Just a little question, is there a way to activate a scene or automation by a button?
I would like to activate a scene or automation turning all the lights off.
Create an pr and I will also take a look at your code, it is easier for people to help there.
Iām facing the exact same issue as you, with nest as the thermostat. Probably have to proceed with some workaround to mark the thermostat for now, but hopefully I get to finish all the setup to further dive in to debug this issue.
I noticed having the same problem with another custom card (customcard_tpx01_aircodition), so for now the suspect is most likely as @http_edo13 suggest (we might missed some icon templates somewhere). Just for information, do you mind sharing the current frontend integrations you are having @http_edo13 & @micdejo ? For me currently I have:
I have tried a few things but wasnāt able to get it to work. If iām correct the ācustom_card_httpedo13_thermostatā is based of of the ācustom_card_tpx01_airconditionā. Therefore, the problem occurs for both of the cards. I donāt know what is causing the problem though. For now iām using the ācustom_card_mpse_thermostatā which works fine.
yes, my card is based on tpx01 air condition. This is my entire configuration code:
custom_card_httpedo13_thermostat:
template:
- "ulm_language_variables"
- "custom_card_httpedo13_thermostat_language_variables"
tap_action:
action: "toggle"
icon: |
if (entity.attributes.hvac_action == 'heating') {
return "mdi:radiator";
return "mdi:radiator-off";
label: >-
if (entity.state =='off') {
return variables.custom_card_httpedo13_thermostat_off;
} else if (entity.state =='heat') {
return variables.custom_card_httpedo13_thermostat_on;
} else if (entity.attributes.hvac_action == 'heating') {
return variables.custom_card_httpedo13_thermostat_heating;
return entity.state;
state:
- operator: "template"
value: >
return entity.state != 'off';
styles:
label:
- color: |
if (entity.attributes.hvac_action == 'heating'){
return "var(--card-background-color)";
return "rgba(var(--color-theme),0.9)";
name:
- font-weight: "bold"
- color: |
icon:
- color: "rgba(var(--color-red),1)"
img_cell:
- background-color: |
return 'var(--card-background-color)';
return 'rgba(var(--color-red),0.2)';
card:
return '#ff8100';
custom_card_httpedo13_thermostat_with_buttons:
triggers_update: "all"
styles:
grid:
- grid-template-areas: "'item1' 'item2'"
- grid-template-columns: "1fr"
- grid-template-rows: "min-content min-content"
- row-gap: "12px"
card:
- border-radius: "var(--border-radius)"
- box-shadow: "var(--box-shadow)"
- padding: "12px"
if (states[variables.entity].attributes.hvac_action == 'heating'){
return '#ff8100';
tap_action:
action: "call-service"
service: "climate.set_hvac_mode"
service_data:
entity_id: "[[[ return variables.entity ]]]"
hvac_mode: |
if (states[variables.entity].state == "off"){
return 'heat';
} else if (states[variables.entity].state == "heat"){
return 'off';
custom_fields:
item1:
card:
type: "custom:button-card"
template: "list_items_favorite"
styles:
card:
return '#ff8100';
custom_fields:
item1:
card:
template:
- "icon_info"
- "custom_card_httpedo13_thermostat"
tap_action:
service_data:
hvac_mode: |
return 'heat';
return 'off';
if (variables.name == null) {
return variables.entity;
return variables.name;
entity: "[[[ return variables.entity ]]]"
item2:
card:
template: "widget_current_temperature"
tap_action:
action: "toggle"
icon: "mdi:temperature-celsius"
item2:
card:
template: "list_3_items"
styles:
card:
return '#ff8100';
custom_fields:
item1:
card:
template: "widget_icon_for_thermostat"
tap_action:
service: "climate.set_temperature"
service_data:
temperature: "[[[ return (parseFloat(states[variables.entity].attributes.temperature) - 0.5) ]]]"
icon: "mdi:minus"
