Lovelace: Swiper card
I’m getting this error, t.setConfig error.
I’ve installed the preload cards and added it to my Lovelace with the card types and restarted, however it’s not changed.
It only works if I view the cards in another format first then go back to the slider card. So it suggests it’s still a preloading issue.
Does anyone know how to jump directly to a particular card though navigation.
in my setup, The first card in the group shows a basic overview of 8 of the subsequent cards. When I press on one of the overviews id like to jump directly to the card
Were you ever able to figure this out as I’m also looking to do the same thing? As devitus mentioned, there’s the activeIndex or realIndex properties but I don’t know how to use it within Home Assistant.
I know your question was a year ago or so but were you ever able to figure out or get an answer to your question on using events to use call-service? I’m looking to do something similar and am stuck. Thanks in advance.
Great card, easy to use for a novice like me, limitless possibilities.
ezgif.com-optimize
Weather clock example:
type: custom:swipe-card
card_width: auto
start_card: 1
parameters:
  slidesPerView: 1
  spaceBetween: 0
  grabCursor: true
  followFinger: true
  pagination:
    type: bullets
    color: white
cards:
  - type: custom:clock-weather-card
    entity: weather.openweathermap
    sun_entity: sun.sun
    temperature_sensor: sensor.openweathermap_temperature
    weather_icon_type: fill
    animated_icon: true
    forecast_days: 0
    locale: an-GB
    fill: true
    time_format: 12
    date_pattern: dd MMMM
    hide_today_section: false
    hide_forecast_section: true
    hide_clock: false
    hide_date: false
    hourly_forecast: false
    use_browser_time: true
    hide_forecast_section: false
    hide_date: false
    animated_icon: true
    hide_today_section: true
    weather_icon_type: line
    forecast_days: 4
Album gallery example:
 - type: custom:stack-in-card
              cards:
                - type: custom:swipe-card
                  card_width: 15%
                  start_card: 4
                  parameters:
                    spaceBetween: 4
                    effect: coverflow
                    grabCursor: false
                    centeredSlides: false
                    slidesPerView: auto
                    coverflowEffect:
                      rotate: 0
                      stretch: 0
                      depth: 20
                      modifier: 1
                      slideShadows: true
                    pagination:
                      type: bullets
                  cards:
                    - type: picture
                      image: >-
                        https://i.scdn.co/image/ab67706f00000002710eb316c75a6df0bd83bb2e
                      tap_action:
                        action: call-service
                        service: media_player.play_media
                          entity_id: media_player.den
                          media_content_id: >-
                            media-source://media_source/media/London
                            Streams/purple disco.m4a
                          media_content_type: audio/mp4
                          enqueue: play
                      entity: light.den_group
                    - type: picture
                      theme: slate
                      image: >-
                        https://i.scdn.co/image/ab67706c0000da84910fe2ed0a4c7d51595a203c
                      tap_action:
                            Streams/printworks stream1.m4a
                          enqueue: play
                      entity: light.greenhouse_group
No unfortunately, still bugs me on occasion :frowning:
I’m looking to swipe 2 different swipe-cards at the same time. (Built in a tabbed card and a vert-stack)
Is there any type of function or workaround for this?
So in this example I would like to swipe both the swipecard for temperature and the humidity at the same time.
Can you not just stack both cards within another vertical-stack, for example? Then your first swipe card would be the vertical stack rather than the individual temp cards.
swipecardtest
This looks great.
