Lovelace UI - Linux console editor
This is for the linux console junkies (like me) :slightly_smiling_face: who edit their files mostly in a terminal.
As the ui-lovelace.yaml gets bigger and bigger, i wrote a little script that greps the views from the file and starts the editor at the line number with the selected view.
The script (for example, save it in ~/ui_edit.sh and make it executable):
#!/bin/bash
userhome=$(eval echo ~$user)
# Path to ui-lovelace.yaml
lovelace_yaml="$userhome/.homeassistant/ui-lovelace.yaml"
# Command to start the editor and the option to jump to a line number
# For example, nano jumps to line with +linenumber
editor='nano -SE -T2 +'
prompt="Please select a view:"
# Grep the lovelace.yaml for lines starting a view ('  - title:')
options=( $(egrep '^ {2}- title:' -n $lovelace_yaml | awk '{print $4}') )
# Make some little menu with the views
PS3="$prompt "
echo '------------------------------------------------------'
select opt in "${options[@]}" "Quit" ; do
    if (( REPLY == 1 + ${#options[@]} )) ; then
        exit
    elif (( REPLY > 0 && REPLY <= ${#options[@]} )) ; then
        echo  "You picked $opt ($REPLY)"
        break
    else
        echo "Invalid option. Try another one."
    fi
done
# Grep the lovelace.yaml once again for the '  title: <option>' and get the line number
lnum=$(egrep "^ {2}- title: ${opt}" -n $lovelace_yaml | awk -F ":" '{print $1}')
# Start the editor an jump to the line number
$editor$lnum $lovelace_yaml
I created an alias in .bashrc:
alias uiedit='~/ui_edit.sh'
Now when i type uiedit:
(ha) homeassi:~$ uiedit
1) Home		    4) Mediaplayer     7) Cameras	 10) System
2) Wetter	    5) Milights	       8) Miscellaneous	 11) Quit
3) Baustelle	    6) Covers	       9) Tests
You picked Tests (9)
The editor starts with the selected view
### Tests
  - title: Tests
    #theme: PmxMononight
    icon: mdi:flask-outline
    cards:
      - type: entities
Have fun!
Nice, I like it but cant get it to work.
copied the file made executable, changed lovelace.yaml path to mine but just says"Invalid option. Try another one."
Can you post the output of
egrep '^ {2}- title:' -n /path/to/your/ui-lovelace.yaml
thank you
I get nothing
Maybe you’re using icons only.
thank you
no i’ve identified my views like so:
- title: Info
  icon: mdi:information
Thx @ciotlosm, but shouldn’t the β€˜title’ be required?
The script expects 2 spaces in front of β€œ- title:”, maybe thats the problem?
Thank you
I run
egrep β€˜^ {0}- title:’ -n /path/to/your/ui-lovelace.yaml
and got this
35: **- title:** Rooms
135: **- title:** Living
213: **- title:** Bose
275: **- title:** Info
442: **- title:** Location
517: **- title:** Server Status
Ok, definitely the way i have my yaml.
changed to
options=( $(egrep β€˜^ {0}- title:’ -n $lovelace_yaml | awk β€˜{print $3}’ ) )
and it works.
thank you for your help
