That was my idea too that it has to be relatetd with the derived entity or that the index/state will be overwritten… but with the hint of the converter the last one is kicked off…
So thanks for that. it´s a step closer to the solution…
I’m probably not understanding something here and wonder f anyone can give me some pointers. I’ve installed step 1 using HACS and now trying to do step 2 but can’t find a Lovelace folder. I’m running a Pi4 with Hass.io and have SFTP and SSH etc working.
Is this because Hass.io uses a different folder structure or is it something else? if so, where do the files need to go?
If it’s not yet there, you have to make the folder yourself. I believe it’s only there if you use the yaml version of the frontend, instead of the direct editor.
It should be located in the root folder of your home assistant, i.e. at the same place as where you can find your configuration.yaml
Made on ‘custom:swiss-army-knife-card’, there is a big lack of “hold_action”, I wanted to make a video help on sensors in the dashboard: where they are, what they look like, how to change batteries and what batteries are needed. An example is in the video.
Maybe I don’t get it right. I, using the v2.5.1-dev.2 part of the SAKS. But when I try to inplement the new line chart it says: “s[t.type] is not a constructor”
Here is part of the yaml when the error code is generated:
Thanks for your solution, unfortunately it wasnt that. The indentation in my yaml was correct. I just copied en pasted in wrong in this forum. The -type and view_layout etc is correctly aligned.
Moreover, on another page the fce2 examples from marswarrior show the same error.
I thinks I messed something up beacuse of the v2.5.1-dev.2 version. I copied some files over but not all of them. Maybe there is something missing. Are there instructions how to install v2.5.1-dev.2 or is it just copy and paste evertging over v2.5.1?
