In the Frontend version of the thermostat, the temperature step-size is based upon target_temp_step. If this parameter in not defined then it derives the step-size from the unit system. For Fahrenheit it uses 1 and for Celsius it’s 0.5.
Ideally, it should configure itself like the Frontend version and use target_temp_step. If not defined, it should auto-configure itself based upon the unit system (metric=0.5, imperial=1.0).
I want one that doesn’t take up so much space. Having a 12 zone thermostat with such a giant card takes up way too much space… Can we get a compact mode that flattens the circle into a little arc?
