Hi everyone
Has version 0.0.8 been deleted?
I donāt see it on Github anymore ā¦
Now the latest release is 0.0.7-hotfix2
Hello please. I canāt understand the basic structure. I follow tutorials and videos and I canāt get it to work. I give you examples
So it doesnāt show anything
button_card_templates: !include_dir_merge_named "../../custom_components/ui_lovelace_minimalist/__ui_minimalist__/ulm_templates/"
# Button cards location
!include views/home.yaml
Thatās how it works. The problem is the custom cards. I add the template to the custom_cards folder of my project and still canāt find it.
title: "My new dashboard"
theme: "minimalist-desktop"
background: "var(--background-image)"
# views: !include_dir_merge_list "views/"
- type: "custom:button-card"
template: "card_esh_welcome"
triggers_update: "input_boolean.minimalist_dropdown"
variables:
ulm_card_esh_welcome_collapse: input_boolean.minimalist_dropdown
ulm_weather: "weather.openweathermap"
entity_1:
nav: "house"
icon: "mdi:home"
color: "blue"
entity_2:
nav: "lights"
icon: "mdi:lightbulb"
color: "yellow"
entity_3:
nav: "security"
icon: "mdi:shield"
color: "green"
entity_4:
nav: "network"
icon: "mdi:nas"
color: "purple"
entity_5:
nav: "network"
icon: "mdi:flask"
color: "red"
file structure
Hey guys,
Something Iāve found that may help people not seeing updates on their screen. is you need to save both the current yaml file that you are using to create a view, but also the main ui-lovelace.yaml (or whatever you have named it)
Have you refreshed āui lovelace minimalistā in the settings page of HA as well? Since 2022.5 you can find it under Developer Tools > Yaml > āUI LOVELACE MINIMALISTā button.
Afterwards you also need to refresh the dashboard with the three dots > Refresh
edit: btw, I see that you have a card right under views, thatās not possible. You should either seperate each view (like home.yaml) and include it in the main yaml OR you have one big YAML with all the views.
- title: "Home"
path: home
icon: "mdi:home"
cards:
variables:
entity_1:
nav: "house"
icon: "mdi:home"
color: "blue"
entity_2:
nav: "lights"
color: "yellow"
entity_3:
nav: "security"
icon: "mdi:shield"
color: "green"
entity_4:
nav: "network"
icon: "mdi:nas"
color: "purple"
entity_5:
nav: "network"
icon: "mdi:flask"
color: "red"
Yes. The one that says two is a trial version. The idea was to create a main file and in the views folder put all the files as Home. This is how I saw it in an Everythng, Smart Home tutorial. The Home.yaml file finds it but shows nothing. not even the bar with the three points. It finds it because if I change the name it gives me an error. thanks for answering
Maybe this is not the case, but if you have āminimalist-mobileā as a theme in your profile it will not show the three dot menu (nor any of the views as a tab). What I do is when I create and edit the dashboard I use the āminimalist-desktopā as a theme.
This is how I have it, it loads every view yaml inside the given folder.
main dashboard yaml
And every view starts like this (01-home.yaml)
Also try with a simple card just to check if it shows, because the welcome card can give trouble sometimes when you havenāt filled it in correctly. Maybe like the person card or a simple binary sensor card.
Iām super clear. And it worked for me. Thank you very much for the help
Hello everyone. I am adding this card to be able to see the popup. Does anyone have the script you need to find the phone and show the popup. Thank you very much
Hello everyone. I am trying to create a new color template. But when I want to use it in a room card it says that it canāt find that template. Do I have to reload something for it to find it? Thank you
darkgrey_no_state:
styles:
icon:
- color: "rgba(var(--color-darkgrey),1)"
label:
- color: "rgba(var(--color-darkgrey-text),1)"
name:
img_cell:
- background-color: "rgba(var(--color-darkgrey), 0.2)"
Has anyone had any issues not getting units to show up in chips, specifically the icon state chips? Iāve checked the chip code and checked my sensors have units but they donāt seem to display units for some reason!
Hi. Could you share the card? thank you
This does work. But you have to keep pressing the button, it only rings once. So if anyone knows how to make it loop until you ack that would be awesome
alias: Find My Phone
sequence:
- service: notify.mobile_app_iphone
message: Here is your phone.
persistent: true
tag: persistent
push:
sound:
critical: 1
volume: 1
mode: single
icon: mdi:cellphone
Perfect. Thank you very much
I found what you tell me looking for more.
pablo_find_my_phone:
sequence:
- repeat:
count: 3
sequence:
- service: notify.mobile_app_sm_g973f
title: Encontrar mi telƩfono
message: AcĆ” estoy
push:
sound:
critical: 1
volume: 1.0
- delay:
seconds: 4
Hello everyone. Why canāt I get my air handler to look as different as it should?
This is how it looks
Yeah ok, I use node red for everything these days. forgot about repeats and delays, nice work
Would be better if we could have it ring until acknowledged, but take what you can get
Also; does name: Ringtone_UK_Haptic.caf work for you?
I get the same sound no matter what I put in lol
So I have to say, this has been great. I was originally using mushroom cards for the clean design, but after ESHās video on this I decided to give it a whirl. The only thing that I canāt stand is that the default light card (w/ slider) turns the card color either yellow, or the color of the light. I canāt stand this. Iād like to use the blue_on template, but it doesnāt seem to work. Can someone point me in the right direction? Thanks!
Hey guys,
my lovelace.yaml is currently quite simple.
lovelace:
mode: storage
I have our greate minimalist dashboard and some simple UI-created dashboards.
My question: How do I make the minimalist dashboard āadmin onlyā?
Thank you!
Hi Guys,
Is anyone able to help me. Screwed it up. Had afresh install of 62bit HA. I followed the guide and manually installed all the front-end integrations. I then did the main add-in for it and had the UI Lovelace show up in my side bar, I clicked it and it gave me loads of errors saying cards hadnāt loaded. I checked and they were all installed in the front-ends section. So I disabled the UI Lovelace Integration, rebooted, re-enabled it and now for the life of me I cannot get the icon and link back in my side bar?
I have cleared chace, multiple browsers, private windows etc? Changed and saved the settings but still canāt get it to show back up?
Any ideas
Hello everyone. The custom person card opens a popup when one clicks on it. Why is it not opening anything?
I found the error but I donāt know how to fix it. When I check the configuration to see if everything is correct, it doesnāt find browse_mode. I read the documentation but Iām not understanding something because I canāt find it. I put the browse_mod folder in different places and I canāt get it to work.
In the documentation it says that you have to configure it like this
{ url: "/local/vanilla-tilt.min.js?v=1.7.2",type: module },
{ url: "/local/my-cards.js", type: module },
{ url: "/browser_mod.js", type: module },
{ url: "/local/font.css", type: css }
This is the location that I believe is where it should now be.
\192.168.1.4\config\www\custom_components\browser_mod
@basbrus: can you please share the code of your person card which adds the battery percent of the personās phone? Thank you.
