heffneil
(Neil H.)
February 17, 2021, 12:29pm
1
Hey guys I am working on a relay that will turn on a relay when the garage door is closed. I think I have it working 100% the only odd thing is that the switch for the output on the ESP32-Wroom turns off automatically.
In my ESPHome code I don’t have an auto-reset template. Its very strange. I am wondering if I need to restart my system after removing settings for RESTORE_DEFAULT_ON
tom_l
February 17, 2021, 2:22pm
2
Without any configuration code we would only be guessing.
heffneil
(Neil H.)
February 17, 2021, 3:22pm
3
The lovelace buttons are defined as such:
type: entities
entities:
- entity: sensor.garage_esp32_wifi_signal_sensor
- entity: switch.esp_left_garage_door
- entity: switch.esp_middle_garage_door
- entity: switch.esp_right_garage_door
- entity: switch.led_left_garage
- entity: switch.led_middle_garage
- entity: switch.led_right_garage
- entity: binary_sensor.esp_left_garage_sensor
- entity: binary_sensor.esp_middle_garage_sensor
- entity: binary_sensor.esp_right_garage_sensor
- entity: binary_sensor.esp_back_garage_sensor
title: Garage ESP32
The issues are within these:
ESPhome settings:
- platform: gpio
pin: GPIO25
- platform: gpio
pin: GPIO26
- platform: gpio
pin: GPIO27
name: "LED Left Garage"
turn_on_action:
- switch.turn_on: pin25
turn_off_action:
- switch.turn_off: pin25
icon: "mdi:arrow-up-down-bold-outline"
name: "LED Middle Garage"
turn_on_action:
- switch.turn_on: pin26
turn_off_action:
- switch.turn_off: pin26
name: "LED Right Garage"
turn_on_action:
- switch.turn_on: pin27
turn_off_action:
- switch.turn_off: pin27
tom_l
February 17, 2021, 3:26pm
4
heffneil:
ESPhome settings:
That is not sufficient. I can’t even see if those platforms are for switches or binary sensors.
heffneil
(Neil H.)
February 17, 2021, 3:39pm
5
Forgive my ignorance I am new to this.
switch:
and on an ESP32 WROVER
tom_l
February 17, 2021, 3:50pm
6
Ok, for the template switches you need to define a lambda function to determine the state of the switch. See https://esphome.io/components/switch/template.html#configuration-variables
Otherwise ESPHome does not know what state your switch is in.
Can you explain why you are not using the GIPO switches directly in home assistant, and are using templates to control them?
Or even better, why not use this?
heffneil
(Neil H.)
February 17, 2021, 6:20pm
7
Again I am all new to this and without some examples I am not sure what is proper. I didn’t mean to go on this tangent but I am trying to turn a relay on and off thats basically it. For this particular case I was testing my outputs really but there are other GPIO’s I will use to operate the relay to open and close the garage door. Let me know if that makes sense? If there was an example ESP Home example and or the lovelace front end I could see it might make better sense?
Thanks a bunch!
tom_l
February 17, 2021, 6:25pm
8
If you give these names:
switch:
- platform: gpio
pin: GPIO25
- platform: gpio
pin: GPIO26
- platform: gpio
pin: GPIO27
They will appear as switches in Home Assistant (add them to an entities card) and you don’t need the template switches.
heffneil
(Neil H.)
February 17, 2021, 7:00pm
9
I wish I understood that, but forgive me, I don’t know what you are saying above?
This is how I am testing. The full card is here:
entities:
title: Garage ESP32
tom_l
February 17, 2021, 7:11pm
10
I’m saying you don’t need the template switches in ESPHome. Just use the GPIO switches.
Where did the binary sensors come from?
You have not shown an esp config for them.
heffneil
(Neil H.)
February 17, 2021, 8:00pm
11
This is (almost) everything:
binary_sensor:
- platform: gpio
name: "ESP Left Garage Sensor"
pin:
number: GPIO16
mode: INPUT_PULLDOWN
- platform: gpio
name: "ESP Middle Garage Sensor"
pin:
number: GPIO17
- platform: gpio
name: "ESP Right Garage Sensor"
pin:
number: GPIO18
- platform: gpio
name: "ESP Back Garage Sensor"
pin:
number: GPIO32
switch:
- platform: gpio
pin: GPIO19
- platform: gpio
pin: GPIO21
- platform: gpio
pin: GPIO22
- platform: gpio
pin: GPIO23
- platform: gpio
pin: GPIO25
- platform: gpio
pin: GPIO26
- platform: gpio
pin: GPIO27
turn_on_action:
turn_off_action:
turn_on_action:
turn_off_action:
turn_on_action:
turn_off_action:
name: "esp Left Garage Door"
restore_state: yes
turn_on_action:
- switch.turn_on: pin19
- delay: 500ms
- switch.turn_off: pin19
name: "esp Middle Garage Door"
restore_state: yes
turn_on_action:
- switch.turn_on: pin21
- delay: 500ms
- switch.turn_off: pin21
name: "esp Right Garage Door"
restore_state: yes
turn_on_action:
- switch.turn_on: pin22
- delay: 500ms
- switch.turn_off: pin22
name: "esp Back Garage Door"
restore_state: yes
turn_on_action:
- switch.turn_on: pin23
- delay: 500ms
- switch.turn_off: pin23
- platform: wifi_signal
name: "Garage ESP32 WiFi Signal Sensor"
update_interval: 60s
tom_l
February 18, 2021, 3:42am
12
That is not what you posted originally when I asked for your esphome configuration. I can’t help you if you keep wasting my time like this.
You want to define three template covers in home assistant that pull your binary sensors and switches together into three garage door components.
heffneil
(Neil H.)
February 18, 2021, 2:14pm
13
I didn’t change it. I don’t know why you’re so adversarial. Im just looking for help and didn’t want to dump the entire thing.
I appreciate your time and help. Just looking to make this work. I will figure it out.
