@ASNNetworks you work wonders my friend. Thank you. I now have it implemented but how do you center the title text and give it less padding so that the bottom boxes line up with the shopping list?
Hi, if you changed the title using grid card, I think the only way to change that is by using card-mod. I donāt use that myself though, so canāt help you with the correct code. If that doesnāt work as neat, I would just use my first code with your mushroom-template-cards as titles in vertical-stacks I created. Both codes work, while the first one will give you the titles as you had with mushroom
If you already use your mushroom-template-card then best thing is to ask in that topic how to mod that card to align/center the text and remove padding. Itās all possible, but most likely you need card-mod.
There is a post with a lot of examples how to use card-mod:
Card-mod - Add css styles to any lovelace card - Share your Projects! / Dashboards & Frontend - Home Assistant Community (home-assistant.io) Perhaps you will find your solution there as well.
Sorry if asked before, but searched this thread and couldnāt find an answer.
How do you get the swipe-card to work nicely inside a grid layout (using layout-card, css grid with grid-areas)? I place the swipe-card in one of my grid-areas and want to achieve the default behaviour of swipe-card like in the last example of the start-post of this thread.
The undesired effect I get is that the 2 cards inside the swipe-card get displayed side by side and the grid-area is stretched (and my other grid-areas too):
btw, when leaving the edit-mode of the UI the area gets streched even more and takes over the entire dashboard.
code:
type: custom:swipe-card
view_layout:
grid-area: row3_2
parameters:
autoplay:
delay: 6000
speed: 3000
cards:
- type: custom:button-card
template: big_tile
tap_action:
action: navigate
navigation_path: /dashboard-home/agenda
custom_fields:
custom_icon: '[[[ return `<img src="/local/images/icons8-calendar-96.png"/>` ]]]'
template: big_tile
tap_action:
action: navigate
custom_fields:
Does anyone know how to change the color of the elements of swipebar (sliders, bullets, etc)?
been looking for just that today, see: š¹ Card-mod - Add css styles to any lovelace card - #4191 by Mariusthvdb and only found my way through these just yet:
swiper-pagination-color: red
swiper-navigation-color: green
swiper-navigation-size: 24px
swiper-preloader-color: gold
# :host {
# --swiper-theme-color: var(--primary-color);
top variables can be set like that in your themes, or, like in the commented bit, directly in a card_mod.
as you can see the primary-color is used, so if you change that, it will also affect the swiper elements.
the pagination color only affects the active swiper bullet, for the other (inactive) bullets there is only a background color set, and an opacity:
the other theme variables are used in the resource:
swiper-navigation-color: green #used on the navigation elements (left and right, arrows)
swiper-navigation-size: 24px # used on those same elements
swiper-preloader-color: gold #not sure where this applies
but I have yet to find where they apply
I have set them in my theme like above now, so they would stand out, but they dontā¦
havent found the correct dom path yet to change those directly in a card config, and would really love to do soā¦
update
some detailed complexity: when using either bullets or progress bar on pagination, the theme color swiper-pagination-color is applied. However, when using fraction, to show 1/3, that same theme colors is not applied, and we have to go into inspector to reveal
using that:
card_mod:
style: |
:host {
color: red;
does Not work howeverā¦
made it this far:
type: custom:mod-card
card_mod:
style:
swipe-card:
/* colors the whole fraction element: '1/3' */
/*.swiper-pagination-fraction {
color: white;
/* colors the '1' in: '1/3' */
.swiper-pagination-current {
color: blue;
/* colors the '3' in: '1/3' */
.swiper-pagination-total {
color: gold;
ha-card {
font-weight: bold;
font-size: 20px;
color: white; */sets the full line, or only the '/', when the other elements are colored individually
unfortunately, the mod-card seems to lose some cards in the swiper⦠no idea why, but taking out the mod card brings them backā¦
2 questions if I mayā¦
- Have any Swiper gurus managed to enable hash navigation?
Itās shown below in the api:
I have buttons in a swipe-card that have a tap_action path of ā#[my paths]ā which state-switch listens and swaps to the corresponding card.
It would be better if the buttons in Swipe Card were also listening for hash changes and move to the corresponding slide.
