đŸŒ» Lovelace UI ‱ Minimalist
I have shortened almost everything for the purpose of overview:
Pastebin Link
The “Scenes” lines would be at: Line 46 to 76
Line 77 to 123 is e.g. a working switch card.
Thank you very much.
Thank you it is just beautiful and easy to use.
I have created a specific card for my ligths using custom:slider-card
light card
light_buttons:
  variables:
    entity: "cover.fibaro_cover_balcon"
  styles:
    card:
      - border-radius: 20px
      - box-shadow: var(--box-shadow)
      - padding: 12px
    grid:
      - grid-template-areas: '"item1" "item2"'
      - grid-template-columns: 1fr
      - grid-template-rows: min-content  min-content
      - row-gap: 12px
  custom_fields:
    item1:
      card:
        entity: "[[[ return variables.entity ]]]"
        name: "[[[ return variables.name ]]]"
        tap_action:
          action: call-service
          service: light.toggle
          service_data:
            entity_id: "[[[ return variables.entity ]]]"
        template:
          - icon_info
          - light
        type: "custom:button-card"
    item2:
      card:
        template: list_items_light
        custom_fields:
          item1:
            card:
              type: custom:slider-card
              radius: 14px
              height: 42px
              mainSliderColorOff: var(--google-grey-500)
              secondarySliderColor: "rgba(var(--couleur-theme),0.05)"
              secondarySliderColorOff: "rgba(var(--couleur-theme),0.05)"
              thumbColorOff: white
          item2:
            card:
              icon: "mdi:palette"
              tap_action:
                action: more-info
              template: widget_icon
@schumijo
hello could you share your file template: list_items_light? thank you
TrĂšs belle interface ! Merci du partage :+1:
Very nice interface! Thanks for sharing :+1:
I would also like the rest of this template. Thanks
Oups sorry :wink:
list_items_light:
  styles:
    card:
      - box-shadow: none
      - padding: 0px
    grid:
      - grid-template-areas: '"item1 item2"'
      - grid-template-columns: 2fr 1fr
      - column-gap: 7px
@tben Already lots of people love your work! :clap:
Why don’t you create a github repository with the cards as generic building blocks? And others enthusiasts with visuals skills like @schumijo could start adding to it!
I could help with the setup if you want, but frontend dev is definitely not my thing unfortunately. That’s why I need something like this where I can just pick the card I want and copy/paste yaml :wink:
Anyway, keep up the good work!
Good Idea @danieldotnl !
I also could help (and even create this repository if needed)
Hi guys :wave: the goal was to share my setup asap. I’ll take care of sharing on Github next week when I return from vacation
FR:
Comme je l’ai dĂ©jĂ  dit : Merci pour le thĂšme et le partage :+1:
Voici une modeste contribution (surtout si c’était dĂ©jĂ  prĂ©sent dans le code :sweat_smile:)
L’ajout par rapport au modĂšle (template) dĂ©jĂ  fournis, est l’utilisation de la clĂ© id afin de combiner plusieurs modĂšle (template) :+1:
EN :
As I said before: Thanks for the theme and sharing :+1:
My small contribution (especially if it was already present in the code :sweat_smile:)
I have added to the template already provided, the id key to merge several template: +1:
Porte / Door :
#Carte/Card
type: custom:button-card
entity: binary_sensor.porte_cuisine
template:
  - icon_info_bg
  - ouverture_porte
#ModĂšle/Template
button_card_templates:
  ouverture_porte:
    template:
      - rouge_on
      - vert_off
    state:
      - icon: mdi:door-open
        label: Porte Ouverte
        value: 'on'
      - icon: mdi:door-closed
        label: Porte Fermée
        value: 'off'
FenĂȘtre/Window
#Carte/Card
entity: binary_sensor.fenetre_bureau
template:
  - icon_info_bg
  - ouverture_fenetre
#ModĂšle/Template
  ouverture_fenetre:
    template:
      - rouge_on
      - vert_off
    state:
      - icon: mdi:window-open-variant
        label: FenĂȘtre Ouverte
        value: 'on'
      - icon: mdi:window-closed-variant
        label: FenĂȘtre FermĂ©e
        value: 'off'
ModĂšles inclus dans les modĂšles / Templates includes in template (inception :wink: ) :wink:
  vert_off:
    state:
      - id: vert_off
        styles:
          icon:
            - color: rgba(var(--couleur-vert),1)
          img_cell:
            - background-color: rgba(var(--couleur-vert), 0.2)
        value: 'off'
  vert_on:
    state:
      - id: vert_on
        styles:
          icon:
          img_cell:
        value: 'on'
  rouge_on:
    state:
      - id: rouge_on
        styles:
          icon:
            - color: rgba(var(--couleur-rouge),1)
          img_cell:
            - background-color: rgba(var(--couleur-rouge), 0.2)
        value: 'on'
  rouge_off:
    state:
      - id: rouge_off
        styles:
          icon:
          img_cell:
        value: 'off'
Edit :
Merci beaucoup, trĂšs jolie
Thank you very much it makes it really pretty:
This will be the next scoop here, looking forward to it.
