🌻 Lovelace UI • Minimalist
What I did…
Create a blank new Lovelace dashboard. Use UI mode. Install Grid Card, or use vertical and horizontal card stack, and play around with the standard Home assistant cards (ie. light or button card).
Create the LAYOUT you find nice.
Then you have the WAY of sorting the buttons you desire, and from there you lift applicable code to your Minimalist UI dashboard :slight_smile:
Hey Noah,
Looks great with the background :slight_smile: where did you put it in the configuration ? Can you please help to archive this ?
Thank you very much,
sven
Has anyone implemented a layout with a sidebar and can give a hint what a good way doing it? I would like to have a sidebar with clock, date and weather info + maybe calender for my wall-mounted tablet.
thanks
Flave
Pretty much what I’m doing. I’m just looking for the code to lift. :rofl:
Hey all! Firstly I love this theme, it’s aesthetic, easy to use, and honestly exactly what I’ve been looking for!
How do I modify the point_per_hour and hours_to_show when using the graph card? I tried adding it under the definition of the card (same level as type, template, and variables) and also within variables but didn’t have any luck. Do I need to create a custom template with a different amount of hours? or is the syntax slightly different since it’s being called by the button-card?
And also multi coloured graphs? I have one that shows my draw from the grid, I had it green when I was feeding power and red when drawing power.
Here’s my power dashboard :slight_smile:
and summary page
thank you very much!
Are you using UI-mode or .yaml?
If you want help to create a mockup/the frame work for something, make a hand drawn skiss, post it, and We will help you out!
:love_you_gesture:
Hey, maybe you’ll get lucky with my custom graph card. Let me know if you need help adding something for your purpose.
Variables explained:
hours: hours to show (default 24)
bar: set it to true if you want a bar graph
graph_color: color of the graph (red, yellow, blue, green) dont use color codes!
custom_icon: custom mdi-icon
name: null custom name
Use
type: "custom:button-card"
template: custom_card_graph
entity: sensor.waschmaschine_verbrauch
variables:
  bar: "true"
  custom_icon: mdi:washing-machine
Template
custom_card_graph:
  show_icon: false
  show_name: false
  styles:
    grid:
      - grid-template-areas: '"item1" "item2"'
      - grid-template-columns: 1fr
      - grid-template-rows: min-content  min-content
    card:
      - border-radius: var(--border-radius)
      - box-shadow: var(--box-shadow)
      - padding: 0px
  variables:
    hours: 24
    bar: false
    graph_color: red
    custom_icon: null
  custom_fields:
    item1:
      card:
        type: 'custom:button-card'
        icon: '[[[ return variables.custom_icon ]]]'
        template:
          - icon_info
          - card_generic
        styles:
          card:
            - box-shadow: none
            - border-radius: var(--border-radius) var(--border-radius) 0px 0px
            - padding: 12px
        entity: '[[[ return entity.entity_id ]]]'
        name: '[[[ return variables.name == "null" ? entity.friendly_name : variables.name ]]]'
    item2:
      card:
        type: 'custom:mini-graph-card'
        entities:
          - entity: '[[[ return entity.entity_id ]]]'
        line_color: "[[[ return 'rgba(var(--color-' + variables.graph_color + '),1)'; ]]]"
        hours_to_show: '[[[ return variables.hours ]]]'
        show:
          graph: '[[[ return variables.bar === "true" ? "bar" : "line"; ]]]'
          icon: false
          legend: false
          state: false
        style: |
          ha-card {
            box-shadow: none;
            border-radius: var(--border-radius);
When using the custom_card_tpx01_aircondition and trying to adjust the temperature up or down I get this:
The card works fine other than that and if I hold for more info and use the up and down arrows it works fine!
Can you please open a bug report on the UI repo in this? The Template shouldn’t use any scripts that you dont have on your system :wink:
I had to make my own scripts for temp up and down and just named them the same :slight_smile:
increment_climate_temperature:
  alias: increment_climate_temperature
  sequence:
  - service: climate.set_temperature
    data_template:
      entity_id: climate.vent_vsr500
      temperature: '{{(state_attr(''climate.vent_vsr500'' , ''temperature'')|round(0))
        + 1 }}'
  mode: single
decrease_climate_temperature:
  alias: decrease_climate_temperature
  sequence:
    data_template:
        - 1 }}'
  mode: single
Alright! But how do I if I have multiple ACs? Thailand is hot :joy:
For example I have climate.ac_bedroom, climate.ac_livingroom, climate.ac_guestroom, climate.ac_office
Thanks for the help!
Probably have to do one script per maybe? And then just name them differently and change the script called in each card. Maybe there is some templating possibility that I don’t know off
How do I change the script in each card then? This is what I have now?
        template: custom_card_tpx01_aircondition_with_buttons
        variables:
          entity: climate.ac_livingroom
EDIT: Oh I guess I’ll have to make a custom_card for each AC…
Yes, do a custom template for each of them, where you the specific script for each room. I don’t know if there’s an easier way?
