I get huge amounts of errors regarding waze not being able to find the coordinates of Amsterdam…
2019-04-15 23:19:44 ERROR (SyncWorker_18) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: Cannot get coords for Amsterdam, NL
2019-04-15 23:24:46 ERROR (SyncWorker_1) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: Cannot get coords for Amsterdam, NL
2019-04-15 23:34:47 ERROR (SyncWorker_15) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: Cannot get coords for Amsterdam, NL
2019-04-15 23:44:54 ERROR (SyncWorker_6) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: Cannot get coords for Amsterdam, NL
Unfortunately, the latest version of the waze sensor does not accept non-coordinates. You can talk with the developer about this at the WazeRouteCalculator repository here https://github.com/kovacsbalu/WazeRouteCalculator
but what do these sensors render? gps coordinates, or location names. Its with the latter the Waze component has issues.
I have several using device_trackers (coordinates) and they show fine too.
Hi, I got an issue after restart
Uncaught NotSupportedError: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “waze-card” has already been used with this registry
Installed HACS before.
There is only one entry in lovelace yaml
I’ve just discovered this card and set it up fine, but can you confirm or not whether when it opens the Waze app it creates the route for you automatically?
I’ve got it to open the app but it sits waiting for me to set a route up.
Well, since iOS 13, it now opens the Apple Maps app. Still routes correctly, so not sure what has changed. I don’t really use this to start navigation, so not really an issue for me.
I only set this up yesterday so was already on ios13, opens in Waze for me by specifying it as the map in the card. however I don’t get a route, just the app opening.
Taking the Map line out opens google maps for me, not apple maps, but it does set the route correctly.
I always use Waze so would be good if I could get the routing working.
is this still working? I installed via hacks and get no data - only 0 km and 0 travel time. I tryed zones and waze endities. It looks like that there is no start point. Can yomeone help me?
