🌻 Lovelace UI • Minimalist
I posted my code a few comments above
How do you made the qr pop-up card? or is it a image?
Just an image. There are like a million websites that can generate a wifi qr code for you.
I needed a Person chip as well, I quickly created this as a custom card:
Looks good. I also would want the zone icone as a option or as a bubble notification for the chip.
On the card_room, is there a way to change the icon on the 4 sub-icons that appear on the right side? Looking at the Living Room card, the icons on the right are outlets (entity type is switch), but since they control lights I wanted to change their icon. I tried using icon under entity_1, but it didn’t work. I saw an example in the documentation where it’s different but it doesn’t show the yaml to do it.
you can use the customize.yaml file
very nice chip. I’ve copied from your repo.
Thank you
I had a similar thing, and by experimenting found out that changing the header text changes the height of the title somehow. This is annoying and I do not know a real fix, but I worked around it by changing the title a little bit. I discovered this by making both titles the same. You could try to do the same to test it: If I’m right, the misalignment will disappear.
That’s not a bad idea, I’ll try to get something working next week, I might just split up the person chip into 2 different ones, a simple (the one that I have now) and a more advanced with the options you mentioned
wow this looks awesome, can you give us more info?
Especially also the fashion popup I would like to adopt
Is there any way to hide the chip card on desktop devices? I only want to show them on mobile devices. Thanks!
Thank you, that worked perfectly!
That would be cool
Check out the state switch card that might work
Can somebody point me to - or share with me - their Lovelace config file? I’d like to copy paste one to better understand it. I am trying to start from 0 but it’s just way harder than just starting with an example. I see tben’s original files up there but unfortunately they are in French and white I do speak French my install is kept in English.
Thanks!
You might find this resource useful.
Minimalist cards usage
Thanks a lot, indeed this helps. However, not all work for me as described. For example:
          - type: 'custom:button-card'
            template: card_light
            variables:
              ulm_card_light_enable_slider: true
              ulm_card_light_enable_color: true
              ulm_card_light_force_background_color: true
              ulm_card_light_enable_popup: true
              ulm_card_light_slider_collapse_name: Table Left
This code does give me a button, with color and background color forced. However, it has no slides, no popup and the name is not correct. See attached picture the top two buttons:
This should be:
ulm_card_light_name: Table Left
The slider is only working when the my-cards-slider-card is installed either manually or by ticking the box in the integration config. Installation - UI Lovelace Minimalist
The pop-up only works when you have installed browser-mod.
You also need to include the line below to your configuration.yaml file to make browser_mod active.
browser_mod:
Hope this helps you a bit :wink:
