Great Theme! I installed it now via HACS and migrate my existing config to it
One question: the light slider is not working with light groups (āgroup.lights_xyzā):
however, a brightness slider is available in the ādefaultā view of home assistant for a light group:
do you plan on adding a compatibility for the light slider to work with light groups as well? Would be awesome!
piitaya
(Paul)
January 31, 2022, 8:19am
1362
You can use the light.group platform instead of the group. (Light Group - Home Assistant ).
You will have a better support for all cards
thanks for your suggestion, but unfortunately it doesnāt work with some of my groups where I bundled light entities and switch entities together switch entities canāt be added to light groups.
RickTSD
(Rick de Jong)
January 31, 2022, 11:01am
1364
Iāve got two questions. A simple one and perhaps a little difficult one.
1- Why is there no āchip forwardā available? Wen navigating between four or five areas, just be able to go back seems a bit as a waste sometimes
2- I donāt get the popup light to work. Iāve tried
- type: "custom:button-card"
template:
- card_light
entity: light.tradfri_lamp_tv_meubel
variables:
ulm_card_light_enable_popup: true
and
template: card_light
variables:
ulm_card_light_enable_slider: true
ulm_card_light_enable_color: true
ulm_card_light_force_background_color: true
Looks like Iāve got all the modules I need
This happens in my console
basbrus
(Bas)
January 31, 2022, 11:15am
1365
Do you have browser-mod also included in your configuration.yaml?
camelen
(John)
January 31, 2022, 11:27am
1367
You can convert switch entities to light entities. Thatās what I have done.
light:
- platform: switch
entity_id: switch.hallway_windows
ohh that sounds nice! Thanks, I will try this one out!
klidberg
(Kim Lidberg)
January 31, 2022, 2:25pm
1369
Got ulm_card_light_enable_popup: true
working while using my desktop and if I use BRAVE browser on my android phone.
But with the HA Companion app on android it doesnt pop up. Any clue why?
Proche72
(Jiri Pragr)
January 31, 2022, 4:44pm
1370
For some reason if using the light theme I cannot see the light bar. When using dark I can see it. Any clues? š¤·š»
basbrus
(Bas)
January 31, 2022, 5:06pm
1371
The theme is not correctly applied. Go to profile and set theme to āminimalist-desktopā or minimalist-mobileā
Proche72
(Jiri Pragr)
January 31, 2022, 5:56pm
1372
Did that on 3 devices and forgot on the 4th š¤¦ thank you, wife acceptance is now fullš
AndiS
January 31, 2022, 6:12pm
1373
Sorry if I missed it, but is there a migration guide from old yaml based integration to HACS integration?
Hi bms,
Is there anyway to add another entity in for a motion sensors below the light switch next to the name and label?
bms
(Bavo)
February 1, 2022, 9:49am
1375
Yes, youāll need to play around with the following lines in my template:
grid:
- grid-template-areas: '"i toggle" "n n" "l l"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: min-content
See here for more documentation on the topic.
Hi Bavo,
Thanks for your advise. Managed to code it in. If any one else is interested in adding this in to their setup. Go easy on me there is properly a better way to code this and space it all about, but Iām still a bit of an amateur of css.
Template Code
room:
tap_action:
action: more-info
#color: var(--google-grey-500)
show_icon: true
show_name: true
show_label: true
label: >-
if (entity.state !='unavailable'){
if (entity.state =='off'){
var bri = Math.round(entity.attributes.brightness / 2.55);
return 'Off';
}else{
return (bri ? bri : '0') + '%';
}else{
return "Unavailable";
styles:
card:
- border-radius: 20px
- box-shadow: var(--box-shadow)
- padding: 12px
- background-color: 'rgba(150, 150, 150, 0.1)'
grid:
- grid-template-areas: '"i toggle" "n motion" "l motion"'
- grid-template-rows: min-content min-content
- align-content: space-evenly
icon:
- filter: opacity(100%)
- height: 30px
- width: 30px
- margin-left: 5px
- margin-top: 2px
- color:
img_cell:
- place-self: start
- width: 42px
- height: 42px
- color:
- margin-top: 5px
name:
- align-self: end
- justify-self: start
- font-weight: bold
- font-size: 11px
- margin-left: 5px
- margin-top: 2px
label:
- align-self: start
- font-weight: bolder
- font-size: 11px
- margin-left: 5px
state:
- align-self: start
- font-size: 12px
- filter: opacity(0%)
- margin-left: 12px
- margin-top: 2px
custom_fields:
toggle:
card:
entity: '[[[ return entity.entity_id ]]]'
name: '[[[ return name ]]]'
state:
- value: 'on'
styles:
icon:
- color: 'rgba(var(--color-yellow),1)'
img_cell:
- background-color: 'rgba(var(--color-yellow), 0.2)'
- value: 'off'
tap_action:
action: toggle
type: 'custom:button-card'
template:
- widget_icon
motion:
card:
state:
- value: 'on'
styles:
icon:
img_cell:
- value: 'off'
tap_action:
action: none
template:
- widget_icon
Lovelace Code
- type: 'custom:button-card'
template:
- room_non_hue
entity: light.cctv10_carport_light
icon: hue:room-carport
label: '[[[ return states["sensor.back_garden_sensor_temperature"].state + "Ā°C" ]]]'
custom_fields:
motion:
card:
entity: binary_sensor.cctv10_carport_motion
tap_action:
action: navigate
navigation_path: '/lovelace-carport-mobile/ui-carport-mobile'`Preformatted text`
klidberg
(Kim Lidberg)
February 1, 2022, 12:51pm
1378
Where do I change these icons so that the text is NOT bold?
