šŸŒ» Lovelace UI ā€¢ Minimalist
Wow this is a great sketch @cphassistant.
On our long term goals is already also to offer a similar footer navigation as from 7ahangā€™s work that is actually the origin for the design of this UI:
But as @rickstokking already says. It would probably be good if you could post a feature request on github. Then it can be tracked better. :slight_smile:
It would be awesome to go with that tabbar from 7ahang :grinning:
I have created a feature request here Tabbar navigation Ā· Issue #346 Ā· UI-Lovelace-Minimalist/UI Ā· GitHub
Hello, is there a simple way to add an alerte (!) on chip card ?
using a custom definition.
hi,
looks great!
can you please share your cards.
how did you make the title card ? as in your screen shot, Entrance with sub text with temperature and the other icons on the right? could you please share?
thanks.
Hello, here is the code i try to make working.
custom_chip_icon_state:
  template: chip_icon_state
#  triggers_update: "all"
  state:
    styles:
      custom_fields:
        notification:
          - border-radius: "50%"
          - position: "absolute"
          - left: "38px"
          - top: "8px"
          - height: "16px"
          - width: "16px"
          - border: "2px solid var(--card-background-color)"
          - font-size: "8px"
          - line-height: "10px"
          - background-color: >
                return "rgba(var(--color-red),1)";
  styles:
    custom_fields:
      notification: >
          if (state.variables.ulm_chip_icon_state_entity.state > 0 ){
            return `<ha-icon icon="mdi:exclamation" style="width: 10px; height: 10px; color: var(--primary-background-color);"></ha-icon>`
and here is the result :
Capture dā€™eĢcran 2022-01-28 aĢ€ 11.47.24
No alerte and the icon is too high.
With the standard chip_icon_state :
Capture dā€™eĢcran 2022-01-28 aĢ€ 11.47.51
Icon and Label are centered.
Whatā€™s wrong in my code ? Can Someone help ?
How about a floating button. It uses less space
Hello, nice layout. Is it possible to share code?
Thanks!
I clean my code i will post the code later yes :slight_smile:
Hi all,
Iā€™ve almost completed my thermostat card, but stuck on returning the remaining time of my timer.
I have configured a timer and using node-red to turn off the AC unit after the timer finishes.
I am wanting to return the current remaining time in the label section.
The timer countdown works as seen below, but i am unsure as to how to return this value in the custom card.
I am using the input number card.
card_input_number:
  variables:
    ulm_card_input_number_name: "n/a"
  styles:
    grid:
      - grid-template-areas: "'item1' 'item2'"
      - grid-template-columns: "1fr"
      - grid-template-rows: "min-content  min-content"
      - row-gap: "12px"
    card:
      - border-radius: "var(--border-radius)"
      - box-shadow: "var(--box-shadow)"
      - padding: "12px"
  custom_fields:
    item1:
      card:
        type: "custom:button-card"
        template:
          - "icon_info"
          - "ulm_language_variables"
          - "input_number"
        tap_action:
          action: "more-info"
        entity: "[[[ return variables.ulm_card_input_number_entity ]]]"
        name: "[[[ return variables.ulm_card_input_number_name ]]]"
        show_last_changed: false
        label:
          entity: timer.ac_timer
Any help on the label section would be greatful.
Aaron
I have also found with the light slider you cannot tap and drag with any touch interface. You can only tap along the bar. Makes it very difficult to adjust, especially to 100%.
Does anyone know how to resolve this?
Great job, really love to see your code for the thermostat any chance you can share this with me? Thanks in advance!
I have a question on the custom_cards, when I installed the integration it seems the custom_cards was not installed. (only the cards where) Is there a way to install from HACS? I searched but couldnā€™t find them. Or is it only manual? If Manual, is there a special place I should be creating these files? Thanks in advance.
the custom cards can be downloaded from the git hub - GitHub - UI-Lovelace-Minimalist/UI: UI-Lovelace-Minimalist is a "theme" for HomeAssistant
custom cards
download the zip then copy the custom card folder you need into your templates folder
templates folder
make sure you include the below in your lovelace-minimalist.yaml file to include the templates in your code.
button_card_templates: !include_dir_merge_named minimalist-templates/
Thanks for getting back to me! I am a little confused. I donā€™t have a lovelace-minimalist.yaml file. Mine is ui-lovlace.yaml file that came as default with this integration. Is that what I would add this too? Thanks again for all the help :slight_smile:
oh thatā€™s just what i named my yaml file when I started.
Please read the docs. This is the official way how to use custom cards: Configuration - UI Lovelace Minimalist
Yes thanks I got it working, thanks for responding :slight_smile:
Love to see your code as well so I can do the same. Thanks in advance!
Hello everyone !