J’ai retravaillĂ© la carte alarme pour qu’elle colle mieux au dĂ©sign. Je laisse le code pour ceux qui veulent l’amĂ©liorer :+1:
I reworked the alarm card to match the minimalist design. I share the code for those who want to improve it :+1:
type: vertical-stack
cards:
  - card:
      entity: alarm_control_panel.alarme
      states:
        - arm_home
      style:
          ha-card > ha-label-badge{
            --alarm-state-color: var(--google-green-500) !important;
          ha-card{
            padding-top: 16px;
            padding-bottom: 12px !important;
            border-radius: 21px;
          ha-card > h1{
             padding-top: 0;
             color: transparent;
          ha-card > h1::before{
             content: "Désactivée";
             color: var(--google-green-500);
             position: absolute;
             font-variant: small-caps;
          #alarmCode{
            display: none;
          #keypad{
            display: none !important;
        '#armActions':
          mwc-button:
              #button > span.slot-container{
                color: transparent;
                position: absolute;
              #button{
                width: 150px;
              #button > span.slot-container::before{
                color: var(--mdc-theme-primary, #6200ee);
                content: "Activer";
                margin: 0 0 0 50%;
      title: Alarme
      type: alarm-panel
    conditions:
      - entity: alarm_control_panel.alarme
        state: disarmed
    type: conditional
  - card:
      states:
        - arm_home
      title: Alarme
      type: alarm-panel
      style:
            --alarm-state-color: var(--google-red-500) !important;
          ha-card{
            padding-top: 16px;
          ha-card > h1{
             padding-top: 0;
             color: transparent;
             content: "Activée";
             color: var(--google-red-500);
             position: absolute;
        '#armActions':
          mwc-button:
                color: transparent;
                position: absolute;
              #button{
                width: 150px;
                content: "DĂ©sactiver";
                margin: 0 0 0 50%;
        '#keypad':
          mwc-button:
              #button{
                border-radius: 12px
    conditions:
        state_not: disarmed
    type: conditional
Il reste a reprendre les couleurs
 Fait
It would be necessary to use the colors of the theme
 Done
this is sexy. many thanks.
Thanks a lot guys !
Sans optimiser le code, voici 2 nouvelles cartes que j’utilise.
Without optimizing templates, 2 cards that I use (like covers).
