I am hoping to give Minimalist UI I try, but am already off to a rough patch, and can;t seem to figure out where my mistake could be,
Iāve started by following the excellent youtube video greated by Lewis at the wiki. I already followed his video for mushroom, and now looking to try Minimalist.
But I canāt seem to get started. Iāve installed it, but get stuck at the point off adding in the welcome card and it just return a blank dashboard. I setup the helper toggle, setup the custom card folder and custom card. Everything looks correct from a folder and file path perspective, just a blank dashboard.
The yaml code looks correct from what I can see. But would an extra space someplace or something cause a blank dashboard?
Iāll give it another try tomorrow with some fresh eyes. But for now, Iām just stuck.
Edit. Found the typo. It was missing " - " in referencing the include.
I think if you are referring to the lines around the cards, itās because you need to set in your profile the theme to be one of the minimalist themes.
I am still new with Minimalist, so unsure if its a coding issue on my end or other.
I am trying to get either the Expander Card or the Collapsible Card to work with Minimalist
//https://github.com/Alia5/lovelace-expander-card
or
//https://github.com/RossMcMillan92/lovelace-collapsable-cards
I can get both of those to work and show up on my PC in a web browser. But then both of them also give an error on my mobile device of āCustom element doesnāt existā.
Why would it work in the web browser but not on the mobile device?
I am also having a lot of difficulty getting this working, and see the same issue sometimes.
About 90% of the time I refresh the page, I get āCustom element doesnāt existā errors, but it varies which element is missing. Sometimes it is all elements, sometimes it is only some.
Other times, everything loads but with incorrect styling - as you are seeing.
It looks like v1.3.0 fixed most of the issues with this release. Thanks!!
I do notice theres still an issue with the tapbar for the minimalist-ios-tapbar theme. The hamburger menu lines and the āā¦ā show there while it should only show the ātabsā. Wonder what changed that would require a theme update?
The hamburger menu is added as there were some rumors within the beta that the swiping to get the sidebar could be deprecated for the ios-app. For now at least you are able to show the sidebar
PS; Due to the changes to the header in the frontend this was the quickest method to get everything working.
Just updated and the mobile tapbar isnāt sticky to the bottom when I scroll anymore. Iāve tried uninstalling the iOS app to clear cache and also clearing cache on desktop chrome browser. Any ideas?
After the HA update all my cards had errors but after doing to the UI-m, card mod update and clearing the cache the errors went away. Now that iām home im getting the same error as you
Below is my code for one of rooms if someone sees anything Iām over looking
