Hi Craig
Hum, this card works well on my side.
Hi all
I work on the theme this week-en and I also looked about your feedback.
I will update the git in the week
Here is a small teaser
Apologies if I have overlooked this in the github repo, but I couldnt find the chip template for an alarm:
Could you point me in the right direction?
Hi @telashton
It does not exist
I made this illustration to give ideas for use
- Travel time
- Number of days without smoking
- Number of bikes in the nearest station
- Number of aliens in your attic
- etc …
You can get inspiration from other chips to create your own alarm template
Thanks @tben - I had already made one, but the alarm image in your illustration fitted the overall theme much better than the one I had chosen
Hi @tben
Do you know if it is possible to bind a different tap action to the icon than a tap on the rest of the card?
I feel like I would have a lot of wasted space if I would add an entire extra row just to toggle the lights, like the example with extra actions.
Hi @bms
Technically it is possible of course. But not with my current template
You can create a card composed of 2 items, on one side you can use the icon
template which is already available and on the other side you can display the name and status of the entity.
You can start from the card cover
which already uses the principle of nested card.
Great work. Will try it.
Would like to have automatic themes enabled on my phone.
Thx,
I’m gonna try this and post the template if the result is satisfying.
(Or a github pull request if you prefer )
Hi how can I place the spotify icon like the image below? is it an image or an emoji
Oops, I just realized that there is no more template to display an icon + text in a chip
I’ll add this on Github this week with the other improvements
Hi @tben,
I have create a pull requests with the custom folder (or addon) section as suggested by @clemalex : https://github.com/TBens/lovelace-ui-minimalist/pull/2
Feel free to approve or not.
Again, thank you for this beautiful design
Can you just share your rough code? Maybe I can help polishing it?
I can’t seem to get it to work with my system, I have uploaded all of the files you Lovelace.yaml first an !include, when that didn’t work, I inserted it directly into the file but still no change, any ideas why?
light card example
Did you also add icon_info_bg
as template to your button-card?
template:
- icon_info_bg
- light
I did,
entity: light.omers_bedroom
template:
- icon_info_bg
- light
type: custom:button-card
widget_icon_signal:
tap_action:
action: toggle
color: var(--google-grey-500)
show_icon: true
show_name: false
icon: >
if (entity.attributes.fan_mode == 'LOW')
return 'mdi:network-strength-outline';
else if (entity.attributes.fan_mode == 'LOW_MID')
return 'mdi:network-strength-1';
else if (entity.attributes.fan_mode == 'MID')
return 'mdi:network-strength-2';
else if (entity.attributes.fan_mode == 'MID_HIGH')
return 'mdi:network-strength-3';
else if (entity.attributes.fan_mode == 'HIGH')
return 'mdi:network-strength-4';
else if (entity.attributes.fan_mode == 'NATURE')
return 'mdi:leaf';
else
styles:
card:
- box-shadow: none
- padding: 0px
#- background-color: 'rgba(var(--couleur-theme),0.05)'
- background-color: transparent
- border-radius: 100%
- place-self: center
- height: 42px
- width: 42px
grid:
- grid-template-areas: '"i"'
icon:
- color: "rgba(var(--couleur-theme),0.9)"
state:
- styles:
icon:
- color: "#ffffff"
value: heat
- styles:
icon:
- color: "#ffffff"
value: dry
- styles:
icon:
- color: "#ffffff"
value: cool
- styles:
icon:
- color: "#ffffff"
value: fan_only
- styles:
icon:
- color: "#ffffff"
value: heat_cool
- styles:
icon:
- color: "#ffffff"
- display: none
card:
- display: none
value: "off"
climate_temperature_text:
#tap_action:
#action: toggle
show_icon: false
show_name: true
show_label: true
if (entity.state == 'off')
return entity.attributes.current_temperature;
else
return entity.attributes.temperature;
label: "°C"
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
- font-size: 20px
- font-weight: bold
grid:
- grid-template-areas: '"n" "l"'
name:
- font-size: 25px
- align-self: center
label:
- font-size: 15px
state:
- styles:
name:
- color: "#ffffff"
label:
- color: rgba(255,255,255,0.3)
value: heat
- styles:
name:
- color: "#ffffff"
label:
value: dry
- styles:
name:
- color: "#ffffff"
label:
value: cool
- styles:
name:
- color: "#ffffff"
label:
value: fan_only
- styles:
name:
- color: "#ffffff"
label:
value: heat_cool
widget_icon_circle_climate:
tap_action:
action: toggle
show_icon: true
show_name: false
styles:
card:
- box-shadow: none
- padding: 0px
- background-color: "rgba(var(--couleur-theme),0.05)"
- border-radius: 50%
- height: 42px
- width: 42px
grid:
icon:
state:
- value: "heat"
styles:
card:
- background-color: "#ffffff"
icon:
- color: rgba(var(--couleur-jaune),1)
- value: "dry"
styles:
card:
icon:
- color: rgba(var(--couleur-light-yellow),1)
- value: "cool"
styles:
card:
icon:
