Lovelace: Swiper card
Have you tried the loop command. If you look into the documentation, there is a loop option. But i am not sure if it works.
Should be something like:
loop: true
That did not work for me. But hey, its not that big problem. It would be nicer to have but if I dont ā€¦
Could you please give more details on this ā€œcssMode: Trueā€ where did you put it?
Iā€™m experiencing the same issue.
Furthermore, I have another issue.
I always need to clear the cache, or load another page from the iFrame to get the card (phone, or chrome) otherwise itā€™s just an empty box.
At first page loading:
After selecting Energy page or reloading page while clearing cache:
Thank you in advance for your feedback.
cards:
      - type: custom:swipe-card
        start_card: 1
        parameters:
          loop: false
          preloadImages: true
          cssMode: true
          observer: true
        card_mod:
          style: |
            swipe-card{
              background: transparent;
              height: 100%;
              width: 100%;
See above; just in the swiper card options!
Perfect, it s working like a charm, thank you.
Hi folks,
coverflow does not work. It just swipes, but this rotate:50 etc does not work. Card_width also has no effectā€¦ hmā€¦
(I want to see one card in the middle an on every side one 50% rotate = coverflow)
Any ideas why? I cannot find the problemā€¦
card_width: 50%
parameters:
  iOSEdgeSwipeDetection: true
  slideToClickedSlide: true
  effect: coverflow
  grabCursor: true
  centeredSlides: true
  coverflowEffect:
    rotate: 50
    stretch: 0
    depth: 100
    modifier: 1
    slideShadows: true
  pagination:
    type: bullets
  navigation:
    keyboard:
      enabled: true
      onlyInViewport: true
cards:
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/l
    show_state: true
    icon: mdi:sofa
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/esszimmer
    icon: mdi:table-furniture
    show_state: true
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/kuche
    icon: mdi:chef-hat
    show_state: true
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/eg-flur
    icon: mdi:stairs
    show_state: true
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/eingang
    icon: mdi:door-closed
    show_state: true
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /lovelace/wc
    icon: mdi:toilet
    show_state: true
I implemented my heating controls with Better Thermostat. Now I want to use this in the swipe card. My problem now is that if I want to adjust the temperature manually with my finger, it always swipe immediately to the second page. Can i somehow block the card as soon as i press the slider so that the swipe is not executed?
I look forward to your experiences and suggestionsā€¦ Thanks in advance.
cards:
  - type: custom:better-thermostat-ui-card
    entity: climate.bt_bad_eg
    set_current_as_main: true
    disable_window: false
    eco_temperature: 18
    disable_summer: true
    disable_eco: true
  - type: custom:mini-graph-card
    align_state: center
    entities:
      - color: '#FFC300'
        entity: sensor.ble_bad_eg_temperatur
        index: 2
parameters:
  scrollbar:
    hide: true
    draggable: true
    snapOnRelease: true
  spaceBetween: 0
  effect: coverflow
  pagination:
    type: progressbar
  keyboard:
    enabled: true
Did you solve the problem with the slider? I have the same problem with Better Thermostat.
Adding cssMode: True as per my post above solved that particular problem for me!
Hello, I started to use the swiper card in my dashboard and I noticed one problem:
I have set the start_card to 2. (to be able to swipe in both directions)
When I switch this page using the swiper-card to a different page (without swiper-card) and back, then allways the last card is shown.
Can I get it to show the start_card 2?
( I also use the layout card on this page)
Using loop: true I get an empty page when comming back.
My dashboard is based on one picture element card in which I have the rest of the cards. Is it possible to put a swipe card in a picture element?
part of my code:
          - type: custom:hui-element
            cards:
              - type: sensor
                entity: sensor.domnasq_system_temperature
              - type: sensor
            style:
              top: 50%
              left: 50%
            card_type: custom:swipe-card
Hi all, Iā€™m using a custom tabbed and battery state card together. This allows me to display all my zigbee, zwave, and wifi battery devices in separate tabs with each of the battery devices in ascending order. I have a large number of zigbee devices and would love to be able to keep the ascending order but swipe to different pages (maybe in groups of 5-10 devices) to see the battery level of devices that have a higher percentage.
Does anyone know if I can use the swipe card to do this by defining how many entities in a list should display on each ā€œpageā€?
Hereā€™s what it currently looks like.
Perhaps anyone can help me.
I have a grid and want to swipe some cards in there. But the swipe cards doesnt fit in there
i cant find the right way how get it bigger
square: true
type: grid
cards:
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /fire-tablet/2
    icon: mdi:speaker
    show_state: false
    entity: input_boolean.musik
    hold_action:
      action: navigate
      navigation_path: ''
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /fire-tablet/l
    entity: light.lampen_wohnung
    icon: mdi:lightbulb
  - show_name: true
    show_icon: true
    type: button
    tap_action:
      action: navigate
      navigation_path: /fire-tablet/6
    icon: mdi:air-filter
    entity: input_boolean.heizen
    hold_action:
      action: call-service
      service: climate.set_hvac_mode
        entity_id:
          - climate.better_thermostat_bad
          - climate.better_thermostat_esszimmer
          - climate.better_thermostat_kuche
          - climate.better_thermostat_schlafzimmer
          - climate.better_thermostat_wohnzimmer
        hvac_mode: 'off'
    card_width: '250'
    cards:
      - type: button
        tap_action:
          action: navigate
          navigation_path: /fire-tablet/luften
        icon: mdi:home-analytics
columns: 4
Please can someone help me. How can I create a swipe card like the pics I posted below? So if you swipe to a room or category on the top and then it displays a swipe option below that you can swipe through and select a entity? Iā€™ve asked the person who posted this on his FB page but he hasnā€™t responded. Do i need to create helpers or templates? I have no idea.
here is his link
ā€œI've been revamping my mobile dashboard views. Here's what I have so far. | By Keith - Facebookā€
I use a combination of the swipe card and the tab card. This works fine on my android phone, but not on a windows machine. On windows (11) I canā€™t change the value (I donā€™t get a cursor) ?!
So this works fine :
type: custom:tabbed-card
styles:
  '--mdc-tab-text-label-color-default': rgba(128, 128, 128, 0.8)
  '--mdc-typography-button-font-size': 8px
options: {}
tabs:
  - card:
      type: vertical-stack
      cards:
        - type: entities
          entities:
            - entity: input_datetime.tijdstip_alles_uitschakelen
              name: All air conditioning off (again) at
              tap_action:
                action: none
              hold_action:
                action: none
    attributes:
      label: TEST
But this doesnā€™t :
cards:
  - type: custom:tabbed-card
    styles:
    options: {}
    tabs:
      - card:
          cards:
            - type: entities
              entities:
                  tap_action:
                    action: none
                  hold_action:
                    action: none
        attributes:
          label: TEST
Is this a bug ?
Hi
how did you create that card and the view?
how do you get the plugs and lights to show under the plugs or light option.
HI, How did you get those colors on your swipe card?
thanks
Hey all.
So i have the following issue with the Mini Graph Card and Swiper. Whenever I click something in the input select/drop down menu the card shifts up and the select list doesnā€™t display properly like in the picture below.
Has anyone encountered this isuse?
Anyone here been able to move the pagination bullets below the cards? I tried this that works in console but not live:
        card_mod:
          style: |
            .swiper-pagination {
              position: static;
              margin-top: 20px;
Hello, I am using this card with most standard parameters:
  reset_after: 30
  parameters:
    scrollbar:
      hide: false
      draggable: true
      snapOnRelease: true
Is it possible to get the resulting scrollbar above of my cards insted of below?
(similar to the progressbar, but still a scrollbar)