@tben : correct them if you want, I’m not a designer
#templates
  list_items_1:
    styles:
      card:
        - box-shadow: none
        - padding: 0px
      grid:
        - grid-template-areas: '"item1"'
        - column-gap: 7px
  garage_button:
    variables:
      entity: binary_sensor.default
      icon: mdi:home
      entity_command: input_boolean.default
    styles:
      card:
        - padding: 12px
      grid:
        - row-gap: 12px
    custom_fields:
      item1:
        card:
          entity: '[[[ return variables.entity ]]]'
          name: '[[[ return variables.name ]]]'
          tap_action:
            action: more-info
          template:
            - icon_info
            - ouverture
          state:
            - icon: mdi:garage-open-variant
              value: 'on'
              label: Ouvert
            - icon: mdi:garage-variant
              value: 'off'
              label: Fermé
      item2:
        card:
          template: list_items_1
          custom_fields:
            item1:
              card:
                icon: '[[[ return variables.icon ]]]'
                tap_action:
                  service: input_boolean.turn_on
                  service_data:
                    entity_id: '[[[ return variables.entity_command ]]]'
  portail_close_button:
    variables:
      icon: mdi:home
    styles:
      card:
        - padding: 12px
      grid:
        - row-gap: 12px
    custom_fields:
      item1:
        card:
          tap_action:
            action: more-info
          template:
            - icon_info
            - ouverture
          state:
            - icon: mdi:gate-open
              value: 'on'
              label: Ouvert
            - icon: mdi:gate
              value: 'off'
              label: Fermé
      item2:
        card:
          custom_fields:
            item1:
              card:
                icon: mdi:arrow-left-bold
                tap_action:
                  service_data:
  list_items_2:
    styles:
      card:
        - box-shadow: none
        - padding: 0px
      grid:
        - grid-template-columns: 1fr 1fr
        - column-gap: 7px
  portail_button:
    variables:
      entity_pieton: input_boolean.default
      entity_voiture: input_boolean.default
    styles:
      card:
        - padding: 12px
      grid:
        - row-gap: 12px
    custom_fields:
      item1:
        card:
          tap_action:
            action: more-info
          template:
            - icon_info
            - ouverture
          state:
              value: 'on'
              label: Ouvert
            - icon: mdi:gate
              value: 'off'
              label: Fermé
      item2:
        card:
          template: list_items_2
          custom_fields:
            item1:
              card:
                icon: mdi:run
                tap_action:
                  service_data:
                    entity_id: '[[[ return variables.entity_pieton ]]]'
            item2:
              card:
                icon: mdi:car
                tap_action:
                  service_data:
                    entity_id: '[[[ return variables.entity_voiture ]]]'
#cards
type: grid
cards:
  - type: horizontal-stack
    cards:
      - type: conditional
        conditions:
          - entity: binary_sensor.door_012
            state: 'off'
        card:
          variables:
            entity_pieton: input_boolean.portail_pieton_command
            entity_voiture: input_boolean.portail_voiture_command
          template:
            - portail_button
      - type: conditional
        conditions:
            state: 'on'
        card:
          variables:
            entity_command: input_boolean.portail_pieton_command
          template:
            - portail_close_button
    cards:
      - type: conditional
        conditions:
          - entity: binary_sensor.porte_du_garage
            state: 'off'
        card:
          variables:
            entity_command: input_boolean.garage_command
            icon: mdi:arrow-up-bold
          template:
            - garage_button
      - type: conditional
        conditions:
            state: 'on'
        card:
          variables:
            icon: mdi:arrow-down-bold
          template:
            - garage_button
columns: 2
square: false
détecteur de fumée / smoke detector
#card:
entity: binary_sensor.smoke_sensor_salon
template:
  - icon_info_bg
  - ouverture
state:
  - icon: mdi:fire
    value: 'on'
    label: Incendie !
