Lovelace: Sun Card
I tried this configuration too… no success
type: 'custom:sun-card'
entities:
  time: sensor.time
  moon_phase: sensor.moon
  sunrise: sensor.sunrise
  sunset: sensor.sunset
style: |
  ha-card {
    --sc-sunbeam-color: blue;
    --sc-sun-color: green;
    --sc-horizon-color: orange;
animation: true
meridiem: false
Has something changed with the HACS install? I get a “Repostitory structure for v5.0 is not compliant” error when trying to add this github as a repo.
set the Category to ‘Lovelace’
Oh! That was kind of obvious, in retrospect. Thanks!
Hi all. I’ve made ha checking before upgrade to 2021.5.1
The result is an error on platform: sun2
I don’t have upgraded HA yet
Do you have any advice?
Did you bother checking if sun2 has been updated?
Hi David,
I’ve the 5.0 Version
It’s the last, I suppose
this is the reported error
Failed config
General Errors:
- Platform error sensor.sun2 - cannot import name ‘AstralError’ from ‘astral’ (/usr/local/lib/python3.8/site-packages/astral/init.py)
You are probably confusing the card with the component. The latest version of sun2 is version 2 and it was specifically released for the change in HA.
You are right David
I had not seen that there was an upgrade to 2.0 of the component.
I have now updated all documents in Custom_component
Thanks very much.
I’m checking now for the HA upgrade.
I’ve now proceed to 2021.5.1 upgrade without problems
Just to note there is a ‘Sun Card’ in the HACS directory (I think).
Perhaps this should be renamed to sun2-card to avoid conflict?
Both cards have their pros and cons.
Is this Project still in development? Latest files on github are from 17 Jun 2020.
I need help to get this working in synology dockercontainer.
Installed with this tutorial: https://mariushosting.com/how-to-install-home-assistant-on-your-synology-nas/
Now i want to manually install the files, but the mentioned folders/pathes are not here.
any advice/tutorial how to install within docker?
thx
Synology DSM 7.1.xxx with Home Assistant 2022.8.6
I agree with @baz123 !
Is it possible to rename it?
I’m having problems with the two cards because they conflict
