Hi @Freshhat
Can you confirm browser_mod is installed ?
Sure it‘s installed using it heavily for some of my automations
Any idea how i could debug why no popup is opening?
When using the pop up code nothing happens
- type: "custom:button-card"
template:
- card_light
- popup_light
entity: light.cuisine
I changed the entity to a few different lights but no pop up
And thank you everyone for the awesome work!
Your configuration seems to be correct.
Can you try to clear your browser cache ?
Can you have a look to Dev console on your web browser (F12) and see if you have error message ?
Last solution, download again Minimalist theme from GitHub and put it in a new folder. Just update the inclusion in your yaml file. On my configuration, sometimes it doesn’t work to overwrite files.
in my case I have this strange output
the light “light.lumiere_salon” is a group of 4 lights.
type: custom:button-card
template:
- card_light
- popup_light
entity: light.lumiere_salon
icon: mdi:sofa
Last question, where can I find “slider-card” ?
@schumijo
You might need to do a hotfix of our popup card.
The slider-card was moved to a new repository. From here to here.
I’m using the new repository but I’m guessing your part of the popup is using the old slider.
@laurentdb
A temporary solution could be to install both cards for now.
@bms thanks for your reply.
The new repository is using
type: custom:my-slider
and the popup template is using
type: custom:slider-card
And I think so that’s why I can’t find it.
The temporary hot fix didn’t solved my issue I still those 4 big circles instead of one…
The definition of the light is like this:
light:
- platform: group
entities:
- light.salon1
- light.salon2
- light.salon3
- light.salon4
Maybe I am doing wrong.
@bms
Thank you for the PR
@laurentdb New version 1.0.0-beta10-hotfix released
Should solve slider card new repository and light group display.
What is required to get the popup card working? I have complete reinstall the UI, clean my caches but still the popup is not opening. I have tried both for light and and a power outlet/switch.
template:
- card_light
- popup_light
entity: light.slaapkamer
template:
- card_power_outlet
- popup_power_outlet
variables:
ulm_card_power_outlet_consumption_sensor: sensor.elektrischdeken_energy
ulm_popup_power_outlet_sensor1: sensor.elektrischdeken_energy
ulm_popup_power_outlet_sensor2: sensor.elektrischdeken_energy
ulm_popup_power_outlet_graph_sensor: sensor.elektrischdeken_energy
entity: switch.elektrischdeken
You need to install the browser_mod
Can I add the same lights to multiple light groups?
Only one way to find out
I don’t know
It works like a charm! thanks
Thanks for all your suggestions, tried it today with your hotfix + reinstalling everything in a new folder. As then also nothing was showing i debugged it in the Browser Console and found out that it’s referring to a line inside button_card.js and after checking this further i found out that with my second Dashboard (Dwains Dashboard) the custom button card from HACS will be overwritten. So i removed this somehow outdated button card from the dwains_dashboard installation folder.
Now everything is working like a charm.
Any ideas why the tv icon is not showing on mobile?
Also the lightbulb is not in the same position as on desktop.
BTW: Thanks for the awesome work!
Is this the view of the companion app or your default webbrowser (desktop/smartphone)? It seems there is a rendering issue. Noticed it with an early version of android 12 after an update of the webview / browser component it got fixed. So first see if you can update your system/app/browser and try again.
Readme updated with all requirements
Its the companion app on iOS iPhone 12 Pro Max.
Ah, ok. Seems webkit ignores for some reason the justify-self property. Like I said I had that problem with chrome on android 12 , too. After an update it was rendered correctly. I wish I could fix it but I have no apple device in my hands. :\
I am trying to create a custom garage door cover card.
I have a sensor that node red-updates when the door is open with the minutes until auto-close
I wanted to display this countdown on the state line of the button instead of the word “open”.
I’m defining the sensor as a variable in the lovelace yaml file, but I cannot figure out how to access the sensor from within the template functions; it keeps throwing an undefined error.
I probably have a variable scope issue, but I’m just learning this and stumped - anyone see anything obvious?
lovelace-minimalist.yaml
- type: 'custom:button-card'
template: card_cover_with_countdown
variables:
ulm_card_cover_with_countdown_name: "Dads Garage Door"
ulm_card_cover_with_countdown_entity: "cover.garagedoor1"
ulm_card_cover_with_countdown_countdown: "sensor.garagecountdown1_2"
In the code below, it works as expected if I replace
variables.ulm_card_cover_with_countdown_countdown
with
‘sensor.garagecountdown1_2’
label: >-
var icon = 'mdi:help-circle';
var countdown = '?';
var countdown = states[variables.ulm_card_cover_with_countdown_countdown].state;
if (typeof states[entity.entity_id].attributes.current_position === 'undefined'){
if (states[entity.entity_id].state == 'closed'){
return variables.ulm_closed;
} else
return countdown + ' m/close';
} else {
if (states[entity.entity_id].attributes.current_position == 0){
} else {
return (countdown ? countdown : '0') + ' m/close';
return icon ;
The full yaml of the new templates are below
(based from cover: and card_cover_with_buttons:)
cover_countdown:
tap_action:
action: more-info
icon: |
var icon = 'mdi:window-shutter';
} else
var icon = 'mdi:window-shutter-open';
} else {
} else
return icon ;
label: >-
} else
} else {
} else {
return icon ;
state:
- operator: template
value: "[[[ return states[entity.entity_id].attributes.current_position != 0; ]]]"
styles:
icon:
- color: "rgba(var(--color-blue),1)"
img_cell:
- background-color: "rgba(var(--color-blue),0.2)"
card_cover_with_countdown:
variables:
ulm_card_cover_with_countdown_name: "n/a"
triggers_update:
- "[[[ variables.ulm_card_cover_with_countdown_entity ]]]"
- "[[[ variables.ulm_card_cover_with_countdown_countdown ]]]"
styles:
grid:
- grid-template-areas: '"item1" "item2"'
- grid-template-columns: 1fr
- grid-template-rows: min-content min-content
- row-gap: 12px
card:
- border-radius: var(--border-radius)
- box-shadow: var(--box-shadow)
- padding: 12px
custom_fields:
item1:
card:
template:
- icon_info
- ulm_language_variables
- cover_countdown
tap_action:
action: more-info
entity: '[[[ return variables.ulm_card_cover_with_countdown_entity ]]]'
name: '[[[ return variables.ulm_card_cover_with_countdown_name ]]]'
item2:
card:
template: list_items
custom_fields:
item1:
card:
template: widget_icon
tap_action:
action: call-service
service: cover.close_cover
service_data:
entity_id: '[[[ return variables.ulm_card_cover_with_countdown_entity ]]]'
icon: 'mdi:arrow-down'
item2:
card:
tap_action:
service: cover.stop_cover
service_data:
icon: 'mdi:pause'
item3:
card:
tap_action:
service: cover.open_cover
service_data:
icon: 'mdi:arrow-up'