EDIT: Nevermind found it and I needed to restart for it work.
guims78
(guims)
February 1, 2022, 3:15pm
1379
i modified the custom card sonos to fit to my request, but i would like to have the background changing, depending on which button i pressed.
For exemple, if the media player is āplayingā and iāve pressed the first button, iād like to have the same image in the background as it is in the button.
Here is my code :
card_media_player_sonos:
show_icon: true
show_entity_picture: false
show_state: false
show_name: true
template:
- "green_playing"
- "icon_info_bg"
- "custom_ulm_language_variables"
label: |
if (entity.state == 'idle'){
return variables.ulm_media_player_off;
if (entity.state == 'paused'){
return variables.ulm_media_player_pause;
if (entity.state == 'playing'){
return variables.ulm_media_player_on + ' ā¢ ' + ( Math.round(entity.attributes.volume_level / 0.01)) + '%';
if (entity.state == 'unavailable'){
return variables.ulm_media_player_unavailable;
if (entity.state == 'off'){
card_media_player_sonos_with_controls:
variables:
ulm_card_media_player_with_controls_name: "No name set"
triggers_update:
- "[[[ ulm_card_media_player_with_controls_entity ]]]"
styles:
grid:
- grid-template-areas: '"item1" "item2" "item3"'
- grid-template-columns: "1fr"
- grid-template-rows: "min-content min-content"
- row-gap: "12px"
card:
- border-radius: "var(--border-radius)"
- box-shadow: "var(--box-shadow)"
- padding: "12px"
custom_fields:
item1:
card:
template:
- "ulm_language_variables"
- "card_media_player_sonos"
tap_action:
action: "more-info"
entity: "[[[ return variables.ulm_card_media_player_with_controls_entity ]]]"
name: "[[[ return variables.ulm_card_media_player_with_controls_name ]]]"
styles:
card:
- box-shadow: "none"
- padding: "0px"
item2:
card:
template: "list_4_items"
custom_fields:
item1:
card:
template: "widget_icon"
tap_action:
action: "call-service"
service: "media_player.media_play_pause"
service_data:
entity_id: "[[[ return variables.ulm_card_media_player_with_controls_entity ]]]"
icon: "mdi:pause"
state:
- value: "paused"
icon: "mdi:play"
- value: "off"
icon: "mdi:play"
item2:
card:
tap_action:
service: "media_player.media_next_track"
service_data:
icon: "mdi:skip-next"
item3:
card:
tap_action:
service: "media_player.volume_down"
service_data:
icon: "mdi:volume-minus"
item4:
card:
tap_action:
service: "media_player.volume_up"
service_data:
icon: "mdi:volume-plus"
item3:
card:
template: "custom_list_5_items"
custom_fields:
item1:
card:
tap_action:
action: call-service
service: media_player.play_media
service_data:
media_content_id: 'http://streaming.radio.rtl2.fr/rtl2-1-44-128'
media_content_type: music
custom_fields:
i: |
<img width= 90% src='/local/icon_radio/RadioRTL2.png'>
item2:
card:
tap_action:
service_data:
media_content_id: 'https://ais-live.cloud-services.paris:8443/rfm.mp3'
custom_fields:
i: |
<img width= 90% src='/local/icon_radio/RadioRFM.png'>
item3:
card:
tap_action:
service_data:
media_content_id: 'https://ais-live.cloud-services.paris:8443/virgin.mp3'
custom_fields:
i: |
<img width= 90% src='/local/icon_radio/RadioVirgin.png'>
item4:
card:
tap_action:
service_data:
media_content_id: 'http://cdn.nrjaudio.fm/audio1/fr/30201/mp3_128.mp3?origine=fluxradios'
custom_fields:
i: |
<img width= 90% src='/local/icon_radio/RadioCherieFM.png'>
item5:
card:
tap_action:
service: spotcast.start
service_data:
uri: "spotify:playlist:6sCtuHWjGDBjY3tPGu3bOo"
shuffle: true
random_song: true
custom_fields:
i: |
<img width= 90% src='/local/icon_radio/Spotify2.png'>
icon_info_bg_sonos:
color: "var(--google-grey)"
show_icon: true
show_label: true
show_name: true
state:
- value: "unavailable"
styles:
custom_fields:
notification:
- border-radius: "50%"
- position: "absolute"
- left: "3px"
- top: "8px"
- height: "18px"
- width: "18px"
- font-size: "12px"
- line-height: "14px"
- background-color: >
return "rgba(var(--color-red),1)";
styles:
icon:
- color: "rgba(var(--color-theme),0.2)"
label:
- justify-self: "start"
- align-self: "start"
- font-weight: "bold"
- font-size: "12px"
- filter: "opacity(40%)"
- margin-left: "12px"
name:
- align-self: "end"
- font-size: "14px"
state:
- font-size: "12px"
img_cell:
- background-color: "rgba(var(--color-theme),0.05)"
- place-self: "center"
grid:
- grid-template-areas: "'i n' 'i l'"
- grid-template-columns: "min-content auto"
card:
- padding: "12px"
green_playing:
state:
- styles:
icon:
- color: "rgba(var(--color-green),1)"
img_cell:
- background-color: "rgba(var(--color-green), 0.2)"
value: "playing"
Can someone help me or give me some clues to code what i wish ?
hi, itās awesome, can you share the code for two solar panels card?
joffrey71
(Joffrey71)
February 1, 2022, 8:05pm
1381
Great job @irmajavi .
Is it possible to share the vacuum card?
Thx