- color: rgba(var(--couleur-bleu),1)
- value: "fan_only"
styles:
card:
icon:
- color: rgba(var(--couleur-grey),1)
- value: "heat_cool"
styles:
card:
icon:
- color: rgba(var(--couleur-vert),1)
climate_text_only:
tap_action:
action: more-info
show_icon: false
label: >-
var climate_mode = entity.state;
if (climate_mode == 'heat'){
var etat = "Ανοιχτό • Ζέστη";
} else if(climate_mode == 'dry'){
var etat = "Ανοιχτό • Στεγνό";
} else if(climate_mode == 'cool'){
var etat = "Ανοιχτό • Κρύο";
} else if(climate_mode == 'fan_only'){
var etat = "Ανοιχτό • Ανεμιστήρας";
} else if(climate_mode == 'heat_cool'){
var etat = "Ανοιχτό • Ανακύκλωση";
} else {
var etat = "Κλειστό";
return etat ;
styles:
card:
- border-radius: 8px
- padding: 5px 0
state:
- styles:
card:
- background-color: rgba(var(--couleur-jaune),1)
img_cell:
#- background-color: rgba(var(--couleur-jaune), 0.2)
- background-color: rgba(255,255,255,0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: heat
- styles:
card:
- background-color: rgba(var(--couleur-light-yellow),1)
img_cell:
#- background-color: rgba(var(--couleur-light-yellow), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: dry
- styles:
card:
- background-color: rgba(var(--couleur-bleu),1)
img_cell:
#- background-color: rgba(var(--couleur-bleu), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: cool
- styles:
card:
- background-color: rgba(var(--couleur-grey),1)
img_cell:
#- background-color: rgba(var(--couleur-grey), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: fan_only
- styles:
card:
- background-color: rgba(var(--couleur-vert),1)
img_cell:
#- background-color: rgba(var(--couleur-vert), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: heat_cool
climate_icon_only:
#tap_action:
# action: toggle
# action: call-service
# service: script.step_hvac_mode
# service_data:
# climate_id: "[[[ return variables.entity ]]]"
show_name: false
icon: |
var icon = 'mdi:snowflake';
var icon = 'mdi:fire';
var icon = 'mdi:water-percent';
var icon = 'mdi:fan';
var icon = 'mdi:autorenew';
} else {
var icon = 'mdi:power';
return icon ;
styles:
card:
state:
- styles:
card:
icon:
#- color: rgba(var(--couleur-jaune),1)
- color: "#ffffff"
img_cell:
value: heat
- styles:
card:
icon:
#- color: rgba(var(--couleur-light-yellow),1)
- color: "#ffffff"
img_cell:
value: dry
- styles:
card:
icon:
#- color: rgba(var(--couleur-bleu),1)
- color: "#ffffff"
img_cell:
value: cool
- styles:
card:
icon:
#- color: rgba(var(--couleur-grey),1)
- color: "#ffffff"
img_cell:
value: fan_only
- styles:
card:
icon:
#- color: rgba(var(--couleur-vert),1)
- color: "#ffffff"
img_cell:
value: heat_cool
- styles:
card:
- background-color: rgba(var(--couleur-theme),0.05)
icon:
- color: rgba(var(--couleur-theme),0.9)
img_cell:
value: "off"
list_items_climate_three:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"item1 item2 item3"'
- grid-template-columns: 1fr 3fr 1fr
- grid-template-rows: min-content
- column-gap: 7px
climate_buttons_with_favorite:
variables:
entity: climate.default
show_name: false
show_icon: false
styles:
card:
- border-radius: 20px
- box-shadow: var(--box-shadow)
- padding: 12px
# - background-color: |
# [[[variables.entity
# if (states[variables.entity].state == "heat"){
# return 'rgba(var(--couleur-jaune),1)';
# } else if (states[variables.entity].state == "dry"){
# return 'rgba(var(--couleur-light-yellow),1)';
# } else if (states[variables.entity].state == "cool"){
# return 'rgba(var(--couleur-bleu),1)';
# } else if (states[variables.entity].state == "fan_only"){
# return 'rgba(var(--couleur-grey),1)';
# } else if (states[variables.entity].state == "heat_cool"){
# return 'rgba(var(--couleur-vert),1)';
# } else {
# return 'white';
grid:
- grid-template-areas: '"item1" "item2"'
- grid-template-rows: min-content min-content
- row-gap: 12px
state:
- value: "heat"
styles:
card:
- value: "dry"
styles:
card:
- value: "cool"
styles:
card:
- value: "fan_only"
styles:
card:
styles:
card:
custom_fields:
item1:
card:
template: list_items_climate_three
custom_fields:
item1:
card:
entity: "[[[ return variables.entity ]]]"
tap_action:
service_data:
template:
- icon_info
- climate_icon_only
item2:
card:
name: "[[[ return variables.name ]]]"
template:
- icon_info
- climate_text_only
item3:
card:
tap_action:
service: script.step_fan_mode
service_data:
template: widget_icon_signal
item2:
card:
custom_fields:
item1:
card:
icon: mdi:minus
tap_action:
action: >
if (entity.attributes.temperature == '16')
return 'none';
else
return 'call-service';
service: script.temperature_down
service_data:
value: 1
template: widget_icon_circle_climate
item2:
card:
tap_action:
action: more-info
template: climate_temperature_text
item3:
card:
icon: mdi:plus
tap_action:
action: >
if (entity.attributes.temperature == '30')
return 'none';
else
service: script.temperature_up
service_data:
value: 1
Here is the code for climate card template
Inspired on what you made, @djacid , I made my own version. I couldn’t wait… Throwing it in the group too.
