Elmor
(Elmor)
March 14, 2023, 9:06am
3124
Hi, hope youâre all doing well. Iâm trying to get started with this wonderful template but I cannot seem to get the example dashboard working as it should. As you can see below the pills in the scene card are aligned strangely and overlap with eachother. When I click/toggle them, they align correctly again (see second pill)
Iâm running everything (HA, resources) on the latest version. Iâve tried different themes, browsers, resolutions, devices but itâs all the same. Does anyone have a clue?
Elmor
(Elmor)
March 14, 2023, 2:38pm
3126
When everything is toggled ON it looks better:
But when everything is toggled OFF you see it all jump over the place and overlapâŠ
detLAN
(Detlef)
March 15, 2023, 2:28pm
3127
Hi Oliver,
can you help me again? I have two sensors, if only one of them is âopenâ, the color should be pink immediately. If both or one is âtiltedâ and possibly the second is âclosedâ, the color should be blue. I canât get the correct code programmed:
templates:
if (states['sensor.bad_rechts_fenstergriff_state'].state === 'open')
or if (states['sensor.bad_links_fenstergriff_state'].state === 'open')
return 'pink_no_state';
else if (states['sensor.bad_rechts_fenstergriff_state'].state === 'tilted')
or if (states['sensor.bad_links_fenstergriff_state'].state === 'tilted')
return 'blue_no_state';
return 'grey_off'
Thank you
EDIT:
I just found the solution myself
templates:
else if (states['sensor.bad_links_fenstergriff_state'].state === 'open')
else if (states['sensor.bad_links_fenstergriff_state'].state === 'tilted')
return 'grey_off'
Did you ever work this out? Iâm getting the same problem.
jjnj
(jjnj)
March 16, 2023, 7:47pm
3129
Are you ready to share your code?
It looks so great.
Fixed it. It was the color codes:
- type: vertical-stack
cards:
- card:
entity: alarm_control_panel.home_alarm
states:
- arm_home
style:
ha-card > ha-label-badge{
--alarm-state-color: rgba(var(--color-green),1) !important;
ha-card{
padding-top: 16px;
padding-bottom: 12px !important;
border-radius: 21px;
ha-card > h1{
padding-top: 0;
color: transparent;
ha-card > h1::before{
content: "Disarm";
color: rgba(var(--color-green),1);
position: absolute;
font-variant: small-caps;
#alarmCode{
display: none;
#keypad{
display: none !important;
'#armActions':
mwc-button:
#button > span.slot-container{
color: transparent;
position: absolute;
#button{
width: 150px;
#button > span.slot-container::before{
color: var(--mdc-theme-primary, #6200ee);
content: "Arm";
margin: 0 0 0 50%;
title: Alarm
type: alarm-panel
conditions:
- entity: alarm_control_panel.home_alarm
state: disarmed
type: conditional
- card:
states:
- arm_home
title: Alarm
type: alarm-panel
style:
--alarm-state-color: rgba(var(--color-red),1) !important;
ha-card{
padding-top: 16px;
ha-card > h1{
padding-top: 0;
color: transparent;
content: "Arm";
color: rgba(var(--color-red),1)v;
position: absolute;
'#armActions':
mwc-button:
color: transparent;
position: absolute;
#button{
width: 150px;
content: "Disarm";
margin: 0 0 0 50%;
'#keypad':
mwc-button:
#button{
border-radius: 12px
conditions:
state_not: disarmed
type: conditional
Faecon
(Jo)
March 20, 2023, 2:38pm
3132
When I try to add the person_card I get this error
solution : I didnât had users made
Faecon
(Jo)
March 21, 2023, 5:09pm
3135
is it possible to slide the 6 cards from âruimtesâ to 6 others ?
edit : trying but no victory
this is my code:
- type: custom:swipe-card
parameters:
speed: 550
spaceBetween: 40
threshold: 5
cards:
cards:
- type: horizontal-stack
cards:
- type: "custom:button-card"
cards:
cards:
now I have 4 buttons on a row to slide, but not 2 rows with 2 buttons. What am I doing wrong ?
Is it possible to use templates in the yaml parameters? It doesnât seem to be working. This doesnât color the icon for example:
template: chip_navigate
variables:
ulm_chip_navigate_path: security
ulm_chip_navigate_icon: mdi:shield
ulm_chip_navigate_icon_color: >
{% if is_state("alarm_control_panel.alarm_name", "disarmed") %}
var(--google-green)
{% else %}
var(--google-red)
{% endif %}
I could set up a template sensor and then use the states['sensor.template_sensor'].state syntax which does work. Is that the best way?
AbuMoosa
(AbuMoosa)
March 24, 2023, 1:12am
3137
did you manage to fix this?
Regards
I didnât. I still have the issue.
Faecon
(Jo)
March 26, 2023, 8:53am
3140
How can I make a popup weather card by pressing a chip ? Is it with tap_action ?
Faecon
(Jo)
March 26, 2023, 10:46am
3141
Where can I find the fontsize and colour so I can make the apexcharttitle the same as the minimal font ?
Shadorlo
(Shadorlo)
March 26, 2023, 4:56pm
3142
Bonjour,
Jâaimerai convertir ma carte mushroom pour quâelle soit compatible ui minimalist pouvez-vous mâaidez ?
