Lovelace Wallpaper Screensaver integration removal failing
Hi All,
I’m trying to totally remove some HACS integrations and I guess the first question is to verify that I can’t remove integrations from HACS via HACS? I thought this was posisble in the past, but I don’t see any way of doing that now per the below image.
I managed to clear out a couple of troublesome integrations but this one just refuses to die. Now I’ve ended up with the integration not loading properly I assume due to beiong partially removed.
So, folder deleted, nothing in HACS folder, and deleted the resource from Dashboards.
I’ve disabled HACS, removed the relevant section in hacs.repositories and restarted HACS but it just returns. I’ve tried disabling HACS, removing the section, restarting and then reenabling HACS but none of the methods appear to work.
    "484333657": {
      "repository_manifest": {
        "name": "Lovelace Wallpanel Screensaver",
        "render_readme": true,
        "zip_release": true,
        "filename": "wallpanel-screensaver.js"
      "category": "plugin",
Happy to hear of any suggestions or pointers in the right direction.
Regards,
Paul
Did you ever figure this out? I used an example config from the github and after I changed it, it was still doing what the example said.
No, I just didn’t bother looking into it any further.
Regs,
Paul