You willing to share the code for this one?
    card_width: 100%
    start_card: 1
    parameters:
      effect: coverflow
      threshold: 2
      slidesPerView: 1
      centeredSlides: true
      coverflowEffect:
        stretch: -50
        rotate: 20
        depth: 100
        slideShadows: true
    cards:
      - type: vertical-stack
        cards:
          - type: custom:mini-graph-card
            entities:
              - entity: sensor.wiser_lts_temperature_family_room
                name: Inside Temperature
                color: "#4caf50"
            hours_to_show: 24
            line_width: 2
            font_size: 50
            animate: true
            show:
              icon: false
              state: false
              legend: false
              labels: false
              labels_secondary: false
              fill: fade
            style: |
              ha-card {
                background-color: rgba(38,40,42,1) !important;
                margin: 0px !important;
            entities:
                color: "#4caf50"
            hours_to_show: 24
            line_width: 2
            font_size: 50
            animate: true
            show:
              icon: false
              state: false
              legend: false
              labels: false
              fill: fade
            style: |
              ha-card {
        cards:
            entities:
                color: "#4caf50"
                color: "#2196f3"
                y_axis: primary
            hours_to_show: 24
            line_width: 2
            font_size: 50
            animate: true
            show:
              icon: false
              state: false
              legend: false
              labels: false
              fill: fade
            style: |
              ha-card {
            entities:
                color: "#4caf50"
                color: "#2196f3"
                y_axis: primary
            hours_to_show: 24
            line_width: 2
            font_size: 50
            animate: true
            show:
              icon: false
              state: false
              legend: false
              labels: false
              fill: fade
            style: |
              ha-card {
Thx this helped a bit.
I’m still trying to figure out how to auto-populate my entities this way now.
It seems to be very hard since the Swipe card is doing such a great job putting the cards in a horizontal line.
Any suggestions? :slight_smile:
Previous code looking something like this.
type: custom:tabbed-card
tabs:
  - card:
      cards:
        - type: custom:auto-entities
          card:
            card_width: 400px
            autoHeight: true
            start_card: 1
            parameters:
              effect: coverflow
              grabCursor: true
              slidesPerView: auto
              coverflowEffect:
                rotate: 50
                stretch: 0
                depth: 100
                modifier: 1
                slideShadows: true
          card_param: cards
          filter:
            exclude:
              - name: '*ress*'
              - name: '*atter*'
              - name: '*umid*'
              - entity_id: '*sensor.gt*'
            include:
              - domain: sensor
                options:
                  entities:
                    - this.entity_id
                  color_thresholds:
                    - value: 27
                      color: '#f39c12'
                    - value: 28
                      color: '#d35400'
                    - value: 29
                      color: '#c0392b'
                  show:
                    labels: true
                    points: false
          card:
            card_width: 400px
            autoHeight: true
            start_card: 1
            parameters:
              effect: coverflow
              grabCursor: true
              slidesPerView: auto
              coverflowEffect:
                rotate: 50
                stretch: 0
                depth: 100
                modifier: 1
                slideShadows: true
          card_param: cards
          filter:
            include:
              - entity_id: '*umid*'
                domain: sensor
                options:
                  entities:
                    - this.entity_id
                  color_thresholds:
                    - value: 55
                      color: '#F3B6D5'
                    - value: 60
                      color: '#FD54A9'
                    - value: 65
                      color: '#3400DE'
                  show:
                    labels: true
                    points: false
          card:
            card_width: 400px
            autoHeight: true
            start_card: 1
            parameters:
              effect: coverflow
              grabCursor: true
              slidesPerView: auto
              coverflowEffect:
                rotate: 50
                stretch: 0
                depth: 100
                modifier: 1
                slideShadows: true
          card_param: cards
          filter:
            include:
              - entity_id: '*monox*'
                domain: sensor
                options:
                  entities:
                    - this.entity_id
                  color_thresholds:
                    - value: 600
                      color: '#F3B6D5'
                    - value: 800
                      color: '#FD54A9'
                    - value: 1000
                      color: '#3400DE'
                  show:
                    labels: true
                    points: false
    attributes:
      label: Alla rum
I am trying to use this card on my dashboard. However, whenever I try to use it, it messes up my top row. here is my code. Can anyone tell me what I might be doing wrong?