I have tried to add it into the parameters etc and manually adding "data-hash=āhash valueā to the div class but I canāt figure it out.
- Has anyone run into this issue where by changing to a different view and then back causes the swiper to go to the last slide? If I refresh the page it always goes back to the specified slide but switching between views changes that (kitchen is what it should be one):
card_width: 100%
start_card: 1
slideToClickedSlide: true
parameters:
centeredSlides: true
slidesPerView: auto
spaceBetween: 30
speed: 420
cards:
FWIW:
Iāve raised the following issue on GitHub for the hash navigation:
I can get it to work if I manually define the class of the swipe-card slide data-hash="[my-hash-value]"
would be great if we could define this hash through the YAML config!
I have been looking into using javascript to add the data-hash class to each slide on page load but Iām having trouble navigating/targeting the specific slide through the DOM (Iām JS illiterate
Would it be possible to change this variable with card_mod, since that basically overwrites css code as well?
I have tried card_mod but I wasnāt able to get it to give the element a new class.
As in outside of the style="ā¦" class.
needs to be <button-card class="swiper-slide swiper-slide-active" data-hash="my_hash" style="..."</>
If anyone else was looking for a way to label their slides, hereās a hack that inserts names onto bullets via card-mod, and then styles them like so:
Filler text via Hipsum
card:
parameters:
pagination:
type: bullets
clickable: true
effect: cube
grabCursor: true
cubeEffect:
shadow: false
loop: false
cards:
- type: markdown
card_mod:
class: nav_1
content: >-
I'm baby raw denim dreamcatcher viral, taxidermy lumbersexual portland
occupy direct trade farm-to-table cliche seitan wayfarers activated
charcoal cardigan. Tattooed big mood XOXO, green juice food truck fit
echo park hexagon. Small batch put a bird on it intelligentsia JOMO,
letterpress williamsburg glossier. Poutine bruh XOXO, etsy big mood
jianbing kale chips tattooed flannel plaid chicharrones typewriter
fingerstache. Squid ramps poutine, activated charcoal la croix DSA sus.
- type: markdown
card_mod:
class: nav_2
content: >-
Occupy direct trade farm-to-table cliche seitan wayfarers activated
- type: markdown
card_mod:
class: nav_3
content: >-
Leggings seitan tofu, shabby chic salvia narwhal lomo mlkshk shoreditch
listicle ascot authentic vice. Semiotics cray ugh iceland polaroid
meditation. Affogato ramps portland 3 wolf moon pickled bruh austin,
hoodie skateboard subway tile literally. Seitan vegan letterpress
knausgaard, tacos asymmetrical cardigan trust fund single-origin coffee
palo santo keffiyeh gluten-free. Bicycle rights trust fund beard
intelligentsia irony, typewriter sriracha subway tile kitsch truffaut
selvage migas pork belly hashtag tonx. Venmo squid try-hard pug.
style:
swipe-card$: |
.swiper-container {
margin: 0 0 0 0 !important;
padding: 65px 30px 10px 30px !important;
.swiper-pagination-bullets {
position: absolute;
top: 15px;
bottom: inherit !important;
width: 100%;
.swiper-pagination-bullets>span {
margin: 0px !important;
min-width: 100px;
min-height: 25px;
padding-top: 5px;
border-radius: 0;
.swiper-pagination-bullets>span:last-child {
border-radius: 0px 10px 10px 0px;
.swiper-pagination-bullets>span:first-child {
border-radius: 10px 0 0 10px;
.swiper-pagination-bullets>span:nth-child(1):before {
content: "CAMS";
.swiper-pagination-bullets>span:nth-child(2):before {
content: "CLIMATE";
.swiper-pagination-bullets>span:nth-child(3):before {
content: "LAB";
Hacked together some JS to add the data-hash to each slide in my slider and also adds a back card that when swiped returns to the beginning.
For some reason changing back to the view with which the swiper is on always shows the last slide (for me?), another reason for using the ābackā slide which automatically puts it back to the beginning on page load.
Also because the browser hash changes on swipe, no click is required which means that simply swiping the slider to the desired slide can change (in my case) a state-switch card.