A few days ago, I discovered this ā€œthemeā€ which I really like; I am therefore in the process of switching my old dashboard to ā€œUI Minimalistā€. I started with the rather basic cards, but now Iā€™m getting into small customizations and now Iā€™m stuckā€¦
The old cards to convert
With the help of the community, I had set up some ā€œTemperaturesā€ cards that visually and functionally pleased me a lot. So I want to adapt something that comes as close as possible to it, as Iā€™m not convinced by already existing examples that I found here and there.
  • The old card design :
The associated code
type: entities
title: Salon
state_color: false
theme: transparent
entities:
  - entity: sensor.netatmo_air_quality_jouffroy_temperature
    type: custom:multiple-entity-row
    style: |
      .entity:not(.state)>div {
        color: var(--secondary-text-color);
    state_header: Actuelle
    entities:
      - entity: sensor.stats_temp_salon_min
      - entity: sensor.stats_temp_salon_max
  - entity: sensor.netatmo_air_quality_jouffroy_humidity
  - entity: sensor.netatmo_air_quality_jouffroy_co2
  - type: custom:swipe-card
    reset_after: 5
    parameters:
      roundLengths: true
      effect: coverflow
      speed: 650
      spaceBetween: 20
      threshold: 7
      coverflowEffect:
        rotate: 80
        depth: 300
        start_card: 1
    cards:
      - type: custom:hui-element
        card_type: horizontal-stack
        cards:
          - type: custom:mini-graph-card
            align_icon: state
            line_width: 3
            color_thresholds:
              - color: '#ef1d0f'
                value: 25
              - color: '#ef5a0f'
                value: 24
              - color: '#f0da11'
                value: 22
              - color: '#11f13a'
                value: 19
              - color: '#1da4f2'
                value: 15
            entities:
                index: 0
            hour24: true
            more_info: false
            points_per_hour: 1
            show:
              labels: false
            align_icon: state
            entities:
                index: 0
            hour24: true
            line_color: '#1da4f2'
            more_info: false
            line_width: 3
            points_per_hour: 1
            show:
              labels: false
        cards:
            align_icon: state
            entities:
              - entity: sensor.netatmo_air_quality_jouffroy_noise
                index: 0
            hour24: true
            line_color: '#ff0000'
            more_info: false
            line_width: 3
            points_per_hour: 1
            show:
              labels: false
            align_icon: state
            entities:
              - entity: sensor.netatmo_air_quality_jouffroy_pressure
                index: 0
            hour24: true
            line_color: '#A700FF'
            more_info: false
            line_width: 3
            points_per_hour: 1
            show:
              graph: bar
              labels: false
My work in progress on UI Minimalist
I tried my best to convert those cards, but without much successā€¦
  • The draft :
The associated code
      - type: 'custom:button-card'
        template: card_generic
        show_label: false
        show_state: false
        show_name: false
        show_icon: false
        styles:
          card:
            - border-radius: var(--border-radius)
            - box-shadow: var(--box-shadow)
            - padding: 0px
        styles:
              grid:
                - grid-template-areas: '"item2 item2 item2 item2" "item3 item3 item3 item3"'
                - grid-template-rows: min-content min-content min-content min-content
                - grid-template-columns: 1fr 1fr 1fr 1fr
                - row-gap: 7px
        custom_fields:
          item2:
            card:
              type: entities
              title: Salon
              state_color: false
              entities:
                  style: |
                  entities:
          item3:
            card:
              reset_after: 5
              parameters:
                roundLengths: true
                effect: coverflow
                speed: 650
                spaceBetween: 20
                threshold: 7
                coverflowEffect:
                  rotate: 80
                  depth: 300
                  start_card: 1
              cards:
                - type: horizontal-stack
                  cards:
                      align_icon: state
                      line_width: 3
                      color_thresholds:
                        - color: '#ef1d0f'
                          value: 25
                        - color: '#ef5a0f'
                          value: 24
                        - color: '#f0da11'
                          value: 22
                        - color: '#11f13a'
                          value: 19
                        - color: '#1da4f2'
                          value: 15
                      entities:
                          index: 0
                      hour24: true
                      more_info: false
                      points_per_hour: 1
                      show:
                        labels: false
                      align_icon: state
                      entities:
                          index: 0
                      hour24: true
                      more_info: false
                      line_width: 3
                      points_per_hour: 1
                      show:
                        labels: false
                  cards:
                      align_icon: state
                      entities:
                          index: 0
                      hour24: true
                      more_info: false
                      line_width: 3
                      points_per_hour: 1
                      show:
                        labels: false
                      align_icon: state
                      entities:
                          index: 0
                      hour24: true
                      more_info: false
                      line_width: 3
                      points_per_hour: 1
                      show:
                        graph: bar
                        labels: false
Can any of you help me make this more ā€œUI Minimalist-compatibleā€? I admit that Iā€™m a little out of ideas, Iā€™ve reached the maximum that my skills allow for now :smiley:
Thanks to you all !
I am very sorry for stupid question, but how to properly delete minimalist theme installed on very first beta version when we download files directly without hacs integration?
