title: My Awesome Home
theme: dark_cyan
# View tab title.
title: Weather
cards:
This results in nothing and just keeps using the default theme.
If I add the theme to a tab (here Weather), it gets used in the cards but not in the general layout (so background is still white, top banner still blue, … .
theme: dark_cyan
# View tab title.
title: Weather
theme: dark_cyan
cards:
# The markdown card will render markdown text.
type: entities
So question: how should themes be used in this ui-lovelace or where does the relevant documentation live?
click the hamburger > then your user icon> then choose a theme. That is the global theme that gets used. Themes used within each section of the ui in lovelace is independent of each other and will only affect that panel.
Is that what you’re looking for?
If you look on this page it says it about mid ways down
# Each view can have a different theme applied. Theme should be defined in the frontend.
theme: dark-mode
Thank you, through the GUI it works indeed by selecting the theme.
But I prefer to have my full configuration in the .yaml files, so I have a clean backup and not a mixture of gui-modifications and scripts. The suggestion in your link does not have the same effect (it’s what I’ve tried in my first post), only the cards itself get the theme-background/layout.
What? Everything is done through yaml. These aren’t gui modifications.
Yeah, that’s whats supposed to happen. If you want a global change you need to have a theme that defines your CSS. Selecting it through the ui is how people select what theme they want. If you want to do it through yaml then you need to make an automation that selects and changes themes. When you’re using a default theme that’s what you’re going to get, defaults.