Note: I have no JS experience or understanding and was hacked together. No idea on the performance implications of this and Iām sure there are far superior solutions! Please suggest
parameters:
slidesPerView: auto
spaceBetween: 30
hashNavigation:
watchState: true
cards:
let prevUrl = undefined;
setInterval(() => {
const currUrl = window.location.href;
if (currUrl != prevUrl) {
const select1 = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > grid-layout").shadowRoot.querySelector("#root > stack-in-card").shadowRoot.querySelector("ha-card > div > hui-vertical-stack-card").shadowRoot.querySelector("#root > mod-card").shadowRoot.querySelector("ha-card > swipe-card").shadowRoot.querySelector('div.swiper-wrapper > [aria-label="1 / 5"]');
const select2 = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > grid-layout").shadowRoot.querySelector("#root > stack-in-card").shadowRoot.querySelector("ha-card > div > hui-vertical-stack-card").shadowRoot.querySelector("#root > mod-card").shadowRoot.querySelector("ha-card > swipe-card").shadowRoot.querySelector('div.swiper-wrapper > [aria-label="2 / 5"]');
const select3 = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > grid-layout").shadowRoot.querySelector("#root > stack-in-card").shadowRoot.querySelector("ha-card > div > hui-vertical-stack-card").shadowRoot.querySelector("#root > mod-card").shadowRoot.querySelector("ha-card > swipe-card").shadowRoot.querySelector('div.swiper-wrapper > [aria-label="3 / 5"]');
const select4 = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > grid-layout").shadowRoot.querySelector("#root > stack-in-card").shadowRoot.querySelector("ha-card > div > hui-vertical-stack-card").shadowRoot.querySelector("#root > mod-card").shadowRoot.querySelector("ha-card > swipe-card").shadowRoot.querySelector('div.swiper-wrapper > [aria-label="4 / 5"]');
const select5 = document.querySelector("body > home-assistant").shadowRoot.querySelector("home-assistant-main").shadowRoot.querySelector("app-drawer-layout > partial-panel-resolver > ha-panel-lovelace").shadowRoot.querySelector("hui-root").shadowRoot.querySelector("#view > hui-view > grid-layout").shadowRoot.querySelector("#root > stack-in-card").shadowRoot.querySelector("ha-card > div > hui-vertical-stack-card").shadowRoot.querySelector("#root > mod-card").shadowRoot.querySelector("ha-card > swipe-card").shadowRoot.querySelector('div.swiper-wrapper > [aria-label="5 / 5"]');
var pathArray = window.location.pathname.split('/');
if (pathArray[2] == '[your_view]' && window.location.hash == '' && (!select1.hasAttribute("data-hash"))) {
window.location.hash = '#hash1'
select1.setAttribute("data-hash","hash1");
select2.setAttribute("data-hash","hash2");
select3.setAttribute("data-hash","hash3");
select4.setAttribute("data-hash","hash4");
select5.setAttribute("data-hash","back");
else {
if (pathArray[2] == '[your_view]' && window.location.hash == '#back' && (select1.hasAttribute("data-hash"))) {
prevUrl = currUrl;
}, 100);
Thats fantastic!
Can I change the background behind the text of the selected box somehow?
Sure, those are stock markdown cards, so they can be altered with card-mod (or you can use whatever other cards you want)
Ah; gotcha. Thatās here:
min-width: 100px;
min-height: 25px;
padding-top: 5px;
border-radius: 0;
background: red; /* <---- */
I found something thanks to flufftronix
ДпойлеŃ
style:
swipe-card:
.swiper-pagination-bullet {
background-color: rgba(108, 108, 108, 0.3) !important;
width: 50px !important;
height: 50px !important;
.swiper-container {
margin: 0 0 -10px 0 !important;
padding: 0px 30px 20px 30px !important;
card:
Where do you put the javascript for this? Is it possible to embed it in the dashboard or do you have to inject it with browser mod?
Hi again!
When I use this with custom:button-card I canāt press the buttons.
Is there anything I can do to use this method but still be able to press buttons?
Yes you can just create a .js file, upload it to your HA instance and then load the .js file as a resource either in configuration.yaml or using the UI.
Please note that the code snippet I posted is tailored to my swipe card and you will need to change the querySelector paths and a few other parts etc to work with your own.
I use it with the double_tap_action:
