Hi all. I have a tab in HA to control my electric underfloor heating via Shelly1PM relays. This works well but relies on a simple on/off button. I would like to create another button for a boost option or timer that can be selected and will turn the device on for a set period eg 1, 2, 4 hours etc. It would be nice for the button to show the time remaining, then at the end of the period it turns off the device.
Does anyone have an example they can show? I have never used booleans or Node Red before so require some simple guidance
Have you thought about using input helpers? I would recommend an input number and a timer.
Create an input_number and timer in Configuration β Automations and Scenes β Helpers and add helpers lower right.
You can start the timer and turn on the heater
alias: Floor Heat Timer Activation
description: Activate the timer for floor heat
- platform: state
entity_id: switch.floor_heat
to: 'on'
condition: []
- service: timer.start
duration: {{ states('input_number.heat_duration_seconds') | int }}
entity_id: timer.floor_heat
mode: single
then
alias: Floor Heat Turn Off
description: Turn off floor heat
- platform: state
to: idle
- platform: homeassistant
event: start
condition: []
- service: switch.turn_off
The timer will fail and go to idle on a restart. This is why I have triggered on homeassistant start to also shut off floor heat. If you need to survive a restart, it can be done but more complicated automations.
So your timer will be in minutes. Do you know how to get the timer into lovelace so you can set? I will assume you do at this point and proceed. The first automation is to turn on a timer so you have visual on how long there is left until it turns off
create a timer in helpers.
Go to automations and create an automation
2a In trigger select state as the trigger (by pressing the down arrow next to device)
2b Choose your entity (the shelly 1pm that controls the underfloor heat) switch.floor_heat in my example
2c Set from: off to: on
2d Bypass the conditions - you donβt need any
2e Go to Actions and select call service. Select timer.start as service and pick the timer you just created.
2f Paste this with quotes "{{ states('input_number.ufh_duration') * 60 | int }}" into the duration field.
2g Save your automation.
The second automation is to turn off the floor heat when the duration is done
3 Create the second automation.
3a Create a state trigger as in 2.
3b Select time as entity and set to: idle (meaning the timer has turned off)
3c Create a second trigger. Triggers always OR. timer idle or homeassistant start go do actions
3d Select homeassistant from the drop down. It should have the start already checked below.
3e Bypass the conditions.
3f On actions create call service.
3g On the service, type switch and you should see switch.turn_on, turn_off, and toggle show in a pop up. Select turn off
3h On the entity select the shelly 1 pm.
The logic is:
When you turn on the underfloor heat
1a. This turns on the timer
When the timer expires or the system restarts for whatever reason
2a. turn off the underfloor heat.
