Lovelace UI
Hi All
I have just started to use the Lovelace UI, and I need to know a few things
With the old UI, I did all my setting in configuration.Yaml, and my UI in groups.yaml
I can see that when I upgraded to Lovelace it created another file called ui-lovelace.yaml
my question is this
I have a light entity that shows up in the old UI (- light.flux_led ) and works exactly as it should do
however when I put the same entity in the ui-lovelace.yaml file the etntity des not show up
Can some one help me please. Love the looks of Lovelace but this has me stupted.
Paul
share your lovelace file (see the blue bar at the top of every post)
Also, double check the entity ID.
Hi There
Just restarted the HA and this is in Info
http://192.168.0.7:8123/frontend_latest/bf7146608f595468a214.chunk.js:3157:1358 Unable to get property 'name' of undefined or null reference
‎7‎:‎50‎ ‎PM components/system_log/__init__.py (ERROR)
Error while setting up platform songpal
‎7‎:‎48‎ ‎PM components/media_player/songpal.py (ERROR)
Setup of platform ring is taking over 10 seconds.
‎7‎:‎48‎ ‎PM util/async_.py (WARNING)
Sytem log as below
18-12-17 19:22:57 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:25:52 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-12-17 19:25:59 INFO (SyncWorker_5) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
18-12-17 19:26:38 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-12-17 19:26:38 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:26:40 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:26:41 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.2
18-12-17 19:27:12 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:34:03 INFO (SyncWorker_12) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
18-12-17 19:34:41 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-12-17 19:34:41 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:34:43 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:34:44 INFO (SyncWorker_13) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.2
18-12-17 19:35:14 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:40:22 INFO (SyncWorker_11) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
18-12-17 19:41:01 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-12-17 19:41:01 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:41:04 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:41:05 INFO (SyncWorker_1) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.2
18-12-17 19:41:36 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:43:09 INFO (SyncWorker_13) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
18-12-17 19:43:47 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-12-17 19:43:47 INFO (SyncWorker_5) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:43:49 INFO (SyncWorker_5) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:43:51 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.2
18-12-17 19:44:21 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:47:05 INFO (SyncWorker_15) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
18-12-17 19:47:44 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
18-12-17 19:47:44 INFO (SyncWorker_13) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:47:46 INFO (SyncWorker_13) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
18-12-17 19:47:47 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.84.2
18-12-17 19:48:17 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
18-12-17 19:55:52 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
* List item