item2:
card:
template: "widget_temperature"
tap_action:
action: "toggle"
item3:
card:
tap_action:
service_data:
temperature: "[[[ return (parseFloat(states[variables.entity].attributes.temperature) + 0.5) ]]]"
icon: "mdi:plus"
custom_card_httpedo13_thermostat_with_buttons_collapse:
styles:
grid:
- row-gap: "12px"
card:
- padding: "12px"
return '#ff8100';
tap_action:
service_data:
hvac_mode: |
return 'heat';
return 'off';
custom_fields:
item1:
card:
styles:
card:
return '#ff8100';
custom_fields:
item1:
card:
template:
- "icon_info"
tap_action:
service_data:
hvac_mode: |
return 'heat';
return 'off';
item2:
card:
tap_action:
action: "toggle"
item2:
card:
type: "conditional"
conditions:
- entity: "[[[ return states[variables.entity].entity_id ]]]"
state: "heat"
card:
styles:
card:
return '#ff8100';
custom_fields:
item1:
card:
tap_action:
service_data:
icon: "mdi:minus"
item2:
card:
tap_action:
action: "toggle"
item3:
card:
tap_action:
service_data:
icon: "mdi:plus"
widget_current_temperature:
color: "var(--google-grey-500)"
show_icon: false
show_name: false
show_label: true
label: |-
var temperature = entity.attributes.current_temperature;
if (temperature == null) {
var temperature = '-';
return temperature + 'Ā°C'
styles:
label:
- color: |
return 'rgb(var(--color-theme),0.9)';
grid:
- grid-template-areas: "'l'"
card:
- box-shadow: "none"
- padding: "0px"
- border-radius: "14px"
- place-self: "center"
- height: "42px"
return '#ff8100';
widget_temperature:
show_icon: false
show_name: false
show_label: true
label: |-
var temperature = entity.attributes.temperature;
styles:
label:
- color: |
grid:
card:
- padding: "0px"
- height: "42px"
return '#ff8100';
widget_icon_for_thermostat:
tap_action:
action: "toggle"
show_icon: true
show_name: false
styles:
grid:
- grid-template-areas: "'i'"
card:
- padding: "0px"
return 'rgba(var(--color-theme),0.05)';
- height: "42px"
icon:
- color: "rgba(var(--color-theme),0.9)"
color: "var(--google-grey)"
list_items_favorite:
styles:
grid:
- grid-template-areas: "'item1 item1 item2'"
- grid-template-columns: "1fr 1fr 1fr"
- grid-template-rows: "min-content"
- column-gap: "7px"
card:
- padding: "0px"
icon_info:
color: var(--google-grey)
show_icon: true
show_label: true
show_name: true
state:
- styles:
custom_fields:
notification:
- border-radius: 50%
- position: absolute
- left: 24px
- top: -2px
- height: 16px
- width: 16px
- border: 2px solid var(--card-background-color)
- font-size: 12px
- line-height: 14px
- background-color: >
return "rgba(var(--color-red),1)";
value: unavailable
styles:
icon:
- color: 'rgba(var(--color-theme),0.2)'
label:
- justify-self: start
- align-self: start
- font-weight: bolder
- font-size: 12px
- filter: opacity(40%)
- margin-left: 12px
name:
- align-self: end
- font-weight: bold
- font-size: 14px
- margin-left: 12px
state:
- align-self: start
- font-size: 12px
- margin-left: 12px
img_cell:
- background-color: 'rgba(var(--color-theme),0.05)'
- place-self: center
- width: 42px
- height: 42px
grid:
- grid-template-areas: '"i n" "i l"'
- grid-template-columns: min-content auto
- grid-template-rows: min-content min-content
card:
- border-radius: 21px 8px 8px 21px
- box-shadow: none
- padding: 0px
# - background-color: 'rgba(var(--color-theme),0)'
custom_fields:
notification: >
if (entity.state =='unavailable'){
return `<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: var(--primary-background-color);"></ha-icon>`
Hey guys, this is the first theme Iām trying and I really love how easy it is to implement and how it looks like! Thx to @CM000n for sharing your config! But Iām facing a strange issue regarding some CSS styles not being applied when using SSL or opening it locally on a tablet.
Does anyone have an idea what the problem could be?
