == 'true' or
states.sensor.rocket_launch_3.attributes.launch_20m_warning == 'true' %}
{% set time = states.sensor.rocket_launch_3.attributes.launch_target_timestamp|float - as_timestamp(utcnow()) %}
{% if states.sensor.rocket_launch_3.attributes.launch_24h_warning == 'true' %}
{% endif %}
{% if states.sensor.rocket_launch_3.attributes.launch_20m_warning == 'true' %}
{% endif %}
{% else %}
{{states.sensor.rocket_launch_3.attributes.launch_date_target}}
{% endif %}
secondary: >
{{states.sensor.rocket_launch_3.attributes.provider}}
{{states.sensor.rocket_launch_3.attributes.vehicle}}
entity: sensor.rocket_launch_4
state: >
{% if states.sensor.rocket_launch_4.attributes.launch_24h_warning == 'true' or
states.sensor.rocket_launch_4.attributes.launch_20m_warning == 'true' %}
{% set time = states.sensor.rocket_launch_4.attributes.launch_target_timestamp|float - as_timestamp(utcnow()) %}
{% if states.sensor.rocket_launch_4.attributes.launch_24h_warning == 'true' %}
{% endif %}
{% if states.sensor.rocket_launch_4.attributes.launch_20m_warning == 'true' %}
{% endif %}
{% else %}
{{states.sensor.rocket_launch_4.attributes.launch_date_target}}
{% endif %}
secondary: >
{{states.sensor.rocket_launch_4.attributes.provider}}
{{states.sensor.rocket_launch_4.attributes.vehicle}}
entity: sensor.rocket_launch_5
state: >
{% if states.sensor.rocket_launch_5.attributes.launch_24h_warning == 'true' or
states.sensor.rocket_launch_5.attributes.launch_20m_warning == 'true' %}
{% set time = states.sensor.rocket_launch_5.attributes.launch_target_timestamp|float - as_timestamp(utcnow()) %}
{% if states.sensor.rocket_launch_5.attributes.launch_24h_warning == 'true' %}
{% endif %}
{% if states.sensor.rocket_launch_5.attributes.launch_20m_warning == 'true' %}
{% endif %}
{% else %}
{{states.sensor.rocket_launch_5.attributes.launch_date_target}}
{% endif %}
secondary: >
{{states.sensor.rocket_launch_5.attributes.provider}}
{{states.sensor.rocket_launch_5.attributes.vehicle}}
@lonebaggie great solution, thanks a lot! Is it normal that I get on every HA start the following error:
2022-08-10 07:44:45.037 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'None' has no attribute 'attributes' when rendering '{% if states.sensor.rocket_launch_1.attributes.launch_24h_warning == 'true' or
{% endif %}
{% endif %}
{% else %}
{% endif %}'
anything I could do not to get this errors for each rocket sensor?
I suspect this is due to the time it takes to load the rocket launch live .
Check how long it takes rocket launch live to load ( info now buried in the repairs screen on the latest’s ver)
Unfortunately I no longer use this screen . I have standardised on a Custom button cards for my frontend. I modified the following from https://github.com/djtimca/harocketlaunchlive
