Noah
(Noah)
December 17, 2021, 5:09pm
724
Here is the code of the template:
card_battery_with_charging_notification:
template:
- icon_info_bg_battery
triggers_update: all
hold_action:
action: more-info
styles:
icon:
- color: 'rgba(var(--color-theme),0.9)'
label:
- align-self: end
- justify-self: start
- font-weight: bold
- font-size: 14px
- margin-left: 12px
- filter: opacity(100%)
name:
- align-self: start
- font-weight: bolder
- font-size: 12px
- filter: opacity(40%)
- margin-left: 12px
grid:
- grid-template-areas: '"i l" "i n"'
- grid-template-columns: min-content auto
- grid-template-rows: min-content min-content
icon: |
var icon = "mdi:help-circle-outline";
var battery = variables.ulm_card_battery_attribute !== null
? states[entity.entity_id].attributes[variables.ulm_card_battery_attribute]
: states[entity.entity_id].state;
if (battery == 100) {
icon = "mdi:battery";
} else if (battery >= 90) {
icon = "mdi:battery-90";
} else if (battery >= 80) {
icon = "mdi:battery-80";
} else if (battery >= 70) {
icon = "mdi:battery-70";
} else if (battery >= 60) {
icon = "mdi:battery-60";
} else if (battery >= 50) {
icon = "mdi:battery-50";
} else if (battery >= 40) {
icon = "mdi:battery-40";
} else if (battery >= 30) {
icon = "mdi:battery-30";
} else if (battery >= 20) {
icon = "mdi:battery-20";
} else if (battery >= 10) {
icon = "mdi:battery-10";
} else {
icon = "mdi:battery-outline";
return icon;
label: |
return battery + "%";
card_battery_with_alert:
template:
- icon_info_bg
tap_action:
action: more-info
variables:
ulm_card_battery_attribute:
state:
- value: '[[[return variables.ulm_card_battery_threshold]]]'
operator: '<='
styles:
custom_fields:
notification:
- border-radius: 50%
- position: absolute
- left: 38px
- top: 8px
- height: 16px
- width: 16px
- border: 2px solid var(--card-background-color)
- font-size: 12px
- line-height: 14px
- background-color: >
return "rgba(var(--color-red),1)";
icon: |
} else {
return icon;
label: |
return states[entity.entity_id].attributes.friendly_name;
styles:
icon:
label:
- align-self: end
- font-weight: bold
- font-size: 14px
- margin-left: 12px
name:
- align-self: start
- text-align: start
- font-size: 12px
- margin-left: 12px
grid:
custom_fields:
notification: >
if (entity.state <= variables.ulm_card_battery_threshold){
return `<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: var(--primary-background-color);"></ha-icon>`
And that’s how to use the template:
type: 'custom:button-card'
template: card_battery_with_alert
variables:
ulm_card_battery_threshold: 40
klidberg
(Kim Lidberg)
December 17, 2021, 5:38pm
725
After updating Home assistant to latest version I get this every now and then on my android phone, my wifes iPhone and on the web gui. Sometimes it works but usually after a few refreshes.
Why?
CM000n
(Simon)
December 17, 2021, 6:29pm
726
Did you tried to delete your cache on your devices? Nothing changed on the code for the light cards with sliders on last release.
klidberg
(Kim Lidberg)
December 17, 2021, 6:58pm
727
That did the tricks! Now it is working again! Thanks!
Andy_Miller
(Andy Miller)
December 17, 2021, 9:32pm
728
Hi there im fairly new to to home assistant.
Im currently in the process of designing my first dashboard to use on a pair of fire tab 8’s.
I would like to arrange these in grids of 4 but when i try to add a 3rd card it goes across the row.
What command do i use to make it drop below the 1st 2 cards??
Thanks.
Hi
You need to use either Grid card or a combination of vertical stack followed by horizontal stack
Drealine
(Drealine)
December 18, 2021, 1:45pm
730
Triggers_update not work if it’s set on buttons card template. Only work at the top level of config card on the main UI dashboard.
Why ? Maybe set this on template card not work at all. If it’s the problem, we need to change this conf on the Github repo.
Thank you for your answer.
CM000n
(Simon)
December 18, 2021, 2:53pm
731
Can you please open a bug report on the repo with some example code. Thx
Andy_Miller
(Andy Miller)
December 18, 2021, 4:12pm
732
i figured it thanks for your pointers.
Also does anyone know if you can color the battery level/state cards??
Im trying to see if below a certain percent you can make the icon green and above a % make it green??
thanks.
He (or she) who waits, shall be rewarded.
(it is merged, and will most likely be present in the next release)
UI-Lovelace-Minimalist:dev
← vncnt-dev:vncnt_battery
opened 04:49AM - 16 Dec 21 UTC
I improved the "card_battery" card for users of the official Home Assistant Comp… anion App, which indicate whether and how the device is being charged and colors the icon based on the battery level.