Just my2cent for this āthemeā:
i rly like itā¦butā¦as for now it needs to be heavily maintained and a lot of effort to implement it into the system. also I have the feeling that it slows down a bit the entire frontend. but this is only a feeling. I rly respect the effort you all put into it and itās often easy to say āwhy canāt I simply click on Ā“install`and everything is fine?ā. I think if this will come to a greater audience it needs to get much easier to install and maintain.
during the last days I found an error in the code generatorā¦solution was adding 2 tabs on a single line. ok, fine for me. I am a technical based project manager for a big company and I like to find solutions by myself. I am rly looking forward on your efforts in making this a fully HACS compatible āThemeā. but I am curious when it comes to upgrading/changing the style of integration, manually vs. hacs. but hey, challenge accepted because this theme is rly so minimalistic that it is pretty much close to perfection
i am still missing a lot of things but I am as stupid as possible so that I am not able to program this on my own or to support in any case of programming. as for now I am still maintaining 2 versions of dashboard. one with HA based cards heavily based on the grid card as a fall back if something went wrong and the āminimalisticā version. a lot of work but hopefully some day there will be only one to maintain
thank you all for your effort!
cheers,
ben
Already sorted. Turns out I could use the entity.state
Iāve created a pull request with the code as well.
Yes, the integration into HACS will probably be a big big breaking change in many places.
Some things will be made easier, but others will not.
At the moment we canāt and donāt want to offer a 1 click solution like dwain or HKI.
Most of the people who have contributed so far are tinkerers themselves and make their contribution because they enjoy it and can learn something new. Nothing more and nothing less.
So letās just see what else the future brings.
Maybe your Theme is just not applied, when you Open it from another device? Seems like it is using the standard theme.
Theme Settings in Home Assistant are per Device.
Please have a look in your Settings.
Hi again,
has anybody a good idea for a lock card or already realized it?
cheers,
ben
I want to use the Minimalist button card templates with the standard UI.
I donāt know where to put the ābutton_card_templates.yamlā and how to include it in the lovelace UI.
can someone please guide me ?
Thank You
Hello erverybody,
has anybody an idea why my popups not working?
I have done everything as described:
When I press a button, it turns dark gray as if trying to open the menu, but nothing happens.
This is my Code for the light button (exactly the same as on the manual):
- type: "custom:button-card"
template:
- card_light
- popup_light
entity: light.terrasse_grillbeleuchtung
Thank you
So I followed the docs and like how itās much easier to work with yaml files than I thought by following the guide, I wonder how do I position cards where I want them though, along with making it into 2 columns instead of 3 as it seems too narrow both on PC and on a tablet.
I have also tried using the template āvertical_buttonsā but canāt put tap_action on it as I did with ācard_scriptā
You can put all of your cards into 2 vertical stacks although this solution wonāt carry over across all all devices. For more control I recommend taking a look at lovelace-layout-card.
Iām not sure about the vertical_buttons so maybe someone else can help you out with that. Hopefully this helps!
looks promising!
I am myself looking to make almost exactly the same card. I have been messing around with no results.
Could you also make a same card for thermostat with at the bottom (off, auto, heat, boost)!?
would highly appreciate it. Thanks.
Oh man, thx - this was the issue. I feel kinda dumb Thank you for your work
Hello, i just discovered this fantastic UI and iām trying to personalize it.
I have a little issue making a custom template.
Iād like to change colors and/or icons
For exemple for a card_input_boolean
here is my code.
custom_card_input_boolean_heat:
template: card_input_boolean
name: "[[[ return entity.attributes.friendly_name != '' ? entity.attributes.friendly_name : entity.entity_id ]]]"
label: >
if (entity.state != 'unavailable'){
if (entity.state == 'on'){
return variables.ulm_on;
} else {
return variables.ulm_off;
} else {
return variables.ulm_unavailable;
state:
- styles:
icon:
- color: 'rgba(var(--color-darkorange),1)'
label:
- color: 'rgba(var(--color-darkorange-text),1)'
name:
img_cell:
- background-color: 'rgba(var(--color-darkorange), 0.2)'
card:
- background-color: 'rgba(var(--color-background-darkorange), var(--opacity-bg))'
value: 'on'
where am i wrong ???
You can take a Look at @CM000n config / github. There is a nice solution to place cards with the grid Layout.
