šŸŒ» Lovelace UI ā€¢ Minimalist
Okay that is missing - where do I add this? Where was that explained? Thanks a lot!
Yes, installed via HACS.
I have tried with 3 popup variables. Still not working.
Regarding browser_mod line in configuration.yaml - Yes, itā€™s added.
In the installation instructions of browser_mod :wink:
thomasloven/hass-browser_mod: :small_blue_diamond: A Home Assistant integration to turn your browser into a controllable entity - and also an audio player (github.com)
ĀÆ_(惄)_/ĀÆ Strange. If you want you can create an issue on our github repo. There, such errors can be tracked and documented a bit better than here in the forum where everything gets mixed up.
Added the integration via HACS, added the line into the config.yaml - no change, same error
I am probably missing something simple but when I try to add any of the Slider cards to my dashboard I get an error. When I view the dashboard the button loads the brightness percentage and the name but displays an error message like ā€œCustom Element doesnā€™t exist:my-sliderā€¦ā€.
Any ideas?
Welcome!
You need the my-slider card, see here:
Installation
slider-card
Seems to be an IOS issue:
On IOS sliding starts by pressing the thumb, which is reduced to 0px in the template.
Thatā€™s why it could not work.
The solution is to make it wider but it is now visible. I use default value (25px)
        type: "custom:my-slider"
        entity: "[[[ return entity.entity_id ]]]"
        radius: 14px
        height: 42px
        mainSliderColor: rgba(var(--color-yellow),1)
        secondarySliderColor: rgba(var(--color-yellow),0.2)
        mainSliderColorOff: rgba(var(--color-theme),0.05)
        secondarySliderColorOff: rgba(var(--color-theme),0.05)
        thumbVerticalPadding: "5px"
        # thumbWidth: 0px (default 25px)
        thumbHeight: 42px
        card_mod:
        style: |
          ha-card {
            border-radius: 14px;
            box-shadow: none;
card_slider_light_ios
Hey all,
I know the guy that put together the wiki is gone now. Do we have a list of all the cards somewhere. I see people talking about pull requests ect. But is there a list of whats been added?
Thanks! :slight_smile:
Yeah, weā€™re working on a solution.
Here are all the current custom_cards:
I meant the issue @Mission_Bread_5230 posted :slight_smile:
Thats awesome!
Thank you :slight_smile:
Finally, itā€™s working. Thank You for your advice.
Anyway, gotta ask how to get instant working background color swaps etc? like for normal light_card or power_outlet
Iā€™m using below code but I need to manually refresh to see changes (I spent hour thinking - why itā€™s not working :smiley: )
        state:
         - operator: template
           value: "[[[ return states[variables.humidifier].state == 'on' ]]]"
           styles:
             icon:
               - color: "rgba(var(--color-yellow),1)"
             label:
               - color: "rgba(var(--color-yellow-text),1)"
             name:
             img_cell:
               - background-color: "rgba(var(--color-yellow), 0.2)"
             card:
               - background-color: "rgba(var(--color-background-yellow),var(--opacity-bg))"
Nevermind, adding below solved all issues :slight_smile:
triggers_update: "all"
Does your card include?:
Because your are using the state of a variable the button-card needs to trigger updates.
If your value is based on your entity it auto-triggers, but than you can use:
       state:
         -  value: "on"
Yup, it worked like a charm - edited post like 2 minutes before your post.
Change of styles is working nice but itā€™s for - letā€™s say button only. What if I would like to swap color of entire card? Can I use above code (itā€™s giving me error currently). I want something working like card_light if itā€™s possible in custom_card.
Can you share the full code of the card you want to change? This makes it easier to help you. You can apply styles on item-level as I think your are doing now without affecting the underlying card.
Itā€™s test card for Humidifier with selecting Mode (lvl 1,2,3)
As You can see itā€™s working okay but want to have more control over colors especially I want to know how to color background of whole card like in light_card.
card_humidifier:
  styles:
    grid:
      - grid-template-areas: '"item1" "item2"'
      - grid-template-columns: 1fr
      - grid-template-rows: min-content  min-content
      - row-gap: 12px
    card:
      - border-radius: var(--border-radius)
      - box-shadow: var(--box-shadow)
      - padding: 12px
  custom_fields:
    item1:
      card:
        type: 'custom:button-card'
        label: '[[[ return states[variables.water_lvl].state ]]]'
        template:
        - ulm_language_variables
        icon: 'mdi:air-humidifier'
        color: var(--google-grey)
        show_icon: true
        show_label: true
        show_name: true
        state:
           styles:
             icon:
             label:
             name:
             img_cell:
             card:
        styles:
          icon:
            - color: "rgba(var(--color-blue),1)"
          label:
            - justify-self: start
            - align-self: start
            - font-weight: bolder
            - font-size: 12px
            - filter: opacity(40%)
            - margin-left: 12px
          name:
            - align-self: end
            - font-weight: bold
            - font-size: 14px
            - margin-left: 12px
          state:
            - align-self: start
            - font-size: 12px
            - margin-left: 12px
          img_cell:
            - background-color: "rgba(var(--color-blue),0.2)"
            - border-radius: 50%
            - place-self: center
            - width: 42px
            - height: 42px
          grid:
            - grid-template-areas: '"i n" "i l"'
            - grid-template-columns: min-content auto
          card:
            - border-radius: 21px 8px 8px 21px
            - box-shadow: none
            - padding: 0px
        tap_action:
          action: call-service
          service: humidifier.toggle
          service_data:
            entity_id: humidifier.zhimi_ca4_a088_humidifier
    item2:
      card:
        template: list_items
        custom_fields:
          item1:
            card:
              template: widget_icon
              icon: 'mdi:numeric-1-box'
              tap_action:
                service: humidifier.set_mode
                service_data:
                  mode: Level1
              state:
                value: "[[[ return states[variables.humidifier].attributes.mode == 'Level1' ]]]"
                styles:
                  icon:
                  label:
                  name:
                  img_cell:
                  card:
          item2:
            card:
              icon: 'mdi:numeric-2-box'
              tap_action:
                service_data:
                  mode: Level2
          item3:
            card:
              icon: 'mdi:numeric-3-box'
              tap_action:
                service_data:
                  mode: Level3
The full card color can be controlled with:
card_humidifier:
  styles:
    grid:
      - row-gap: 12px
    card:
      - padding: 12px
  state:
      value: "[[[ return states[variables.your_variable].state ]]]"
      styles:
        card:
          - background-color: "your_color"
In your code you only specify changeable styles to your individual items. With this addition your adding changeable styles to your ā€œmain_cardā€.
Thanks for all your work. I love this ā€œthemeā€.
Sometimes my card will not work even with the standards cards.
The other day it complained about another standard integrated card.
How do I fix this?
Are you using another custom card, e.g. custom stack-in-card?