Looks like this:
button_card_template.yaml
list_items_favorite:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"item1 item1 item2"'
- grid-template-columns: 1fr 1fr 1fr
- column-gap: 7px
widget_temperature:
tap_action:
action: toggle
show_icon: false
show_name: false
show_label: true
label: |-
var temperature = entity.attributes.temperature;
if (temperature == null) {
var temperature = '-';
return temperature + '°C'
styles:
card:
- box-shadow: none
- padding: 0px
- background-color: 'rgba(var(--couleur-theme),0)'
- border-radius: 14px
- height: 42px
grid:
- grid-template-areas: '"l"'
label:
- color: 'rgba(var(--couleur-theme),0.9)' widget_temperature:
tap_action:
action: toggle
show_icon: false
show_name: false
show_label: true
label: |-
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
grid:
label:
# AIRCO #
airco:
tap_action:
action: more-info
icon: |
if (entity.state =='dry') {
return 'mdi:water';
} else if (entity.state =='heat') {
return 'mdi:radiator';
} else if (entity.state =='cool') {
return 'mdi:snowflake';
} else if (entity.state =='fan_only') {
return 'mdi:fan';
return 'mdi:air-conditioner';
label: >-
if (entity.state =='off') {
return "Off";
} else if (entity.state =='dry') {
return "Dry";
return "Heat";
} else if (entity.state =='heat_cool') {
return "Auto";
return "Cool";
return "Fan";
return entity.state;
state:
- operator: template
value: >
return entity.state != 'off';
styles:
icon:
- color: 'rgba(var(--couleur-rouge),1)'
img_cell:
- background-color: 'rgba(var(--couleur-rouge),0.2)'
# AIRCO WITH BOUTONS #
airco_buttons:
variables:
entity: "climate.example"
styles:
card:
- padding: 12px
grid:
- row-gap: 12px
custom_fields:
item1:
card:
template: list_items_favorite
custom_fields:
item1:
card:
entity: '[[[ return variables.entity ]]]'
if (variables.name == null) {
return variables.entity;
return variables.name;
tap_action:
action: more-info
template:
- icon_info
- airco
type: 'custom:button-card'
item2:
card:
type: horizontal-stack
cards:
- type: conditional
conditions:
- entity: '[[[ return variables.entity ]]]'
state: 'off'
card:
icon: mdi:power
tap_action:
service: climate.set_hvac_mode
service_data:
entity_id: '[[[ return variables.entity ]]]'
hvac_mode: 'cool'
- type: conditional
conditions:
state_not: 'off'
card:
icon: mdi:power-off
tap_action:
service_data:
hvac_mode: 'off'
item2:
card:
custom_fields:
item1:
card:
icon: 'mdi:minus'
tap_action:
service: script.decrease_climate_temperature
service_data:
item2:
card:
icon: 'mdi:temperature-celsius'
tap_action:
action: none
template: widget_temperature
item3:
card:
icon: 'mdi:plus'
tap_action:
service: script.increment_climate_temperature
service_data:
scripts.yaml
increment_climate_temperature:
sequence:
- service: climate.set_temperature
data_template:
entity_id: "{{ entity_id }}"
temperature: >
{{ (state_attr(entity_id, 'temperature') | float) + (state_attr(entity_id, 'target_temp_step') | float) | float }}
decrease_climate_temperature:
sequence:
data_template:
temperature: >
{{ (state_attr(entity_id, 'temperature') | float) - (state_attr(entity_id, 'target_temp_step') | float) | float }}
Hi
I took your feedbacks into account and I updated the git.
I wanted to start on a better basis and I had to rename a lot of components and variables. So there are a lot of breaking changes, I don’t know what was the method to manage it properly
What’s new ?
Adding the theme light/dark
Add light_slider component
Added chips_icon component
Use of auto-entities to list the batteries
this looks gooooooooooooooooooooooooood !
Thx !!
