šŸŒ» Lovelace UI ā€¢ Minimalist
@pedolsky I havenā€™t tried that (yet), but shouldnā€™t it be possible, to just copy the link to the template files in the ā€œraw config editorā€? Or does the complete template have to be copied into? :slight_smile:
PS: Will send a PM in a few minutes. :slight_smile:
EDIT: Canā€™t send a PM to youā€¦? Is there a way to contact you, maybe you sending a PM and I can respond?
I have setup this with UI mode and can share my raw config if you are interested.
Unfortunately, currently it seems not possible to use !include in ui dashboards, here is a feature request: https://community.home-assistant.io/t/ability-to-use-include-directives-in-ui-editor/336167
Mmh, strange, in my settings pm from other users is allowed. I will try to pm you.
Oh great! Can you send me a PM? I appreciate you.
Hi, I would be interested too. In particular Iā€™m looking for some help to set up the localisation tab and the sensor for present/absent chip
It still is a work in progress but it will give you a good start point to work with.
For scenes setup like @tben i have setup automation in shortcuts on my iOS device. (Tasker only work in Android)
Automations are setup so it will call an action in HA app when i leave/arrive home/work.
Just ask and i all give some example on that also.
Paste this in an empty Lovelace dashboard - Lovelace UI ā€¢ Minimalist - Pastebin.com
All the credits goes to @tben, i have only copy and paste his great work :slight_smile:
Update1.
Mobile themes code. Create a folder in themes folder called mobile. Create an yaml file with name mobile.yaml. Paste this - Lovelace UI ā€¢ Minimalist - Mobile themes - Pastebin.com
Desktop themes code. Create a folder in themes folder called desktop. Create an yaml file with name desktop.yaml. Paste this - Lovelace UI ā€¢ Minimalist Desktop theme - Pastebin.com
Have an happy tuesday
Hello all,
I just created a alarm clock UI, I find it easier than using the keyboard.
If there is any interest, I would clean up the code and share it here. :slight_smile:
super-nice, release, please!
I am interested :pray:
Can I ask what ā€œlocalisationā€ means in this sense?
Iā€™d translate it to ā€œlocationā€ in the meaning of presence detection. :slight_smile:
Hey, how do you set up ā€œsensor.people_count_presentā€ ?
Have this error :slight_smile:
I use Life360 for myself and Iphone tracker for my wife
tben posted his solution a few days ago. :slightly_smiling_face:
Since I like to work with NodeRed the alarm was implemented with it, of course this would also be possible with HomeAssistant automations but I prefer NodeRed simpler and more practical.
You need some helpers for this. These are created under: Configuration > Helpers.
Time Helper:
  • control_alarm_clock
Dropdown Helper:
  • control_alarm_clock_status
Counter Helper:
  • control_alarm_clock_minute_counter
  • control_alarm_clock_hour_counter
Toggle Helper:
  • alarm_clock_counter_minute_plus
  • alarm_clock_counter_minute_minus
  • alarm_clock_counter_hour_plus
  • alarm_clock_counter_hour_minus
The View and the Node Red Flow:
view_alarm_clock.yaml:
  - icon: mdi:alarm
    badges: []
    cards:
      - cards:
          - type: horizontal-stack
            cards:
              - type: vertical-stack
                cards:
                  - type: custom:button-card
                    template: title
                    double_tap_action:
                      action: call-service
                      confirmation:
                        text: double
                    cards:
                      - template: edge
                        cards:
                            cards:
                                cards:
                                  - entity: input_boolean.alarm_clock_counter_hour_plus
                                    template:
                                      - icon_info_bg
                                      - outlet
                                    label: Hour
                                    tap_action:
                                      action: toggle
                                  - entity: input_boolean.alarm_clock_counter_hour_minus
                                    template:
                                      - icon_info_bg
                                      - outlet
                                    label: Hour
                                    tap_action:
                                      action: toggle
                            cards:
                              - entity: input_boolean.control_alarm_clock
                                template:
                                  - icon_info_bg
                                  - outlet
                                label: |
                                    return states['input_datetime.control_alarm_clock'].state;
                                tap_action:
                                  action: toggle
                              - entity: input_select.control_alarm_clock_status
                                template:
                                  - icon_info_bg
                                  - outlet
                                label: |
                                    return states['input_select.control_alarm_clock_status'].state;
                            cards:
                              - entity: input_boolean.alarm_clock_counter_minute_plus
                                template:
                                  - icon_info_bg
                                  - outlet
                                label: Minute
                                tap_action:
                                  action: toggle
                              - entity: input_boolean.alarm_clock_counter_minute_minus
                                template:
                                  - icon_info_bg
                                  - outlet
                                label: Minute
                                tap_action:
                                  action: toggle
                      - template: edge
NodeRed flow.json:
        "id": "d8bc2cec8cc75d72",
        "type": "api-call-service",
        "z": "bc22c480e12e0600",
        "name": "",
        "server": "4bbca37b.1700ec",
        "version": 3,
        "debugenabled": false,
        "service_domain": "input_datetime",
        "service": "set_datetime",
        "entityId": "input_datetime.control_alarm_clock",
        "data": "{\"entity_id\":\"input_datetime.control_alarm_clock\",\"time\":\"{{ time }}\"}",
        "dataType": "json",
        "mergecontext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 1620,
        "y": 440,
        "wires": [
        "id": "c2842c07fd1a2c05",
        "type": "api-current-state",