So one of these for each rooms - with different script
custom_card_tpx01_aircondition:
  template:
    - ulm_language_variables
    - custom_card_tpx01_aircondition_language_variables
  tap_action:
    action: more-info
  icon: |
        if (entity.state =='dry') {
          return 'mdi:water';
        } else if (entity.state =='heat') {
          return 'mdi:radiator';
        } else if (entity.state =='cool') {
          return 'mdi:snowflake';
        } else if (entity.state =='fan_only') {
          return 'mdi:fan';
        return 'mdi:air-conditioner';
  label: >-
        if (entity.state =='off') {
          return variables.ulm_off;
        } else if (entity.state =='dry') {
          return variables.custom_card_tpx01_aircondition_dry;
          return variables.custom_card_tpx01_aircondition_heat;
        } else if (entity.state =='heat_cool') {
          return variables.custom_card_tpx01_aircondition_heat_cool;
          return variables.custom_card_tpx01_aircondition_cool;
          return variables.custom_card_tpx01_aircondition_fan_only;
        return entity.state;
  state:
    - operator: template
      value: >
          return entity.state != 'off';
      styles:
        icon:
          - color: 'rgba(var(--color-blue),1)'
        img_cell:
          - background-color: 'rgba(var(--color-blue),0.2)'
custom_card_tpx01_aircondition_with_buttons:
  variables:
  styles:
    grid:
      - row-gap: 12px
    card:
      - padding: 12px
  custom_fields:
    item1:
      card:
        type: custom:button-card
        template: list_items_favorite
        custom_fields:
          item1:
            card:
              template:
                - icon_info
              tap_action:
                action: more-info
                    if (variables.name == null) {
                      return variables.entity;
                    return variables.name;
              entity: '[[[ return variables.entity ]]]'
          item2:
            card:
              type: horizontal-stack
              cards:
                - type: conditional
                  conditions:
                    - entity: '[[[ return variables.entity ]]]'
                      state: 'off'
                  card:
                    template: widget_icon
                    tap_action:
                      action: call-service
                      service: climate.set_hvac_mode
                      service_data:
                        entity_id: '[[[ return variables.entity ]]]'
                        hvac_mode: 'cool'
                    icon: mdi:power
                - type: conditional
                  conditions:
                      state_not: 'off'
                  card:
                    tap_action:
                      service_data:
                        hvac_mode: 'off'
                    icon: mdi:power-off
    item2:
      card:
        custom_fields:
          item1:
            card:
              tap_action:
                service: script.decrease_climate_temperature
                service_data:
              icon: 'mdi:minus'
          item2:
            card:
              template: widget_temperature
              tap_action:
                action: none
              icon: 'mdi:temperature-celsius'
          item3:
            card:
              tap_action:
                service: script.increment_climate_temperature
                service_data:
              icon: 'mdi:plus'
list_items_favorite:
  styles:
    grid:
      - grid-template-areas: '"item1 item1 item2"'
      - grid-template-columns: 1fr 1fr 1fr
      - column-gap: 7px
    card:
      - box-shadow: none
      - padding: 0px
widget_temperature:
  tap_action:
    action: toggle
  color: var(--google-grey-500)
  show_icon: false
  show_name: false
  show_label: true
  label: |-
        var temperature = entity.attributes.temperature;
        if (temperature == null) {
          var temperature = '-';
        return temperature + '°C'
  styles:
    label:
      - color: 'rgb(var(--color-theme),0.9)'
    grid:
      - grid-template-areas: '"l"'
    card:
      - box-shadow: none
      - padding: 0px
      - background-color: 'rgba(var(--couleur-theme),0)'
      - border-radius: 14px
      - place-self: center
      - height: 42px
Or maybe if you skip the service_data in the script, you don’t have to make one for each single room - as the template includes the sercive_data allready. I’m not sure?
Thinking I might just rename the cards and then just call the correct card for each room with the script specific for the room. Might be the easiest way for me at least! :slight_smile:
BTW. After adding the script you sent it works great in the bedroom. :slight_smile:
Hehe,
Yeah, my knowledge of doing thing the easy way out is not too great, so I often end up doing thing more complex then they need to be
There are several ways to insert a background image. I have solved it via the theme, so that I can define a separate image for the dark mode and the normal mode. For this I added the following entry in the file ā€œminimalist-desktop.yamlā€:
  modes:
    light:
      background-image: center / cover no-repeat url("https://img.freepik.com/free-vector/hand-painted-watercolor-pastel-sky-background_23-2148902771.jpg?size=626&ext=jpg") fixed
I have added the same entry to the dark mode with a different image. The last thing to do is to add the entry ā€œbackground: var(–background-image)ā€ to the ā€œlovelace-minimalist.yamlā€. For me the file looks like this:
button_card_templates: !include_dir_merge_named minimalist-templates/
background: var(--background-image)
# VIEW HOME
  - title: Zuhause
    path: home
    cards:...
With this method, the background image is automatically applied to all views.