Merci
voici une photo de la carte Ă convertir et son code
type: custom:stack-in-card
keep:
margin: true
box_shadow: true
background: true
cards:
cards:
style: |
ha-card {
padding-bottom: 1px !important;
primary: Chauffage maison
- type: custom:simple-thermostat
style: |
ha-card {
--st-spacing: 0px;
ha-card .current--value {
color: #000000;
header {
margin-bottom: 12px !important;
padding-bottom: 0px !important;
ha-card .thermostat-trigger {
color: #9e9e9e;
entity: climate.chauffage_1
header: false
decimals: '0'
fallback: 'Off'
hide:
temperature: true
state: true
layout:
mode:
names: false
icons: false
headings: false
step: row
step_size: '1'
control:
hvac:
'off': false
heat: false
cool: false
heat_cool: false
style: |
ha-card {
--st-font-size-toggle-label: 6px
--st-spacing: 0px;
--st-default-spacing: 2px;
--st-mode-background: #262626;
margin-left: 12px;
margin-right: 12px;
ha-card .mode-item.active.off {
background: #363636;
color: #9e9e9e;
ha-card .mode-item.active.cool {
background: #1d3447;
color: #2196f3;
ha-card .mode-item.active.heat {
background: #472421;
color: #f44336;
ha-card .mode-item.active {
background: #263926;
color: #4caf50;
ha-card .mode-item.active:hover {
color: #9e9e9e;
ha-card .mode-item:hover {
color: #9e9e9e;
ha-card .mode-item {
--st-spacing: 10px;
border-radius: 10px;
ha-card .modes {
grid-gap: 12px
header: false
setpoints: false
hide:
temperature: true
state: true
layout:
mode:
headings: false
icons: true
names: true
step: row
control:
hvac:
'off':
heat:
cool:
cards:
primary: '{{ states(entity) | round|int }} °c'
secondary: Intérieur
icon: mdi:thermometer
entity: sensor.openweathermap_forecast_temperature
icon_color: blue
badge_icon: |-
{% set temp = states(entity) | int %}
{% set setpoint = states('sensor.thermostat_setpoint') | int %}
{% if temp == setpoint %} mdi:check-bold
{% elif temp <= 60 %} mdi:snowflake
{% elif temp >= 80 %} mdi:heat-wave
{% else %}
{% endif %}
badge_color: |-
{% if temp == setpoint %} green
{% elif temp <= 60 %} blue
{% elif temp >= 80 %} deep-orange
{% else %}
{% endif %}
picture: ''
secondary: Extérieur
icon_color: green
badge_icon: |-
{% set outside_temp = states(entity) | int %}
{% set inside_temp = states('sensor.thermostat_temperature') | int %}
{% if outside_temp == inside_temp %} mdi:equal
{% elif outside_temp <= 32 %} mdi:snowflake
{% elif outside_temp >= 90 %} mdi:heat-wave
{% else %}
{% endif %}
badge_color: |-
{% if outside_temp == inside_temp %} green
{% elif outside_temp <= 32 %} blue
{% elif outside_temp >= 90 %} deep-orange
{% else %}
{% endif %}
picture: ''
layout:
mode:
headings: false
icons: true
names: true
step: row
control:
hvac:
'off': false
heat: false
cool: false
heat_cool: false
fan:
auto:
icon: mdi:fan-auto
'on':
icon: mdi:fan
- type: custom:mini-graph-card
entities:
- entity: sensor.openweathermap_forecast_temperature
name: Température intérieur
color: '#2196f3'
name: Température extérieur
color: '#4caf50'
hours_to_show: 24
line_width: 3
font_size: 75
animate: true
show:
icon: true
state: true
legend: true
fill: fade
Faecon
(Jo)
March 30, 2023, 9:45am
3144
- type: 'custom:button-card'
template: chip_mdi_icon_state
variables:
ulm_chip_mdi_icon_state_entity: sensor.p1_meter_5c2faf04a1f2_active_power
ulm_chip_mdi_icon_state_icon: mdi:lightning-bolt-circle
styles:
icon_color: |-
{% set state = states('sensor.p1_meter_5c2faf04a1f2_active_power') %}
{% if is_number(state) and (state | float < 1 and state | float > 0) %}
Green
{% elif is_number(state) and state | float < 0 %}
Blue
{% else %}
Red
{% endif %}
tap_action:
!include zonnepanelen.yaml
I want a colour change of the icon depending on the value ⊠but i get a black icon
basbrus
(Bas)
March 30, 2023, 10:32am
3145
Minimalist is not like Mushroom where you can have Jinja-templating. Also it is based on custom:button-card which will need JavaScript templating.
variables:
styles:
icon:
- color: >
let state = states('sensor.p1_meter_5c2faf04a1f2_active_power').state
if(parseFloat(state) < 1 && parseFloat(state) > 0 ){
return 'green' }
else if(parseFloat(state) < 0){
return 'blue' }
return 'red'
tap_action:
Faecon
(Jo)
March 30, 2023, 11:15am
3146
Its clear I donât understand a word of writing code
But it isnât working. Actually I want :
styles:
- color: >
if(parseFloat(state) > 0 ){
return 'green' }
return 'red'
but that isnât working also
basbrus
(Bas)
March 30, 2023, 11:20am
3147
You first need to select the icon grid as did in my example:
basbrus:
styles:
icon:
- color: >
PS; I made a small mistake in the state part. It should have instead of ().
let state = states['sensor.p1_meter_5c2faf04a1f2_active_power'].state
AbuMoosa
(AbuMoosa)
March 30, 2023, 11:02pm
3148
I have used the latest code for cover card to fix the issue and also change the icon color.
see @billyjoebob999 âs post
thanks @basbrus for all your work and help to fix this
