Nevermind i found it:
--mdc-icon-size: 50px;
I feel this may be a silly question but I just can’t figure it out.
How can I hide the last preset line of this card.
Add control
to your header config and delete “preset”.
Like:
control:
- hvac
See here:
Thanks for that however this remove both the Operation icons and the preset line.
I just want to remove the preset line
Try
control:
hvac: true
preset: false
If this doesn’t work, please post your config.
Ok new issue.
How can i remove P: at power sensor entity.
I can switch label with icon but i can’ remove it.
My current setup:
cards:
- control:
_headings: false
fan:
quiet:
icon: mdi:microphone-off
auto:
include: false
low:
icon: mdi:fan
normal:
icon: mdi:fan-speed-1
high:
icon: mdi:fan-speed-2
highest:
icon: mdi:fan-speed-3
hvac:
auto:
include: false
fan_only:
icon: mdi:fan-alert
entity: climate.air_condition
hide:
mode: false
temperature: true
state: true
sensors:
- entity: sensor.ac_power_current_consumption
decimals: 0
step_size: '1'
style: |
ha-card {
background: rgba(0, 0, 0, 0.06);
border-radius: 30px;
--st-spacing: 2px;
--primary-text-color: azure;
--secondary-text-color: azure;
--ha-card-box-shadow: 0px 0px 6px rgb(0, 0, 0);
--st-mode-background: rgba(0, 0, 0, 0.2);
--st-mode-active-background: purple;
--st-font-size-sensors: 40px;
--st-font-size-m: 50px;
--st-font-size-l: 50px;
ha-card .mode-item {
--st-spacing: 1px;
border-radius: 15px;
type: custom:simple-thermostat
header: false
layout:
mode:
names: false
headings: false
step: row
decimals: '0'
unit: °
- type: weather-forecast
entity: weather.home
style: |
ha-card {
--st-spacing: 0px;
--ha-card-background: rgba(0, 0, 0, 0.06); color: azure;
--secondary-text-color: #D0FF14;
type: horizontal-stack
Have you tried removing the “name” like so:
sensors:
decimals: 0
Yes i tried.
I just get ful name of entity instead.
I can’t leave it blank either(name:. )
It only work if i switch it with
icon: mdi:something
Yeah that kinda worked thanks.
There is still ( blank space): visible.
The reason i’m trying erase name:
Since i used:
I get this:
So icon and measurement are no longer aligned.
You can try inserting this line under style:|
.sensors.with-labels.as-table .sensor-heading {
display: none;
This is meant to prevent displaying the “name” or icon. However I’m not sure this will solve your alignment issue.
Yes! It worked!
Big thanks.
Thank this fix it
Hi, I just set up Infinitude to control my new Carrier Infinity system and am trying out both the simple thermostat card and the default HA one. Both work great except on the simple card I am not able to lower the setpoint, only raise (currently in Cool mode). On the HA thermostat card both raise and lower work fine.
Anyone else having this issue or am I missing something simple?
Looking for some advice on how to add some extra colour dynamically to the card. Currently when the thermostat is in auto the only way to tell if the system is calling for heat is by looking at “State: Idle (Auto) or Heating (Auto)”. It would be ideal if there was an extra visual cue such as orange/red colour. This could be on the icon in the top left, on the temperature text itself or somewhere else. Many thanks for any help in advance.
I simply use the switch that is controlled by the thermostat in the headers fault section.
- type: custom:simple-thermostat
entity: climate.wohnzimmer
version: 3
header:
icon: null
faults:
- entity: switch.eth008_eg_3
hide_inactive: true
What does the version
tag do? Haven’t seen that one in the documentation.
EDIT: nevermind, found it “hidden” on the example page!
Unfortuantely this won’t work for me I don’t think as I don’t have a binary switch like this. Thanks for the suggestion though!
Hey,
Is it possible to hide the temperature shift control arrows or +/-?
I love this card by the way!
