Found the issue, should be fixed in latest release
I just updated to the latest code, am seeing the following error in the console (currently only using Radarr/Sonarr):
[frontend.js.latest.201811033] http://10.0.1.8:8123/local/custom-lovelace/upcoming-media-card/upcoming-media-card.js:247:40 TypeError
: undefined is not an object (evaluating 'json[count][key]')
Uncaught TypeError: cannot read property 'airdate' of undefined
Working fine now!
Im getting this error “upcoming-media-card.js:16:39 Uncaught TypeError: Cannot read property ‘state’ of undefined”
this is on my Plex card, my Sonarr card is working fine, anybody knows what’s wrong? In dev-states I can see the sensor with the right information. Also downloads the images, but it breaks my Lovelace UI.
Anyone?
What’s your ui-lovelace.yaml code for the card look like?
Tried a few different the latest is:
- type: custom:upcoming-media-card
entity: sensor.plex_recently_added
title: Recently Downloaded
That looks fine. What’s a sample of your sensor data from the sensor look like? Feel free to PM it to me if you prefer.
I pm’d you. I think…
Everything looks good there too. Could try clearing your cache, reinstalling the card, or bumping the version number of the card in the resource section of ui-lovelace.yaml.
Just d/l a movie and no flag showing… its a day before the due date.
Sometimes it takes a bit for Radarr and Sonarr to update. If their API doesn’t report it as downloaded, then neither will the card.
hmm… It normally picks up sonarr instantly. If I check it flag: false shows but radarr says downloaded - what is the refresh interval?
Ah, no. I think I see the issue. Not exactly an easy fix, but it will be soon.
Actually wasn’t as bad as I thought. All should be in working order now.
Updated sonarr, radarr, and plex components to address the issue with notification flag not updating.
Thanks @DavidFW1960!
Sweet. Not seeing in the updater just yet…
I think the updater refreshes every 10 min. Should be there now-ish
got it and it’s fixed. Sonarr was fine before - only radarr…
Plex had the same issue and I had minor changes in sonarr so I just updated them all
Plex_Recently_Added Update:
Thanks to @tmcarr the download image directory is now able to be configured using img_dir
in config.