button_card_templates:
  !include_dir_merge_named ui-lovelace/button_card/
icon: mdi:tablet-smartphone
kiosk_mode:
  non_admin_settings:
    kiosk: true
    ignore_entity_settings: true
  entity_settings:
    - entity:
        input_boolean.kiosk: 'on'
      hide_header: true
    - entity:
        input_boolean.kiosk: 'off'
      hide_header: false
  - title: "dashboard"
    path: "dashboard"
    theme: tablet
    type: custom:grid-layout
    layout:
      #default
      grid-template-columns: 185px 1fr 1fr
      grid-template-rows: fit-content(100%) fit-content(100%)
      grid-template-areas: |
        "sb  col1top  col2top"
        "sb  col1bot  col2bot"
      mediaquery:
        #phone
        "(max-width: 800px)":
          grid-template-columns: 1fr
          grid-template-row: fit-content(100%) fit-content(100%) fit-content(100%) fit-content(100%) 1px
            "col1top"
            "col2top"
            "col1bot"
            "col2bot"
            "sb"
    cards:
      #extra_styles fix, do not remove
      #                    SIDEBAR                    #
        view_layout:
          grid-area: sb
        cards:
          - !include /config/ui-lovelace/cards/sidebar.yaml
      #                  HEADER1                      #
        view_layout:
          grid-area: col1top
        cards:
          - !include /config/ui-lovelace/cards/row-people.yaml
      #                     COL1                      #
        view_layout:
          grid-area: col1bot
        cards:
          - !include /config/ui-lovelace/cards/complete-climate.yaml
          - !include /config/ui-lovelace/cards/timer.yaml
      #                 HEADER2                       #
        view_layout:
          grid-area: col2top
        cards:
          - !include /config/ui-lovelace/cards/row-presence.yaml
      #                     COL2                      #
        view_layout:
          grid-area: col2bot
        cards:
            start_card: 1
            reset_after: 60
            parameters:
              spaceBetween: 8
              scrollbar:
                hide: true
                draggable: true
                snapOnRelease: true
            cards:
                cards:
                  - !include /config/ui-lovelace/cards/1-row-hvac-triggers.yaml
                  - !include /config/ui-lovelace/cards/1-row-living.yaml
                  - !include /config/ui-lovelace/cards/1-row-bedrooms.yaml
                  - !include /config/ui-lovelace/cards/1-row-bathroom-kitchen.yaml
                  - !include /config/ui-lovelace/cards/1-row-garage-kitchen.yaml
                  - !include /config/ui-lovelace/cards/1-row-basement.yaml
                cards:
                  - !include /config/ui-lovelace/cards/2-living-buttons.yaml
                  - !include /config/ui-lovelace/cards/2-bedroom-buttons.yaml
                  - !include /config/ui-lovelace/cards/2-neenie-buttons.yaml
                  - !include /config/ui-lovelace/cards/2-maggie-buttons.yaml
                  - !include /config/ui-lovelace/cards/2-bathroom-buttons.yaml
                  - !include /config/ui-lovelace/cards/2-kitchen-buttons.yaml
Without the swipe card this is what I have.
But when I enable to code above, I get this. The top row in the right column gets way out of whack.
Has anyone encountered this issue? I have tried searching this thread, but haven’t found anything. Cards and entities are not loading in until I change view.
swipe_bug
Hi Fredrik. Have you found any solution ?
Hi, since I read the swiper card is not being maintained anymore, I dropped it all together. Hoping I have wrong, because it’s a great card :slight_smile:
Hi there,
I just started using this swipe card. But it isn’t showing the trend line. Anyone an idea how this can be?
You can use the start_card parameter, if that is what you mean.
No I don’t think it centers the start card like in my image. It would just be #2 and #3 visible.
Nothing to do with swiper card. You need to use the correct variables for sensor card. Add graph: line to actually show a graph.
Is this so you can have one template that can be used on all your button cards ?
now my lovelace code is so long because i have to code it for every button and also if i want to change one thing i have to do it for every card by hand
