Lovelace: Travel Time Card
it seems like the Here integration is not working. I get the following error when I try to add it:
I am using it fine, did you get the API key ? or could you you not get that far ?
yes, i have an api key. I believe this is a known issue.
Strange, I have had an API key for a long time (old version) so maybe thatā€™s why it still works for me. Iā€™ve just tried adding a new integration and it works fine
Sorry for bumping an old thread, but how do I convert the minutes to HH:MM (hours and minutes?).
Iā€™m aware of template sensors, but not sure how to incorporate the conversation into this card.
type: custom:travel-time-card
entities:
  - sensor.waze_travel_time_2
distance_units: miles
Hey,
is there a possibility to show the ā€œlast updateā€ or ā€œlast changedā€ status for the entities?
@Mariusthvdb I know that this is an old link, but if you give me a few hints it would be greatly appreciated.
I would like to know how hthe sensor.origin, sensor.destination and the sensor.route_planner were created.
A sample of each code would really help.
Again thank you for all the help you have given me in the past.
sure, its a bit complex, but works well:
      - unique_id: here_destination
        state: >
          {% set select = states('input_select.destination') %}
          {% if select == 'Thuis'%} {% set destination = 'zone.home' %}
          {% elif select in ['Marijn','P2','P3','P4','P5','P6'] %}
            {% set destination = 'person.' ~ select|lower %}
          {% else %} {% set destination = 'zone.' ~ select|slugify %}
          {% endif %}
          {{destination}}
        picture: >
          {% if select in ['Marijn','P2','P3','P4','P5','P6'] %}
            {{state_attr(destination,'entity_picture')}}
          {% else %} /local/travel/destination.png
          {% endif %}
        attributes:
          latitude: >
            {% if select == 'Thuis'%} {% set result = 'zone.home' %}
              {% set person = 'person.' ~ select|lower %}
              {% set result = 'zone.home' if states(person) == 'home' else
            {% else %} {% set result = 'zone.' ~ select|slugify %}
            {% endif %}
            {% set lat = state_attr(result,'latitude') %}
            {{lat}}
          longitude: >
            {% endif %}
            {% set lon = state_attr(result,'longitude') %}
            {{lon}}
and the same for
      - unique_id: here_origin
        state: >
          {% set select = states('input_select.origin') %}
          {% if select == 'Thuis'%} {% set origin = 'zone.home' %}
            {% set origin = 'person.' ~ select|lower %}
          {% else %} {% set origin = 'zone.' ~ select|slugify %}
          {% endif %}
          {{origin}}
etcetc
so this relies on having those input_selectā€™s, and person device_trackers with lat/long (which I have also set as possible from/to options in the input_select). Got to realize that person trackers in zone home do Not have a lat/long, so that is a reason I base those off the custom component Composite, which always sets the lat/long correctly, even when in zone home.
the final Here sensors are made by the integration,
and I have a script that updates the entities, so it doesnt have to poll constantly
script:
  update_routeplanner_dynamic:
    sequence:
      service: homeassistant.update_entity
        entity_id:
          - sensor.here_route_planner_distance
          - sensor.here_route_planner_duration
and I can push the button in the dashboard.
originally, I had the route (itinerary below in the commented section) I the map, but that has been taken from usā€¦ and never replaced by anything alike.
crd now is this:
type: entities
title: Routeplanner
card_mod:
  class: class-header-margin
entities:
  - input_select.origin
  - input_select.destination
  - entity: script.update_routeplanner_dynamic
    action_name: Hernieuw
  - type: custom:fold-entity-row
    head:
      type: section
      label: Routebeschrijving
      card_mod: &label
        style: |
          .label {
            margin-left: 0px !important;
    padding: 0
    entities:
      - type: custom:hui-element
        card_type: markdown
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              margin: 0px -16px;
        content: >
          {% set duur = states('sensor.here_route_planner_duration') %}
          {% set afstand = states('sensor.here_route_planner_distance') %}
          Van: {{states('input_select.origin')}} Naar: {{states('input_select.destination')}}
          Duur: {{duur}} minuten,  Afstand: {{afstand}} km.
    head:
      type: section
      label: op Kaart
      card_mod: *label
    padding: 0
    card_mod:
      style: |
        div#items {
          margin: 16px -16px -16px -16px;
    entities:
        card_type: map
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
        entities:
           - sensor.here_origin
           - sensor.here_destination
    head:
      type: section
      label: Details
      card_mod: *label
    padding: 0
    entities:
      - entity: sensor.here_origin
      - entity: sensor.here_destination
#       - sensor.here_route_planner_route
      - entity: automation.update_travel_sensors
        secondary_info: last-triggered
        state_color: true
      - entity: automation.update_travel_options
        state_color: true
 # - type: custom:fold-entity-row
#    head:
#      type: section
#      label: Itinerary
#    padding: 0
#    entities:
#      - type: custom:waze-card
#        card_mod:
#          style: |
#            ha-card {
#              box-shadow: none;
#        title: ''
#        entities:
#          - entity: sensor.here_route_planner
Thank you for all the information, you went way above what I had suspected.
Also thank you for your generous time in explaining this.
I copied the info to my text editor and will start to piece it together.
sure, and feel free to ask, youā€™re most welcome!
