Lovelace: Swiper card
I created a card with swiper, that lets you flick through multiple cards.
You can use (almost?) all options of swiper, these can be found here.
More info can be found in the repo: https://github.com/bramkragten/custom-ui/tree/master/swipe-card
A few config examples:
Full width cards with scrollbar:
      - type: custom:swipe-card
        parameters:
          spaceBetween: 8
          scrollbar:
            hide: false
            draggable: true
            snapOnRelease: true
        cards:
          - type: sensor
            entity: sensor.temperature_158d0001720278
            line_width: 8
            line_color: '#FF6384'
          - type: sensor
            entity: sensor.humidity_158d0001720278
            line_color: '#36A2EB'
            line_width: 8
          - type: sensor
            entity: sensor.illumination_f0b429cc4c88
            line_color: '#ffce57'
            line_width: 8
          - type: sensor
            entity: sensor.pressure_158d0001720278
            line_color: "#4BC0C0"
            accuracy: 8
            line_width: 8
Coverflow with pagination:
        card_width: '185px'
        start_card: 2
        parameters:
          effect: 'coverflow'
          grabCursor: true
          centeredSlides: true
          slidesPerView: 'auto'
          coverflowEffect:
            rotate: 50
            stretch: 0
            depth: 100
            modifier: 1
            slideShadows : true
          pagination:
            type: 'bullets'
        cards:
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            accuracy: 8
            line_width: 8
Navigation, keyboard and progressbar:
        card_width: '80%'
        parameters:
          spaceBetween: 8
          pagination:
            type: 'progressbar'
          navigation:
          keyboard:
            enabled: true
            onlyInViewport: true
        cards:
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            accuracy: 8
            line_width: 8
Default:
        cards:
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            line_width: 8
          - type: sensor
            accuracy: 8
            line_width: 8
Place swipe-card.js in /config/www/custom-lovelace/swipe-card/
  - url: /local/custom-lovelace/swipe-card/swipe-card.js?v=3.0.0
    type: module
Optional: add to custom_updater:
https://raw.githubusercontent.com/bramkragten/custom-ui/master/updater.json
I can’t tell by the picture but does each ‘card’ snap into place if you >half slide it?
Yes, it does. Also if you half slide the scrollbar.
This is really cool, nice one! :+1:
Nice space saver cheers
That looks awesome! Very useful.
You could also go all out with coverflow :sunglasses:
https://raw.githubusercontent.com/bramkragten/custom-ui/master/swipe-card/preview-coverflow.gif
This is damn hot! :+1:
EDIT:
@Bram_Kragten can’t get it working, log says:
TypeError: element.setConfig is not a function
tested with Chrome, Iron (Chromium) and Firefox :frowning:
Got any example code for this?
I get the same error (running on Safari)…
…/custom-lovelace/swipe-card/swipe-card.js?v=0.42:71:32 TypeError: element.setConfig is not a function. (In ‘element.setConfig(item)’, ‘element.setConfig’ is undefined)
Yes, working on the final version, will be up tonight (CET) with all config options.
Same goes for the errors, try the new version tonight and see if it solves it.
New version is on, please try :slight_smile:
Really nice space saver, will try it out!
Just tested with the latest version:
swipe-card.js?v=1.0:81 Uncaught TypeError: element.setConfig is not a function
    at _cards.config.cards.map (swipe-card.js?v=1.0:81)
    at Array.map (<anonymous>)
    at HTMLElement.set hass [as hass] (swipe-card.js?v=1.0:73)
    at config.cards.map.cardConfig (27194aefb40e6f5b8d5f.chunk.js:1371)
    at HTMLElement._createCards (27194aefb40e6f5b8d5f.chunk.js:1371)
    at Object.runMethodEffect [as fn] (app-084b7564.js:1067)
    at runEffectsForProperty (app-084b7564.js:1067)
    at runEffects (app-084b7564.js:1067)
    at HTMLElement._propertiesChanged (app-084b7564.js:1067)
My config:
  card_width: '185px'
  parameters:
    effect: 'coverflow'
    grabCursor: true
    coverflowEffect:
      rotate: 50
      stretch: 0
      depth: 100
      modifier: 1
      slideShadows : true
    pagination:
      type: 'bullets'
  cards:
    - type: sensor
      entity: sensor.serre_temperature
      line_width: 8
    - type: sensor
      entity: sensor.serre_humidity
      line_width: 8
- url: /local/custom-lovelace/swipe-card/swipe-card.js?v=1.0
  type: js
What version of home-assistant are you on? The sensor card you are using is only available in beta right now…
Ah damn using version 0.79.2, wasn’t clear in the topic.
The topic is about the slider, you can use it with any card.
You can use Lovelace: mini graph card for now.
I’m still getting this error:
.../custom-lovelace/swipe-card/swipe-card.js?v=1.0:81:32 TypeError: element.setConfig is not a function. (In 'element.setConfig(item)', 'element.setConfig' is undefined)
Safari, and HassOS v. 0.79.3
Same here, using iPad app. Love the card though!
What is your config? Are you also using the sensor card? You should swap that below ha version 0.80 for Lovelace: mini graph card if you want to do the same.
