Lovelace: threshold-stack card
Hello HA community! Here’s a custom card I made after posting in the Discord and finding no card that fit my needs. It makes cards appear as either a horizontal-stack or vertical-stack, depending on your screen’s width. Works best if you use it with vertical-stack nested underneath, for example all of your lights in a vertical-stack or each room in their own vertical-stack.
Behold!
Installation
Install threshold-stack.js as a module.
resources:
  - url: /local/threshold-stack.js
    type: module
Usage
type: custom:threshold-stack
threshold: <pixels>px
cards:
If the device is at least pixels pixels wide, cards will be displayed as a horizontal-stack.
If the device is less than pixels pixels wide, cards will be displayed as a vertical-stack.
Options
  • threshold Threshold in pixels for horizontal-stack. Default: 800px
  • cards Required Cards to render; works particularly well as a vertical-stack container
Check out the code on Github:
Thank you! This is the exact thing I have been looking for the last couple days.