(no braking changes)
wireless charging | wired charging
warning color | danger color
example config:
```yaml
- type: 'custom:button-card'
entity: sensor.mi_9_battery_level
variables:
ulm_card_battery_battery_charger_type_entity_id: sensor.mi_9_charger_type
ulm_card_battery_battery_battery_level_danger: 30
ulm_card_battery_battery_battery_level_warning: 80
<table>
<tr>
<th>Variable</th>
<th>Example</th>
<th>Required</th>
<th>Explanation</th>
</tr>
<tr>
<td>entity</td>
<td>sensor.yourSmartphone_battery_level</td>
<td>true</td>
<td>This is your battery entity</td>
</tr>
<tr>
<td>ulm_card_battery_attribute</td>
<td>battery_attribute</td>
<td>false</td>
<td>If your entity provides the battery percent in an attribute (= not as an own sensor), fill in the attribute's name here. E.g. if you have `sensor.livingroom_thermometer` and the attribute for your battery power is `sensor.livingroom_thermometer.attributes.battery_percent`, you fill in battery_percent here.</td>
</tr>
<tr>
<td>ulm_card_battery_battery_state_entity_id</td>
<td>sensor.yourSmartphone_battery_state</td>
<td>false</td>
<td>Entity that holds the battery state (charging/discharging). If provided, the Icon will display the current status.</td>
</tr>
<tr>
<td>ulm_card_battery_charger_type_entity_id</td>
<td>sensor.yourSmartphone_charger_type</td>
<td>false</td>
<td>Entity that holds the charger type (ac/wireless/none).
This Entity replaces the need for the `ulm_card_battery_battery_state_entity_id` entity.
If provided, the Icon will display the current charger type. <br> This is only useful if you charge your devices Wireless and with cable.</td>
</tr>
<tr>
<td>ulm_card_battery_battery_level_danger</td>
<td>30</td>
<td>true</td>
<td>Changes the color of the Icon, if the battery level falls below the provided value. Must be higher than `ulm_card_battery_battery_level_waring`</td>
</tr>
<tr>
<td>ulm_card_battery_battery_level_waring</td>
<td>50</td>
<td>true</td>
<td>Changes the color of the Icon, if the battery level falls below the provided value.</td>
</tr>
<tr>
<td>ulm_card_battery_color_battery_level_danger: </td>
<td>'var(--google-yellow)'</td>
<td>false</td>
<td>Color of icon if battery level is within the 'danger' zone.
default: 'var(--google-red)'</td>
</tr>
<tr>
<td>ulm_card_battery_color_battery_level_warning:</td>
<td>false</td>
<td>Color of icon if battery level is within the 'warning' zone.
default: 'var(--google-yellow)'</td>
</tr>
<tr>
<td>ulm_card_battery_color_battery_level_ok: </td>
<td>'var(--google-green)'</td>
<td>false</td>
<td>Color of icon if battery level is not within the 'danger' or 'warning' zone.
default: 'var(--google-green)'</td>
</tr>
</table>
Andy_Miller
(Andy Miller)
December 18, 2021, 4:40pm
734
Sorry to be a pain but i have another question.
I have created the following code/page.
It will be living on a hozitonzal firetab. currently it looks very squished in the middle of the screen and the text from the buttons is cut off.
How can i increase column width to increase the width of the buttons?? or do i just need to drop them into another column??
Thanks again.
SildeHoop
(Sil de Hoop)
December 18, 2021, 5:15pm
735
What do you guys think of my card design just need to make it (inspired by 7ahang’s work)
m8, please post the code inside
This kind of block - Preformatted text
Try this;
Try fiddeling with WIDHT
button_card_templates: !include_dir_merge_named minimalist-templates/
swipe_nav:
wrap: false
animate: swipe
skip_tabs:
prevent_default: true
swipe_amount: 30
- title: Telefon Start
path: tel_start
layout:
width: 300
max_cols: 1
type: custom:masonry-layout
badges: []
icon: mdi:sigma
cards:
- type: vertical-stack
cards:
Great idea!
Until now I’ve modified the navigation card to show the temperature of the room.
But your design also fixes the issue of showing the state of lights.
Maybe an idea to add media players as an icon when applicable?
Almost done.
PS: If you (or anyone…) interested PM me so i can send the code and we can finalize the card. I don’t have allot of time the next few weeks so will be great if anyone can help a little.
djacid
(Djacid)
December 19, 2021, 12:33am
740
Nice work. Could you share the code?
klidberg
(Kim Lidberg)
December 19, 2021, 9:13am
743
What’s the easiest way to make a chip to a navigation card?
If I want to navigate to my CCTV view for example?
I did it this way
- type: custom:button-card
template: chip_custom_navigation
variables:
ulm_card_navigate_path: /lovelace-minimalist/tele_media
ulm_card_navigate_title: ""
ulm_card_navigate_icon: mdi:youtube-tv
