Lovelace vs old front-end group toggle
I’m trying to get a toggle for all the entities in a card and I thought the “show_header_toggle: true” would do that but it is not working. Any help is appreciated.
old_frontent:
Screenshot%20from%202018-08-24%2009-12-14
Lovelace_frontent:
Screenshot%20from%202018-08-24%2009-12-49
Can you share the part of the ui-lovelace.yaml file that you’re having issues with? This is working fine for me, here’s a sample of my config:
  - type: entities
    title: Lights
    entities:
      - light.bedroom
      - light.hall
      - light.living_room
      - light.office
Sure, here it is.
- type: entities
  title: Alarm TTS
  entities:
  - automation.tts_back_door
  - automation.tts_garage_door
  - automation.tts_front_door
sorry, fixed.
                  - type: entities
                    title: Alarm TTS
                    entities:
Interestingly enough, works fine for cards with lights. maybe an issue with entities that are not lights or switches?
Screenshot%20from%202018-08-24%2009-56-20
I’m having the same issue and yes, it looks like it doesn’t work for anything that isn’t a light or a switch. I want to have a toggle for certain automation groups (therefore I can’t use group.all_automations) that I create in lovelace. Not sure how to go about this.
make a switch template that turns on/off the all_automations group.
switch:
    switches:
      all_automations:
        value_template: "{{ is_state('group.all_automations','on') }}"
        turn_on:
          - service: homeassistant.turn_on
            entity_id: group.all_automations
        turn_off:
          - service: homeassistant.turn_off
I’m looking to create a switch only for certain automations, i.e automations related to certain rooms of the house, some automations but not others, for example. The above is useful to create a switch for all automations (which for me, is better than nothing) but ideally would like a way to bunch automations together in a group and create a switch for them somehow.
Sorry but I just don’t see the dilemma. If you want a sub set of automations, just make a group with the automations you want. Then make the switch template for the group.
group:
  mygroup:
    entities:
      - automation.auto1
      - automation.auto2
switch:
    switches:
      all_automations:
        value_template: "{{ is_state('group.mygroup','on') }}"
        turn_on:
            entity_id: group.mygroup
        turn_off:
I knew it was something simple, this is exactly what I’m looking for. Thanks!
The same issue,marked.HA 0.86.0
Use the Lovelace UI editor to disable/enable the toggle for groups.