        "name": "Minute Counter",
        "server": "707fb62d.6e7a88",
        "version": 2,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "counter.control_morgen_wecker_minute_counter",
        "state_type": "str",
        "blockInputOverrides": false,
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
                "property": "minute",
                "value": "",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 1080,
        "y": 440,
        "wires": [
                "37db83f5b386feca"
        "id": "f9c0e0678b2f794e",
        "name": "Hour Counter",
        "version": 2,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "counter.control_alarm_clock_hour_counter",
                "value": "",
                "property": "data",
                "value": "",
                "property": "hour",
                "value": "",
        "x": 880,
        "y": 440,
        "wires": [
                "c2842c07fd1a2c05"
        "id": "37db83f5b386feca",
        "type": "function",
        "name": "Merge Time",
        "func": "var newTime = \"New Alarm Clock Time\";\n\nnewTime = msg.hour + \":\" + msg.minute;\nmsg.time = newTime;\n\nreturn msg;\n\n\n// D0doooh from blog.xonatec.ch",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1310,
        "y": 440,
        "wires": [
                "d8bc2cec8cc75d72"
        "id": "23fa339f84e3d45e",
        "type": "server-state-changed",
        "name": "hour plus",
        "version": 3,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.alarm_clock_counter_hour_plus",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "haltifstate": "on",
        "outputs": 2,
        "output_only_on_state_change": true,
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 220,
        "y": 200,
        "wires": [
                "27435f33b5d56346",
                "e09c78909b1072ec"
        "id": "3e5d365e7ea908e8",
        "name": "hour minus",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.alarm_clock_counter_hour_minus",
        "outputs": 2,
        "for": 0,
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 220,
        "y": 360,
        "wires": [
                "770a70af063796b2",
                "5511ebfa738a2319"
        "id": "27435f33b5d56346",
        "name": "hour plus off",
        "version": 3,
        "service_domain": "input_boolean",
        "service": "turn_off",
        "entityId": "input_boolean.alarm_clock_counter_hour_plus",
        "data": "",
        "dataType": "jsonata",
        "mergecontext": "",
        "queue": "none",
        "x": 210,
        "y": 240,
        "wires": [
        "id": "770a70af063796b2",
        "version": 3,
        "entityId": "input_boolean.alarm_clock_counter_hour_minus",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 210,
        "y": 400,
        "wires": [
        "id": "e09c78909b1072ec",
        "name": "",
        "version": 3,
        "service_domain": "counter",
        "service": "increment",
        "entityId": "counter.control_alarm_clock_hour_counter",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 500,
        "y": 200,
        "wires": [
                "f9c0e0678b2f794e"
        "id": "5511ebfa738a2319",
        "name": "",
        "version": 3,
        "service": "decrement",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 510,
        "y": 360,
        "wires": [
                "f9c0e0678b2f794e"
        "id": "d973e869a3658ac8",
        "name": "Minute plus",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.alarm_clock_counter_minute_plus",
        "outputs": 2,
        "for": 0,
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 230,
        "y": 540,
        "wires": [
                "a9cb9aecf1da9875",
                "98d7bb141e327313"
        "id": "20b4c719c9988d33",
        "name": "Minute minus",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.alarm_clock_counter_minute_minus",
        "outputs": 2,
        "for": 0,
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 230,
        "y": 700,
        "wires": [
                "79ff82c54726aff9",
                "09d5a56aa874110a"
        "id": "a9cb9aecf1da9875",
        "name": "minute plus off",
        "version": 3,
        "entityId": "input_boolean.alarm_clock_counter_minute_plus",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 220,
        "y": 580,
        "wires": [
        "id": "79ff82c54726aff9",
        "name": "minute minus off",
        "version": 3,
        "entityId": "input_boolean.alarm_clock_counter_minute_minus",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 230,
        "y": 740,
        "wires": [
        "id": "98d7bb141e327313",
        "name": "",
        "version": 3,
        "entityId": "counter.control_alarm_clock_minute_counter",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 500,
        "y": 540,
        "wires": [
                "f9c0e0678b2f794e"
        "id": "09d5a56aa874110a",
        "name": "",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 510,
        "y": 700,
        "wires": [
                "f9c0e0678b2f794e"
        "id": "4bbca37b.1700ec",
        "type": "server",
        "name": "Home Assistant",
        "version": 1,
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true
        "id": "707fb62d.6e7a88",
        "type": "server",
        "name": "TRUE Home Assistant",
        "version": 1,
        "legacy": false,
        "addon": true,
        "cacheJson": true
Hi Patrick, should we still wait for the ā€œthemeā€ or give it a go/continue with the current project?
Thanks for asking, if time is not critical for you. Iā€™d say wait. :slight_smile: :wink: It is going forward, but not all things are cleared right now. :slight_smile: Shouldnā€™t take too long from this point on. :slight_smile:
What did you do with the entity state if unavailable part from the icon_info template, since there are no entities connected to this example. Curious, because I experience the error if I donā€™t add an entity
ButtonCardJSTemplateError: TypeError: entity is undefined in 'if (entity.state =='unavailable'){ return `<ha-icon icon="mdi:exclamation" style="width: 12px;...'
That case isnā€™t handled in this example. The template definition from icon_info_bg needs an entity set to work correctly.
Change the code to set the entity as a variable. If you set the entity as ā€œentityā€ in button-card, you will break the design.
I can post a solution later this day, Iā€™m in a hurry. :slight_smile:
Please share an example when you have some more time since i dont know how to set the entity as variable
Need some help my friends with my conditional cards. My second card does not show even that it should(what i think)
I think it shows behind the first conditional but i might be wrong.
Solved!
