Strange, it works on my setup in light and dark mode.
This is my themes-file i have in use: minimalist-mobile.yaml · GitHub
Hi again, the chip_icon_state card doesn’t update the state of the provided entity. I have no clue whats wrong. In the “normal” card everything works
Any help is much appreciated
- type: 'custom:button-card'
template: chip_icon_state
variables:
ulm_chip_icon_state_icon: '☕'
ulm_chip_icon_state_entity: group.espresso
tap_action:
action: call-service
service: switch.toggle
service_data:
entity_id: group.espresso
Love this!!! reminds me of Smartthings
I would guess it relates to this: `triggers_update` doesn't accept javascript templates · Issue #35 · UI-Lovelace-Minimalist/UI · GitHub
In your card you can just add:
triggers_update: group.espresso
How do I add so that I can change color of my lamps? Using Light Slider Card (collapse) right now…
Can you tell me the magic behind the recently used (zuletzt verwendet) row in your dashboard?
great that did the trick. I had put it in the card template, but that wasn’t working
I have the samt thought. I’m thinking about a small button to have under or next to my sliders that triggers different colors or brightness. But Im not that great with building templates…
the other way is that someone implements popup sliders.
Hi guys, it took a while, but here once again a new release. Yippie!!
Unfortunately, @Paddy0174 hasn’t been active on Github or the forum for over a month now. We have been trying to reach him via private messages. However, without success. At this point, no matter where you are, love to @Paddy0174 . We all hope you are doing well!
Since all the bug reports and pull requests have piled up, @TBens has kindly granted some contributors the rights to manage the UI github repo. Please bear with us if things don’t run smoothly at the beginning. We still have to learn how to manage a github repo ourselves.
Unfortunately, @TBens has not been able to give us permissions to the wiki page, or its repository, which is why it is not yet as up-to-date with this release. So you should have a close look at this release message and the corresponding commits to avoid misunderstandings.
We are also trying to get permissions for the wiki page to bring it up to date as soon as possible.
But now, without further ado, to the new release. We hope you enjoy it and thanks to all contributors!
@saxel has done an excellent job of reworking the Vertical buttons custom state.
However, a few old habits had to be cut off, concerning the specification of the variables for the colors of the vertical_buttons
If any of you have used this before, you should take a look at @saxel’s pull request to get a better understanding of the new configuration:
#66
Can you post the code please
If anyone interested, I fixed the PS4 custom card. Also made a custom media player card that fixed some issues with Sonos + added the volume level after the attribute.source.
Really cool! It would be great if you could create a pull request in the repo to share your changes and additions with everyone (if you want).
Pull requests · UI-Lovelace-Minimalist/UI (github.com)
Will be glad to share it with the community! Going to take a nap now and will make a pull request tomorrow. Btw, the Chips with mdi support is great!
How did you keep the padding with swipe-card? Can you share your swipe-card config?
This reduced the space between cards to zero:
- type: custom:swipe-card start_card: 1 parameters: grabCursor: true centeredSlides: false slidesPerView: '3' cards: - type: 'custom:button-card'
This is how I configured my waste collector entities to only show when less than 5 days in the future:
- type: "custom:auto-entities"
card:
type: "custom:button-card"
template: custom_card_paddy_waste_collection
entities:
- sensor.afval_rest
- sensor.afval_pmd
- sensor.afval_papier
- sensor.afval_glas
- sensor.afval_gft
filter:
exclude:
- attributes:
daysTo: "> 5"
show_empty: false
sort:
method: none
unique: true
I can’t see what I’m doing wrong here, but with this configuration, no entity shows up. As if the attribute is not read.
If I play with the filter in order to show entities, the custom button-card doesn’t recognize the entities-id. In case you wonder: the entities names are correct, I can show them in a horizontal stack.
I think the easiest way is to create template-sensor like this:
sensors:
current_lights_on:
friendly_name: All Lights Currently On
value_template: >-
{{ states.light|selectattr('state','equalto','on')|list|length }}
Or when you just want to count specific lights, create an light group with those lights an count only the lights within this group
sensors:
current_lights_on:
value_template: >-
{{ expand('group.all_light_entities')|selectattr('state','eq','on')|list|count }}
Sorry for the late reply, like @Noah mentioned i first made a lights group and used a template sensor as my entity for the chip_state_icon.
Great work!
Saw that there is something ongoing regarding popup cards? I would love it to change colors / color temperature or to rotate covers. When would this be available or could there something be shared here?
