Hi all!
Since 0.75.0b0 there are special rows in the entities card
If i use the dividers and style them to my needs, there’s a lot of code to write/change in the ui-lovelace.yaml for every divider.
- type: entities
title: Switches
show_header_toggle: false
entities:
- switch.mcp23017_test_01
- switch.mcp23017_test_02
- switch.mcp23017_test_03
- switch.mcp23017_test_04
- switch.mcp23017_test_05
- type: divider
style:
height: 1px
width: 80%
margin-left: auto
margin-right: auto
background: '#62717b'
- switch.tpad_screen
- switch.tpad_vlc
- type: divider
style:
height: 1px
width: 80%
margin-left: auto
margin-right: auto
- switch.sg90_servo
- input_number.sg90_servo
Is there any way to define the styles globally, so i don’t have to edit every divider on change?
Thanks in advance!
dvd78
(Davide Micheluzzi)
August 1, 2018, 9:19pm
2
Hi, i’m running the same versione (beta) but i have problems with divider, could you help me?
my config is:
- type: entities
entities:
- switch.apertura_cancello_tmpl
- switch.apertura_ped_cancello_tmpl
- type: divider
style:
height: 1px
width: 80%
margin-left: auto
margin-right: auto
but got error “object at position 2 is missing entity field”
Looks like your indentation is wrong. Does this work without the divider?
ToMee
August 4, 2018, 12:24pm
4
Maybe this is the problem:
dvd78
(Davide Micheluzzi)
August 4, 2018, 1:04pm
5
it was the problem. this morning i tried also updating to new versione and it fixed.
than you guy
BullFrog
(BullFrog)
August 4, 2018, 4:52pm
6
Where is the exact documentation for divider? it says I can use CSS, yet I can’t use the same as I used for Hline:
width: 100
height: 1
backgroundcolor: white
bordertop: none
backgroundimage: linear-gradient(to right, rgba(0, 0, 0, 0.02), rgba(0, 0, 0, 0.15), rgba(0, 0, 0, 0.2), rgba(0, 0, 0, 0.22), rgba(0, 0, 0, 0.2), rgba(0, 0, 0, 0.15), rgba(0, 0, 0, 0.02))
The documentation is here and examples in the Gallery .
BullFrog
(BullFrog)
August 4, 2018, 5:25pm
8
It is a pretty deficient, i would not say it is a documentation. The gallery is a blank page for me, tried in different browsers.
Works for me in Firefox 61.0.1 on Ubuntu without issues.
The last line as code:
background: center / contain url("/images/divider.png") no-repeat
BullFrog
(BullFrog)
August 4, 2018, 6:16pm
10
BullFrog:
Okay this one works:
background: linear-gradient(to right, rgba(0, 0, 0, 0.02), rgba(0, 0, 0, 0.15), rgba(0, 0, 0, 0.2), rgba(0, 0, 0, 0.22), rgba(0, 0, 0, 0.2), rgba(0, 0, 0, 0.15), rgba(0, 0, 0, 0.02))
Simply shows nothing for me!
For this i’m asking in this topic!
mayker
(maykar (pronounced "maker" with a southern accent))
August 4, 2018, 6:58pm
14
There might be a better way to do it with input_text or something else, but you can do it with secrets.yaml
in secrets.yaml
divider:
height: 1px
width: 80%
margin-left: auto
margin-right: auto
in ui-lovelace.yaml
- type: entities
title: Switches
entities:
- type: divider
style: !secret divider
That’s nice
Thanks for this!
skalavala
(Mahasri Kalavala)
August 22, 2018, 10:05pm
16
Also, most folks use themes, and you can use the theme colors rather than hard coding colors inside your yaml. Here is a sample code:
- type: divider
style:
height: 3px
width: 100%
margin-left: auto
margin-right: auto
background: "var(--dark-primary-color)"
Specify the variable name instead of hard-coding the color value. It will then automatically pickup the color from the theme and apply it.
For those who use themes, you can pickup names from here: https://github.com/skalavala/smarthome/blob/master/packages/frontend_themes.yaml
renemarc
(René-Marc)
March 13, 2019, 2:01am
17
OP asked a while ago, but this maybe of use to you, dear reader from the future!
You can also use YAML anchors . This way you only define the first divider’s style once (÷r_style
), then paste the placeholder name (*divider_style
), like so:
- type: entities
title: Switches
entities:
- type: divider
style: ÷r_style
height: 1px
width: 80%
margin-left: auto
margin-right: auto
- switch.tpad_vlc
- type: divider
style: *divider_style
- switch.sg90_servo
To keep things tidy, you could even define these styles as dummy custom YAML entries at the top of your file (outside of the Lovelace views section), then apply them wherever you need:
styles:
divider: ÷r_style
height: 1px
width: 80%
margin-left: auto
margin-right: auto
- title: switchboard
cards:
- type: entities
title: Switches
entities:
- type: divider
- switch.tpad_vlc
- type: divider
- switch.sg90_servo
Best thing I found today!