  - icon: mdi:shield-check
    value: 'off'
    label: RAS
Toujours avec l’utilisation des id / Always with id key :
#template
  ouverture:
    template:
      - rouge_on
      - vert_off
    state:
      - label: Ouvert(e)
        value: 'on'
      - label: Fermé(e)
        value: 'off'
J’aime vraiment le rendu et je suis sĂ»r que @tben tu pourras rendre les cartes encore plus belles :+1:
Edit for bilingual : I really like this theme and I’m sure @tben you can make the cards look even better
Toujours en partant de l’existant, voici pour mes volets somfy :
Modification of the initial code for my somfy shutters :
#templates
  cover_somfy:
    tap_action:
      action: more-info
    icon: |
          var icon = 'mdi:window-shutter';
          if (entity.attributes.current_position == 0){
          } else
            var icon = 'mdi:window-shutter-open';
          return icon ;
    label: |-
        if (entity.state == 'opening'){
            return 'Ouverture';
        else if (entity.state == 'closing'){
            return 'Fermeture';
        else{
            var etat = "Fermé";
          }else if (entity.attributes.current_position == 100){
            var etat = "Ouvert" ;
          }else{
            var etat = (entity.attributes.current_position) + '%' ;
          return etat ;
    state:
      - styles:
          icon:
          img_cell:
        value: closed
      - styles:
          icon:
            - color: rgba(var(--couleur-jaune),1)
          img_cell:
            - background-color: rgba(var(--couleur-jaune), 0.2)
        value: open
      - styles:
          icon:
            - color: rgba(var(--couleur-bleu),1)
          img_cell:
            - background-color: rgba(var(--couleur-bleu), 0.2)
        value: opening
      - styles:
          icon:
          img_cell:
        value: closing
  list_items_cover_favorite:
    styles:
      card:
        - box-shadow: none
        - padding: 0px
      grid:
        - grid-template-areas: '"item1 item1 item2"'
        - grid-template-columns: 1fr 1fr 1fr
        - column-gap: 7px
  cover_buttons_with_favorite:
    variables:
      entity: cover.default
      sun_position: 0
    styles:
      card:
        - padding: 12px
      grid:
        - row-gap: 12px
    custom_fields:
      item1:
        card:
          template: list_items_cover_favorite
          custom_fields:
            item1:
              card:
                tap_action:
                  action: more-info
                template:
                  - icon_info
                  - cover_somfy
            item2:
              card:
                icon: mdi:weather-sunset-down
                tap_action:
                  service: cover.set_cover_position
                  service_data:
                    entity_id: '[[[ return variables.entity ]]]'
                    position: '[[[ return variables.sun_position ]]]'
      item2:
        card:
          custom_fields:
            item1:
              card:
                tap_action:
                  service: cover.close_cover
                  service_data:
            item2:
              card:
                icon: mdi:pause
                tap_action:
                  service: cover.stop_cover
                  service_data:
            item3:
              card:
                icon: mdi:arrow-up
                tap_action:
                  service: cover.open_cover
                  service_data:
#carte
    template: cover_buttons_with_favorite
    variables:
      entity: cover.volet_parent
      sun_position: 13
Pour l’aspirateur / Vacuum :
La carte / edit for bilingual card :
#card
template: aspiro
variables:
  in_progress: Maison
  color: couleur-rouge
entity: script.aspiro_maison
icon: mdi:home
#template
  aspiro:
    variables:
      color: default
      in_progress: default
      script: default
    show_label: true
    label: |
        if (states["input_select.vacuum_aspiro_in_progress"].state == variables.in_progress){
            return '💧';
        else if (states["input_select.vacuum_aspiro_last"].state == variables.in_progress){
            return '✔'
    styles:
      card:
        - padding: 10px 0px 8px 0px
      grid:
        - grid-template-areas: '"i" "n" "l"'
      name:
        - margin-top: 10px
        - justify-self: center
        - font-weight: bold
        - font-size: 14px
      label:
        - align-self: start
        - font-weight: bolder
        - font-size: 12px
        - filter: opacity(40%)
        - animation: |
                  return 'blink 0.9s ease infinite';
      icon:
        - color: '[[[ return ''rgb(var(--'' + variables.color + ''))'' ]]]'
      img_cell:
        - background-color: '[[[ return ''rgba(var(--'' + variables.color + ''),0.2)'' ]]]'
        - border-radius: 50%
        - place-self: center
        - width: 42px
        - height: 42px
    tap_action:
      service: script.turn_on
      service_data:
        entity_id: '[[[return entity.entity_id]]]'
    name: '[[[return entity.entity_id]]]'
Merci / edit for bilingual : Thanks @tben :heart:
Please use the English language for forum posts to be inclusive of the majority and to enable effective moderation.
Come on the guy has been translating everything into English. Bilingual is fine with me.
The replies that were deleted as a result of a moderation request were not bi-lingual. The bi-lingual posts were left as perfectly acceptable.
