I was a bit tired to use YAML mode for my configurations. So I am using UI mode now, which is good.
But now I wanted to add a footer graph. But that isn’t possible in the UI. So what do I do?
Do I go to YAML? Will my current setup go to YAML-files automatically? (Where is my UI Lovelace config stored btw?)
Oh yes, I know. But looking for the right place in thousands of lines is quite hard!
So, quick rephrase, YAML in text editors on disk and UI mode isn’t an option?
Its just saying you won’t be able to use the UI editor for that card as the YAML you’ve added isn’t supported by the UI.
The card will still work, you will just need to use YAML for that card now
Could you tell me how? I have a huge house where every signle light, shutter etc are smart, also a lot of code for Dashboards. I would like to split the code to multiple files, but keep the ability to play with GUI editor.
Did that work? I have read it’s one mode or the other?
I would LOVE to have some dashboards in yaml mode (editable in VS Code, and with code splitting), and some dashboards in UI Mode!
